Moderated by: guardian
FM Forums | Nikon-mount SLRs | Join Image Upload
Justin Huffman
Image Upload: Off
p.1 #1 · cokin set on tokina too wide...
well I have a tokina 12-24 and when I mount a cokin P set on the end, you can see the flter housing on the sides, left and right.. If you flip the camera vertical, and rotate the cokin, the edges dissappear... has anyone ever tried to cut down the width of a cokin P holder?
Edited on Feb 02, 2006 at 05:59 PM
Feb 02, 2006 at 01:51 AM
Justin Huffman
Image Upload: Off
p.1 #2 · cokin set on tokina too wide...
no crafty, adventuresome folks out there ?
Feb 02, 2006 at 04:15 PM
mattmak
Image Upload: Off
p.1 #3 · cokin set on tokina too wide...
I've cut off 2 of the 3 filter slots for use on 17mm full frame, but I don't have a 12mm lens to test the results on DX.
Feb 02, 2006 at 04:21 PM
ytwong
Image Upload: Off
p.1 #4 · cokin set on tokina too wide...
i've cut the filter holder too (done it on day one) and now it holds only one. at 18mm on film is ok
Feb 02, 2006 at 05:56 PM
palmbook
Image Upload: Off
p.1 #5 · cokin set on tokina too wide...
I did. It works on 12mm. But you cannot rotate the holder at all @12mm. Moreover, there's a chance to get "a little" vignette, since the upper part of the holder is thicker.
If you are on the budget, or you don't wanna go for X-series, cutting the width of P-series holder is great.
I took this photo with Tokina 12-24mm @16mm and Grad ND on. I rotate the holder, which is for P-series, to match the slanted building line.
Lost password?
