Doug Morgan Offline Upload & Sell: On
p.1 #23 · Hartblei TS lenses on Canon | |
Diane:
That's the same lens I ordered and it DOES require an adapter. It is a medium format lens. The adapters are cheap and as I noted above you don't need a shifting adapter. You need to specify the mount on the lens (Mamiya 645, Pentax 645, Pentacon 6, etc) and then also order an adapter that goes from your chosen MF mount to Canon EOS. I picked pentacon 6 for 2 reasons --> one is that it is the only mount usable with the cheap shift adapter and, two, because the P6 mount can be adapted to the Pentax or Mamiya mounts.
The medium format lens has a larger image circle and in theory at least could provide good results using it on a 35mm camera as the smaller size would keep the image in the sweet spot, even at maximum shift.
For the prices look on ebay first -- I was charged the ebay price though I called them direct and was instructed to order through the regular website (it didn't make sense at the time either). Kiev either doesn't update the website very often or the prices are rather variable. I am supposed to pay (they haven't charged VISA yet) 599 (US$) for the lens. EBAY link:
http://cgi.ebay.com/HARTBLEI-45mm-F3-5-Super-Rotator-Kiev-88-CM-Kiev-60-P6_W0QQitemZ7627356152QQihZ017QQcategoryZ710QQcmdZViewItem
If you aren't going to use the lens for panoramas (with lots of shift) and don't require both shift and rise (for architectural panoramas) you may very well be happier with the Canon TSE lens. I was comparing more to the 24mm TSE which just wasn't going to do it. The Canon 45mm (and 90) TSE's are reputedly much sharper than the 24 and appear to have much less distortion. The Canon's come up used quite often on the buy and sell forum.
Doug
Edited by Doug Morgan on Jun 26, 2006 at 07:36 AM GMT
