GreenArcher Offline Upload & Sell: Off
p.1 #14 · When not to use a polarizer? | |
Lens cap is of limited use as a protection when hiking/backpacking, unless you are not taking a picture. The moment you take the lens cap off, the front element is naked to the elements. There lots of dust, sand, etc.. outdoors. At the end of the day, my polarizer sometimes has accumulated enough dust to warrant cleaning of the filter. Sometimes, I have to clean the filter every couple of hours due to dust.
I use the polarizer to remove the reflections/glare from leaves, trees, rocks, boulders, and water. And so far, I ended up using my polarizer 99.9% of my landscape shots. I should try taking landscape shots with/out a polarizer on my next hike to see the difference.
I only use filters when I am outdoors hiking/backpacking. Otherwise, I do not put filters on my lenses, not even UV. Honestly, I am a bit lazy taking the polarizer off when hiking. So I ended keeping it on during the day, whether it is overcast, cloudy, drizzling. Of course, at night, or when I need the extra light, I take the polarizer off and put a UV or none at all, depending on the elements. I cannot see myself putting UV, then putting POL, then UV again when hiking. Too much hazzle. But I would do it if it renders a scene better. This is what I am trying to find out/learn.
