Archive 2005 · SB800 and Pocket Wizards
andylaiphoto
p.1 #1 · SB800 and Pocket Wizards
Is there a cord to connect the two?
Oct 13, 2005 at 06:10 PM
tazo
[X]
p.1 #2 · SB800 and Pocket Wizards
Yes..
I think it is Pocketwizard to mini-pc? is that logical sounding? i know you connect the PW cable to the PC sync on the sb800.
daniel
Oct 14, 2005 at 03:33 AM
localandbitter
p.1 #3 · SB800 and Pocket Wizards
Pocket wizards, at least the multi-maxes, come with a miniphone - to - pc sync cord in the box that you can use to connect to the SB-800 flash's built in pc-sync port. You probably need to be in SU-4 mode to get it to trigger on the pc-sync port -- I have not tried that in other modes.
Oct 14, 2005 at 05:06 AM
sonm1
p.1 #4 · SB800 and Pocket Wizards
Yes, the multi-Max comes with a mini-phone to PC (male) cord (6").
How did you want to connect the pocketwizards? As a receiver, I presume. The cord fromt the pocketwizard goes into the PC (female) sync located at the side of the flash.
Similarly, as a tranmitter it can be connected to the same PC sync on the flash as well.
The flash does not have to be in SU-4 mode to trigger. Usually, I set it in manual power output. That is usually the only mode it can work when mixing with Pocketwizards.
Oct 14, 2005 at 10:44 PM
andylaiphoto
p.1 #5 · SB800 and Pocket Wizards
Thanks guys
Oct 15, 2005 at 02:32 AM
