sl1200mk4 Offline Image Upload: Off
p.1 #3 · New Nikon Flash System | |
Actually you can attach 8 of them to a ring. I actually thought about doing that and have instant portable ring flash for portraits on location.
Together with a SB-600 and another SB-800 I will have a very flexible location light kit. Imagine having 4 of those small things on each side for the backdrop (I recken that I can make do with 8 of them), or use 2 of those as the hair light, or have multiple flashes as fill from different angles at different locations.
But it uses CR123A, and I have not seen rechargeable ones around. I know they supposely exist, but if you have 8 of those suckers, you better have a good solution for the battery.
It is certainlly a very pricey solution (if you buy 8 of them). I might get 4 of them and give them a try. If they don't work out for me then I will return them and get myself a 17-55 f2.8.
