Archive 2006 · I could use some advice on a good walk around zoom lens...
srv656s
p.1 #1 · I could use some advice on a good walk around zoom lens...
Recently I went on a vacation with my family and took my new 350D. I have the kit lens 18-55 and the thrifty fifty (50mm 1.8). Well, the 50mm prime wasn't really all that useful for most of the situations I was in. The kit lens stayed on the camera about 95% of the time. I went through the pics I took, and most of the pics were taken between 18-30mm. There were a few cases when I zoomed all the way to 50mm, but mostly stayed in the lower range.
I'm kind of looking for something now to replace the kit lens with. I've been looking at the 17-40L, but I'm worried the 40mm end might be a little limiting. I'm also not sure if the f4 is as fast as I'd like. The other zoom lenses I've looked at don't go nearly as wide as the kit lens and the reviews are mixed.
If anyone has any ideas or opinions, I'd love to hear them!
Thanks
Shawn
Feb 20, 2006 at 06:40 PM
jtyszka
p.1 #2 · I could use some advice on a good walk around zoom lens...
Get the 17-40, then you have the 50 prime and in the future you can add a 85 prime and a 70-200 maybe, for a nice line up.
If not, there is also 24-70L, and that's 2.8 so you should be fine.
24-105 might also be in your interest. It's f4 but its got IS.
You're on a budget?
Feb 20, 2006 at 06:55 PM
ken.vs.ryu
p.1 #3 · I could use some advice on a good walk around zoom lens...
sigma 18-50/2.8 or the new tamron 18-50/2.8 or wait and see if a new EF-S lens is announced at PMA.
Feb 20, 2006 at 06:58 PM
foges
p.1 #4 · I could use some advice on a good walk around zoom lens...
agreed, wait until after the PMA's
Feb 20, 2006 at 07:06 PM
Nill Toulme
p.1 #5 · I could use some advice on a good walk around zoom lens...
There's a lot to be said for the 17-85 IS in this context...
Nill
www.toulme.net
srv656s
p.1 #6 · I could use some advice on a good walk around zoom lens...
I'm not on a super tight budget, but I am really not a professional and don't really want to spend thousands on lenses if I can help it.
I have been reading a lot on the 24-70L, and it looks like it'd handle most of my needs, but some reviews state that it casts a shadow when using the built in flash, that isn't a huge deal for some, but I am a little concerned with that. Also, of course, concerned with the $1150 price that most places list that for.
The sigma 18-50 looked like it'd do a lot of what I wanted, but I am worried about getting any more EF-S type lenses (specifically designed for smaller sensors, other companies call them other things I know). With technology moving as it does, I am worried about buying a lens today that will not work on cameras in the future.
Shawn
Feb 20, 2006 at 07:09 PM
elader
p.1 #7 · I could use some advice on a good walk around zoom lens...
I went from the kit lens to the 17-85IS. I really cannot fault this lens- focuses accurately, nice and sharp, wide range, the IS is really useful. I did go and buy a 17-40L and anticipate a face-off. If the 17-40 outperforms the 17-85 by a wide margin, I'll leave it on the camera. If by a small margin, I'll use it for 'photography' and not as a walk-around. If not better at all, you can buy it from me. You can buy the 17-85 for $400 here on FM.
The 24-70 was way too expensive and way too heavy for me and does NOT go wide enough for sightseeing. I really use the 17-24 range A LOT.
Feb 20, 2006 at 07:17 PM
mlorne
p.1 #8 · I could use some advice on a good walk around zoom lens...
I recently took my Sigma 18-50 2.8 to Cuba. It worked like an absolute charm in conjunction with my 85 1.8 and a Tamron 1.4x tele for the 85 (when I need just a little more reach).
As for the DC mount on the sigma, that depends on what you plan on having as your next camera. If you are thinking 5D, 1DSmkII or something to that effect, then by all means go for the 17-40.
Hope this helps.
Feb 20, 2006 at 07:19 PM
coppertop
p.1 #9 · I could use some advice on a good walk around zoom lens...
