Archive 2005 · 24-70L or 24-105L on 1DmkII
1banger
p.1 #1 · 24-70L or 24-105L on 1DmkII
I shoot a 1DmkII and will be getting either the 24-70L or 24-105L for my main
walk about lens.
Try to get some feel from others with either of these setups. I want the 24-105L for the IS and lighter weight. The difference between the 70 and 105 is not that important to me. I have a 70-200L IS, and it will be in my backpack if needed. I have read that the 24-105L
has more distortion than the 24-70L at wider angles. Is it really that noticable?
Also, with a 1D series camera, I know I will be getting both horizontal and vertical focusing points with the 24-70L because of the f/2.8 max aperture. This will give more accurate focusing than the 24-105L which is f/4.0
Thanks.
Dec 31, 2005 at 04:13 PM
rsg_1
p.1 #2 · 24-70L or 24-105L on 1DmkII
If you do a lot of indoor shots, like weddings or functions, then IS can't make up for the extra 1.2 stops on 24-70, no matter what anyone says. If your mostly outdoors, then the extra 35mm focal length will serve you better and the f4 should suffice on 24-105.
Dec 31, 2005 at 04:19 PM
Hrow
p.1 #3 · 24-70L or 24-105L on 1DmkII
Had both lenses and decided to keep the 24-70. The 24-105 has lots of desirable features but the 24-70 was just too much better to give up for the convenience. May try another copy at some point but wasn't that impressed for the price of the 24-105.
Dec 31, 2005 at 04:51 PM
AGeoJO
p.1 #4 · 24-70L or 24-105L on 1DmkII
I feel the same way after playing with it for a few days. I wish Canon would just updated the 24-70 and made it a 24-85mm f/2.8 IS. Had they done it though, it would have crashed the market of the 24-70 since most 24-70mm users would have switched. Not a smart marketing strategy on their part, so they came up with a 24-105 f/4.0 IS. Oh, well.
Dec 31, 2005 at 05:15 PM
CMOS
p.1 #5 · 24-70L or 24-105L on 1DmkII
rsg_1 wrote:
...then IS can't make up for the extra 1.2 stops on 24-70,..
I assume that's the egg nog talking
The 24-105 is an f/4 lens and the 24-70 is a f/2.8. They are exactly "1.0" stop apart, so the 24-70 lets in exactly twice as much light at any given focal length.
Because we are talking about the area of a disc and the area does not scale linearly with diameter, full stops are at f/1.0 1.4 2.0 2.8 4 5.6 8 11 16 and 22
http://www.uscoles.com/fstop.htm
Dec 31, 2005 at 05:17 PM
RGS65
p.1 #6 · 24-70L or 24-105L on 1DmkII
Actually not. Read the thread a few days ago re: the 24-105 here: https://www.fredmiranda.com/forum/topic/329976#2802311 It actually performs more like an f 4-5.6 lens. Its light transmittance is lousy apparently according to that thread. Many folks tested and were losing a lot more than one stop.
Dec 31, 2005 at 07:13 PM
jfulton
p.1 #7 · 24-70L or 24-105L on 1DmkII
Have both and love both for obvious reasons. On my 1DmkII, however, the 24-70L practically lives on it. It acually balances well on the 1-series. There is a noticable difference in weight. If I were going on a hike, the 24-70L would stay home. If I were on a paying gig, the 24-70L would be in the bag. I was going to replace the 24-70L with the 24-105L, but I simply can't. The difference between f/2.8 and f/4 may not seem like much, but in situations when the extra shutter speed means freezing necessary motion, the IS won't do it alone.
Dec 31, 2005 at 07:56 PM
Bobster2
p.1 #8 · 24-70L or 24-105L on 1DmkII
You need to read the entire thread. It turned out to be a metering issue, not a lens problem.
Dec 31, 2005 at 09:56 PM
rd4tile
p.1 #9 · 24-70L or 24-105L on 1DmkII
This thread over at Galbraith kind of established that as well:
http://forums.robgalbraith.com/showflat.php?Cat=0&Number=390450&an=0&page=1&gonew=1#UNREAD
Dec 31, 2005 at 10:13 PM
jmaio
p.1 #10 · 24-70L or 24-105L on 1DmkII
I bought the 24 - 70L f/2.8 just for that last part - - f/2.8!
I just don't see the logic of adding IS to a "slow" lens just so you can talk yourself into thinking you have a "fast" lens. If you do any available light photography at all, you will not regret going for the faster glass.
Just my opinion.
