Archive 2005 · Canon Lenses at the Wide end?
johnastovall
p.1 #1 · Canon Lenses at the Wide end?
I'm looking for adding to my wide end options this year to go with the 5D which is in the works.
I've already decided on the 35mm f/1.4L and the 24mm f/1.4L But beyond that it looks like the choices are the 14mm f/2.8L or the 15mm f/2.8 fisheye.
The 14 seem to be very pricey for even an L but do you get great quality for the price? The 15mm seem to be very affordable and gets good reveiws here.
Or should I for a 2.8 in this area just go with the 16-35 zoom?
Edited by johnastovall on Dec 31, 2005 at 04:33 PM GMT
Dec 31, 2005 at 04:15 PM
mfoto
p.1 #2 · Canon Lenses at the Wide end?
the 16-35 would certainly nail the whole range in one POW and you could sell your 17-40... I had the 17-40... upgraded to the 16-35 and is is better but not "miles" better... the 2.8 f stop is really handy in many situations and I'm nailing way more shots with the 16-35 than I did with the 17-40. The extra 1mm is a lot on the 20D. May not make such a huge difference on a 5D
Dec 31, 2005 at 05:25 PM
khiromu
p.1 #3 · Canon Lenses at the Wide end?
To me in that range, I don't need anything faster than f/2.8. (actually I am happy with f/4) So I would go with 16-35 if your 17-40 is not good enough. Or maybe you can try some non-canon glasses, but I am not familiar with those lenses, so cannot comment on that...
Dec 31, 2005 at 05:37 PM
Michael-M
[X]
p.1 #4 · Canon Lenses at the Wide end?
BINGO.....nailing more shots with AF is what drove me to the 16-35, as well as it's excellent resolution and ability to be used in low light without flash..........when i first read that the 20D uses a higher sensetivity AF with f/2.8 or faster lenses i thought "yeah $$$$$ right" but having switched to all f/2.8 zooms, i can honestly say yes it does happen that way......my 17-40 was giving me some mishits with lowlight shots (even though i used flash), but i have not had one miss with the 16-35. the wide end is not edge to edge sharp when shot at f/2.8 of a landscape scene, but for using in this way in low light you'll be amazed........for all else, the 16-35 is proving to be more useful and quite sharp for covering all the 16-35mm needs.
Dec 31, 2005 at 05:49 PM
