Archive 2006 · EF Extension tubes???
nl2377
p.1 #1 · EF Extension tubes???
I am in the process of purchasing a 70-200f4L and was wondering how much closer you can focus that lens when using an extention tube (IE 12mm or 25mm)?
Would it be better to shoot for one of these for close up photos, or better to just buy closeup filters for the lens?
Feb 09, 2006 at 09:56 PM
EA6B
p.1 #2 · EF Extension tubes???
http://www.fenderforum.com/userphotos/index.html?recid=9884
70-200 2.8IS w/EF25 tube. Keep in mind this flower is only an inch in size.
E
Feb 09, 2006 at 11:04 PM
krementz
p.1 #3 · EF Extension tubes???
I use the Kenko tubes with the 70-200/4. I'm very happy.
I tried the EFS-60 macro and EF-100 macro. i couldn't see any difference. YMMV.
Feb 10, 2006 at 01:49 AM
nl2377
p.1 #4 · EF Extension tubes???
E
So this is an uncropped image
extention tubes dont allow focus to infinity, correct? if not, how far will they focus to?
Feb 10, 2006 at 06:21 AM
Pell
p.1 #5 · EF Extension tubes???
E
Do you have any 100% crops of this combo? I was curious about it too
Feb 10, 2006 at 07:01 AM
Alan321
p.1 #6 · EF Extension tubes???
The advantage of the extension tube is that it does not introduce any new optics. Also it can be used on most EF lenses. The downside is that the lens has to be removed from the camera to fit the tube, thus allowing the possibility of dust getting on your sensor.
A close-up filter is a lens and it has a single diameter, making it unsuitable for use on many of the EF lenses that have a different filter thread diameter. On the plus side it does not require the lens to be removed from the camera body, so there's less chance of introducing dust to your sensor.
Both are a compromise compared with a genuine macro lens but that's to be expected.
I was happy with the extension tube(s) on my 100-400L.
Feb 10, 2006 at 08:01 AM
ocean7
p.1 #7 · EF Extension tubes???
This should help you :
http://www.bobatkins.com/photography/eosfaq/closeup.htm
Feb 10, 2006 at 08:05 AM
sarumokikaraoc
p.1 #8 · EF Extension tubes???
go with the extension tubes...the optical quality of close-up lenses has yet to be truly proved in my mind.
Feb 10, 2006 at 09:14 AM