Jan 01, 2006 at 01:21 AM
RGS65
p.1 #11 · 24-70L or 24-105L on 1DmkII
I read the whole thread and I am not sure what you mean by a metering issue. If the camera/lens "metering issue" results in more than one stop slower who cares what is causing it? What am I missing? Enlighten me? I really want to understand this since I seriously considered the lens, but I really need the speed of the 2.8. If I can get a shot on my 24-70L at f2.8 at 1/60 sec, what will the 24-105L f4 give me? 1/30? 1/15? Wasn't the end result that some lenses were taking shots more than one stop slower?
Jan 01, 2006 at 03:13 PM
Chris Dees
p.1 #12 · 24-70L or 24-105L on 1DmkII
I'm planning to get the 24-105, but I won't sell my 24-70.
Like others already said, the F2.8 can't be replaced by IS.
I'm going to use the 24-105 for travel, together with the 100-400.
Jan 01, 2006 at 03:30 PM
rd4tile
p.1 #13 · 24-70L or 24-105L on 1DmkII
I guess it would depend on whether you're completely trusting the meter or checking your exposures via the histogram/LCD image. Everyone of my lenses behaves a bit differently and you just learn whether to dial in a little compensation or not. In fact with one of my MF lenses I have to dial in a stop and a half of extra exposure at small apertures because it fools the metering that badly. I always found the Tamron 28-75 metered a little "brighter" then either the 24-70 or now the 24-105. End result if I didn't compensate shots tended to be a bit underexposed if left up to the camera. If you expose to the right as a matter of principle a lens that meters like the 24-105 could actually be doing you a favor.
Jan 01, 2006 at 08:23 PM
Bobster2
p.1 #14 · 24-70L or 24-105L on 1DmkII
I did my initial "testing" by putting the lenses on the camera and reading the meter. That was not a valid test. When I set the camera to manual mode and shot actual pictures with identical shutter speeds and apertures with different lenses, there was very little difference in the image histograms.
I believe the actual images tell the real story. For some reason, the meter needs to have different exposure compensation for different lenses.
Jan 01, 2006 at 08:37 PM
RGS65
p.1 #15 · 24-70L or 24-105L on 1DmkII
Thank you Rich. Great explanation. So the fix is the learn what your lens needs and dial in as necessary? For example, I shoot available light and f 2.8 or lower a lot. I should see how my lens performs and keep a mental note in my head and dial in compensation accordingly as a general rule? I can't afford to check the histogram after every shot.
Rob
Jan 01, 2006 at 09:34 PM
RGS65
p.1 #16 · 24-70L or 24-105L on 1DmkII
Thank you again for the explanation. This is quite helpful. But I do not like not trusting my meter. I shoot on aperture priority a lot. What you are telling me is that the camera is shooting at a slower shutter speed than it needs to right? That on these particular lenses when my meter says I need 1/30th and I let it do that on AV mode, I may be able to actually get away with 1/60 if I do it manually? It seems I need to shoot more on manual to resolve this assuming I have a lens that fools the meter like this?
Jan 01, 2006 at 09:37 PM
rd4tile
p.1 #17 · 24-70L or 24-105L on 1DmkII
I'm just in the habit of taking a shot and looking at the histogram and usually bumping the EC a bit depending on what I see and then I just shoot away until the scene or lighting changes. Since I'm usually shooting RAW I don't stress too much over it though.
Two of the reasons I like the 24-105 so much is it reminds me of the 17-40 and 17-85 which were my favorite lenses on the 20D and with the high ISO performance of the 5D I find I'm just not needing f2.8 enough to worry about having it. I used to stress going over ISO800 on the 20D and now I'll dial up a 1000, 1250 or 1600 on the 5D without too much trepidation. Plus IS really helps for much of my shooting in this range. I know you're on the fence about the 24-105 and having the 24-70 just makes it tougher because you know you're not going to see any huge IQ improvement by switching. To be honest if the 24-105 didn't have IS I would tell you not to even bother with it.
Jan 01, 2006 at 10:01 PM
herion
p.1 #18 · 24-70L or 24-105L on 1DmkII
As you can see in my sig, I have the 28-70 and the 24-105. Both are superb lenses and each has it's own niche. The 28-70 lives on my backup 300d and the 24-105 is my main 20D lens, along with my 70-300 and 10-20. If I were doing some low-light ambient shooting, I'd take the 28-70 along instead of the 24-105 and avoid caffeine for the day
Jan 01, 2006 at 11:46 PM
