Archive 2006 · D100 and Nikkor 50mm 1.2 Metering?
edrud
p.1 #1 · D100 and Nikkor 50mm 1.2 Metering?
Am I being stupid or thick or what?
Just got the Nikon 50mm 1.2 AIS lens from another FMer, and am playing with it on my D100. Does the internal metering not work at all with this lens? Even if I set the camera to Manual, the aperture setting always shows F -- --
I don't care about the manual focus, but I need some metering!
Thanks,
Ed R.
Jan 05, 2006 at 03:40 PM
mkonik
p.1 #2 · D100 and Nikkor 50mm 1.2 Metering?
No dice...
Minimum body that supports metering with manual lenses is the new D200.
Jan 05, 2006 at 05:02 PM
edrud
p.1 #3 · D100 and Nikkor 50mm 1.2 Metering?
D'oh! Well, I have my money and am planning to get the D200 in the next month or so; I guess that'll have to be my story.
Thanks,
Ed R.
Jan 05, 2006 at 05:16 PM
mkonik
p.1 #4 · D100 and Nikkor 50mm 1.2 Metering?
I would keep it, its a fantastic low light lens, I've had several folks walk up and wonder what that short bulbous lens was ;-) that and the 55 micro are my two favorite normal portrait lenses.
Jan 05, 2006 at 05:29 PM
the chemist
p.1 #5 · D100 and Nikkor 50mm 1.2 Metering?
i dont know the specifics with the D100 but you should be able to spot meter and center weight meter as well. Just not matrix meter. Just adjust the Aperature manually. Its always going to read F-- but should meter.
Jan 05, 2006 at 05:43 PM
jmcfadden
p.1 #6 · D100 and Nikkor 50mm 1.2 Metering?
if you won't believe Marc, which I highly recommend that you do , will you believe me ?
It will Not meter at All in any mode at any time with a AI or AIS lens
J
Jan 05, 2006 at 05:49 PM
edmanet
p.1 #7 · D100 and Nikkor 50mm 1.2 Metering?
I believe you John !!!
Jan 05, 2006 at 07:02 PM
bellyface
p.1 #8 · D100 and Nikkor 50mm 1.2 Metering?
use your histograms. M mode and histograms preview, or just guestimate. Too bad the simpler bodies don't support the 30+ years of nikkor engineering. The D1 series, D1, D1X, D1H support most AI(s) lenses, minus matrix metering, centerweighted + spot & focus aid work just fine though.
But you can get by managing with the histogram previews.
Good luck, and kudos for a owning one of the great, brighter nikkors!
Jan 05, 2006 at 07:08 PM
