Rules: One new topic per day
2 3 4 5 end
Archive 2007 · HDR Tutorial
thapamd
p.1 #1 · HDR Tutorial
People often point out limited dynamic range as one of digital photography’s shortcomings. True enough. However, at least in the world of landscape photography, that claim is becoming less and less true, mostly thanks to HDR (high dynamic range) imaging. In this tutorial I will show, by example, my method for creating an HDR image. I will be using Photoshop CS3 Beta. However, all the steps are also available in PS CS2. I have no experience with other HDR creating software such as Photomatrix, so I won’t be able to comment on them.
Here’s the most important rule to remember about HDR photography: The higher the number of bracketed exposures, the better the outcome. I almost always use at least 6 exposures, and in this example, I’ll be using 9 bracketed exposures, each 1 stop apart (from -4 to +4 exposure units). I also highly recommend that you not increase your bracket width beyond 1 stop. For example, if you want to bracket -2 to +2, expose in one step exposure increments (-2, -1, 0, …). Don’t do -2, 0, +2. Armed with these two important “rules,” you’re ready to tackle HDR photography.
As with any type of photography that involves blending exposures, a steady tripod is a must. Cable release and mirror lockup are highly recommended. Let’s begin!
In Adobe Bridge, I selected 9 bracketed exposures and chose Tools ? Photoshop ? Photomerge… The following is the resultant screen:
To give you an idea of the dynamic range available on the above image, I’ll show you the resultant image after moving the histogram slider to opposite ends:
As you see, the available dynamic range is nothing short of amazing!
Now here’s the image I decided to create. As you can see, I’ve sacrificed the sky detail for the sake of FG detail. It doesn’t really matter how you convert. I just chose this at random.
The product is a 32 bit photograph. Of course our monitors aren’t good enough to show all that info. Therefore, we now have to convert this image to 16 bit. In PS, choose Image ? Mode ? 16 bit. A dialog box appears, asking you how to convert the image. In my experience, the best method is Local Adaptation. Choose this option and then show the histogram:
On the histogram, I suggest clicking on the line at regularly spaced intervals as below, to have finer control of your curve:
Now to tackle the radius and threshold options. For radius I like to use between 75 and 150. For threshold, I like to use between 1 and 2. The values depend on the image, but these ranges have worked for more than 95% of my HDR images. If I choose a threshold value less than 1, I tend to get “haloing” around high contrast interfaces. Above 2, the image appears too low in contrast. For this image, I used radius of 100 and threshold of 1.87. Next is the most difficult step, in my opinion. This is where you need a lot of patience and practice…adjusting the curve. An advice I have is that you not make any abrupt transitions between points…let the shape of the curve be gentle. Also, remember that, in general, the left side of the histogram controls the dark areas and the right side controls the bright areas. Here’s my curve and resultant image:
The above image is not bad, but it lacks punch (contrast). To correct this, I simply apply a curves and a levels adjustment layes as below. Please note that I applied a gradient mask to the levels to darken the sky but leave the FG unaffected. I also did a tad bit of burning to a few of the clouds.
Here is the final image and my history palette, showing all the steps. The FG isn’t as bright as it could be (and that was intentional), but the slight darkness gives it a more “natural” look, I think.
Jan 30, 2007 at 05:51 AM
ajkessler
p.1 #2 · HDR Tutorial
All Right!! Thanks Mahesh!
Jan 30, 2007 at 05:56 AM
kiwis fly
p.1 #3 · HDR Tutorial
Yeh this is awesome stuff, thank you...
Jan 30, 2007 at 06:16 AM
yldan
p.1 #4 · HDR Tutorial
this is awesome.
Jan 30, 2007 at 06:23 AM
neighbourboy
p.1 #5 · HDR Tutorial
Thanks a lot for spending the time doing these tutorials Mahesh.
Jan 30, 2007 at 06:51 AM
stangeroo
p.1 #6 · HDR Tutorial
may be a noob question, but are you using unedited raw files or processed jpegs?
Jan 30, 2007 at 07:49 AM
Alex Nail
p.1 #7 · HDR Tutorial
Hooray. Just what I wanted to see. Very helpful. The key I gues is using loads of exposures. I supose you bracket manually?
Alex
Jan 30, 2007 at 08:07 AM
pascupixar
p.1 #8 · HDR Tutorial
YOU ARE THE MAN.
Thank you very much for this absolutely incredible tutorial. You explain it clear and simple.
Thanks you very very much.
See you.
Pascual
Jan 30, 2007 at 08:15 AM
alexoki
p.1 #9 · HDR Tutorial
Bravo! Thanks, this is what photography forums are all about, much appreciated. However, could anyone explain to me how I exactly apply a gradient to the levels layer mask?