On the 350D.....
Canon Lenses
1st Choice: 24-105mm f4L IS (if money is no object)
2nd Choice: 28-135mm IS (if you can live with the 28mm end)
3rd Choice: 17-40mm f4L (if you can live with the 40mm end)
4th Choice: 17-85mm IS
Honorable Mention: 24-85mm USM (if your trying to save money)
Non-Canon Lenses:
Tamron 24-135mm
Tamron 18-200mm
Sigma 17-70mm (new lens and initial reports are good)
If money wasn't an issue, the Canon 24-105mm f4L IS is hard to beat. I like my 28-135mm IS but at times do wish it was a 24-135mm.
Feb 20, 2006 at 08:47 PM
ChrisGVE
p.1 #10 · I could use some advice on a good walk around zoom lens...
I would too recommend the 17-85 as walk around lens. It is not a fast lens (4 to 5.6) but IS comes in handy and range is quite ok. As walk around means for me having a single lens for 'point-and-shot' type of photography in normal daylight. Even at night for static subjects, the sensitivity of the 350D and the IS you can take pretty sharp pictures.
For more demanding work or depending whether I take the film body as well, I would take other lenses (mostly primes).
For 1.6 lenses I would wait until PMA to be 100% sure (that is until next PMA...) but I would not be surprised that Canon will continue to produce good cams up to 20D range, i.e. investments in EF-S will not be lost over time.
Feb 20, 2006 at 09:19 PM
Nill Toulme
p.1 #11 · I could use some advice on a good walk around zoom lens...
Hmmm... it does appear that a new 17-55 EF-s lens is to be announced tomorrow. If that turns out to be an EF-s equivalent of the 24-70 f/2.8L it would make an awfully nice high-quality walkaround for the 1.6x crop bodies.
Nill
www.toulme.net
Feb 20, 2006 at 09:55 PM
ChrisGVE
p.1 #12 · I could use some advice on a good walk around zoom lens...
Yes I've just seen it... I'm curious what will be specs and price (2.8+IS+L would be nice...)
Canon could even play the game of Olympus by making a lens 1 stop faster than the conventional FF lens, such as a 17-55/2 IS L...
Feb 20, 2006 at 10:04 PM
Gearfiend
p.1 #13 · I could use some advice on a good walk around zoom lens...
Im surprise no one mentioned the 10-22. If you like to go wide, the 10-22 is awesome. I use it and the 24-70 L as my all purpose setup.
When I need to go really light, I use the kit lens.
Feb 20, 2006 at 11:04 PM
Crusty
p.1 #14 · I could use some advice on a good walk around zoom lens...
For wide landscape shots the 10-22 can't be beaten on a 1.6. For general walkabout the 24-105 is ideal, not too heavy with good reach and excellent results. If you could afford these two you'd be covered for 90% of most situations
Feb 21, 2006 at 12:55 AM
Nill Toulme
p.1 #15 · I could use some advice on a good walk around zoom lens...
Hmmm... looks like the newly announced EF-S 17-55 mm F2.8G IS will be just the ticket. Is "G" the new EF-s corollary to "L"?
Nill
www.toulme.net
Feb 21, 2006 at 03:21 PM
EOS20
p.1 #16 · I could use some advice on a good walk around zoom lens...
You might want to concider the new 17-55 f/2.8 IS. Looks like a nice lens!
Feb 21, 2006 at 03:26 PM
yido
p.1 #17 · I could use some advice on a good walk around zoom lens...
If you want a one lens solution, then I'd recommend either a 17-85 or a sigma 17-70.
If you don't mind the 17-40mm range, then a Canon 17-40L f4 or a Tamron/Sigma 17-35 f2.8-4 maybe a good idea.
I personally think a Sigma 10-20EX and a Sigma 24-70 EX f2.8 makes a better choice than one lens. I also like really wides for more dramatic shots than what 17 or 18mm can offer.
Good luck
Feb 22, 2006 at 04:04 AM
