Today i found out my d2h doesn't focus right! That is...It does focus and it seems quit alright but if i take a closer look thrue the fiewfinder It doesn't seem spot on sharp. If i focus manualy (after aoutofocussing) i am able to make the image appear sharper in the viewfinder...
It could be that the image is sharp and the problem exists only in the fiewfinder or...
Has your D2h been in to Nikon for servicing of the metering problem? Sometimes it is associated with AF problems as well. So this could be an indicator that the meter is about to fail.
It hasn't been back to nikon... what do you meen with metering problem... is that light meteringproblem? does it appear often, does nikon repair this kind of faults for free or can i expect a huge bill if i send it in?
The D2h has a known fault with the light meter. Nikon has admitted that it is a known problem and will fix it for free. The basic symptoms are that the meter will read way off. Some people also experienced weird AF problems at the same time. Search this (and almost any other Nikon DSLR forum) for "D2h" and "meter" and you'll find lots of posts.
My problem was way easyer.. When i picked up my camera this morning the problem of misfocusing was much bigger than yesterday...
I noticed the focusmetering from camera was ok. If i focused manualy my pictures came out blury... Ik had to be something in the viewfinder.... ik was simple, the mat-glas (is that english??) wasn't fixed in the uppermost position. A little push from my finger solved the problem.
