burner Offline Image Upload: Off
I recently switched to Nikon, so I'll give you my perspective. Yes, the D2X is lighter than the Canon 1 series. There are fewer AF points on the Nikon, but they are laid out at the rule of thirds, whereas the 1 series are grouped in the middle. While the Canon's have 45 points, the Nikon has a lot more cross point sensors. I am still getting used to the Cam 2000 on the Nikon, but overall I think it has more options than Canon's. You can set it to all sensors in servo (continous mode), or choose from 2 groups.
The Canon will have better high iso noise hands down. The D2X is usable at 1600 with noise ninja, but not at 3200 IMHO.
Lenses are pretty much equal from 28 to 200 mm. The Nikons are better in the wide, and the Canons have the lead with IS in all the big guns. Nikon does make a couple of lenses Canon doesn't (200 f2.0 VR and 200-400 f4 VR), but the Canon's lead in tilt and shifts.
Ergonomics are all a matter of taste. It is also the reason I switched to Nikon. I much prefer Nikons approach to camera layout, but your mileage may vary. If you switch to a 5D, the layout is pretty much the same, so it shouldn't be an issue for you to get used to. If you are contemplating switching to a 1 series, I would try to find one to rent or borrow to see if you like the ergonomics. It was the deal braker for me, as the 3 button/wheel combo was not to my liking.
In the end, either system is capable of taking better photos than the average photographer is capable of taking. It's all a matter of finding a system you like.
Edited on Nov 29, 2005 at 03:27 AM