Jan 30, 2007 at 09:28 AM
ramdisk
p.1 #10 · HDR Tutorial
Thanks for taking the time.....................
Jan 30, 2007 at 10:08 AM
xpzhang
p.1 #11 · HDR Tutorial
Now I know why my HDR looks fake. Need more bracketing!
Thank you again!
Betty
Jan 30, 2007 at 12:36 PM
pappy
p.1 #12 · HDR Tutorial
Many thanks, Mahesh.
Jan 30, 2007 at 12:50 PM
Mike Ganz
p.1 #13 · HDR Tutorial
Excellent tutorial...I agree with a PP that this is truly the intent of photography forums...provide a transfer of knowledge to help others bring up their skill levels.
Now for the 'dumb question'...Is there any way to 'Save' this and other tutorials for future use, without having to dig up the thread at a later time? I'm not a PS expert (yet) by any means and not sure how to go about this.
Jan 30, 2007 at 12:58 PM
Jarvone
p.1 #14 · HDR Tutorial
Very helpful. Thank you. Jarv
Jan 30, 2007 at 02:44 PM
thapamd
p.1 #15 · HDR Tutorial
Strangeroo,
You have to use unprocessed RAW files to create an HDR image. JPEG is not even an option.
Jan 30, 2007 at 03:00 PM
Guest
Guest
p.1 #16 · HDR Tutorial
Thanks Mahesh Now for those that have cameras that can only bracket 3 exposures what do you suggest?
Al
Jan 30, 2007 at 03:02 PM
thapamd
p.1 #17 · HDR Tutorial
Alex,
See my 1st tutorial (Sunset/Night Photography) on the 1st page of this forum. I talk about applying a gradient to a mask in more detail there. Essentially, this is how you create a mask:
Then, select the gradient tool or just press "g". Then click and drag the mouse from the top of the picture to the bottom, while the MASK thumbnail on your layers palette (not the thumbnail of the layer itself) is selected. Hope this helps.
Jan 30, 2007 at 03:06 PM
thapamd
p.1 #18 · HDR Tutorial
Hi Mike, I know there is a way, but damned if I know how. I've seen it done before. I suppose you could just copy and paste the info on a Word docement or use a program like Front page to copy the info. If all else fails, screen capture may be what you have to do.
Hopefully, someone else here more learned than myself can provide more helpful information about this.
Jan 30, 2007 at 03:09 PM
wzictrace
p.1 #19 · HDR Tutorial
great tutorial
*tag*
Jan 30, 2007 at 03:12 PM
thapamd
p.1 #20 · HDR Tutorial
Al
Hi Al,
My camera can't do 9 braketed exposures either (one of the features I envy on the Nikon D2X). I'm forced to touch the camera. The first bracket set is -4,-3,-2; second set is -1, 0, +1; 3rd set is +2, +3, +4. After you change a bracket set, the key is to wait a few seconds. This allows the little vibrations from your touch to dampen. If you truly have a very steady setup, the camera should "rest" back to the same position. Another pretty cool feature about HDR in PS is that if there are minimal movements, the software corrects for them. I've noticed that a few of my shots have actually been rotated and cropped automatically.
Jan 30, 2007 at 03:16 PM
thapamd
p.1 #21 · HDR Tutorial
Alex
You got it, Alex! Tons of exposures and manual bracketing on a very, very steady tripod. See my response to Al's question.
Jan 30, 2007 at 03:27 PM
Milan Hutera
p.1 #22 · HDR Tutorial
As Bruce allmighty says B-E-A-UTIFUL... Thanks a lot for taking the time and writting these wonderful tutorials for us.
But... what about us with CS1? it doesn't have HDR merge function...
Jan 30, 2007 at 04:03 PM
Milan Hutera
p.1 #23 · HDR Tutorial
BTW, those who want to save the tutorial, the easiest way how to do it is to go to the "file" menu in your browser and select "save page as"... At least IE and Firefox can do it easily. I don't know about Safari, but I supose it can do it as well....
When you need it, you'll simply open it later from the destination you saved it to. It will save the whole first page including pictures.
Jan 30, 2007 at 04:08 PM
thapamd
p.1 #24 · HDR Tutorial
I don't think CS1 has that tool. Time for an upgrade, maybe?
Jan 30, 2007 at 04:09 PM
Refraction
p.1 #25 · HDR Tutorial
Nicely done. I'm often frustrated with the 3 bracket limit as well. Not only does it introduce the possibility of movement, but it takes more time to set up and HDR images tend to show up best when the time between shots is minimized.
Jan 30, 2007 at 04:35 PM
2 3 4 5 end
