mdude85 Offline Dedicated FM Upload & Sell: Off
Hi -- I am traveling around Europe now -- I chose to simply bring a small Canon point and shoot instead of my entire rig, but I also am traveling with a friend who brought his entire rig -- 20D + 70-200 f4 + 17-40 + 50 1.4 + tripod + accessories. He takes it almost everywhere he goes The only problem I forsee with getting the 70-200 f4 is the weight. In Europe you will be walking a LOT, and carrying around all your gear with you is probably a bit tiring. If you want a telephoto, I would choose the lightest and smallest option you can, and if I were you, I'd go with something that is decently fast (but doesn't need to be f2.8 or anything). Many of your shots are going to be handheld. Depending on if you're travelling with friends or alone, you may not have time to set up your tripod inside of a cathedral or on the street (but then again there will be times when you can use a tripod).
If you want to know the truth, there is quite frankly not too much of a need for a telephoto while in Europe, IMO. I mostly use wide angle to get landscapes and street scenes, and a 50 mm is a decent choice for capturing people and faces. A 70-200 might be good if you are far away from the action, and my friend uses it a lot.
I don't think you need a new wide angle. The 18-55 is going to be fine. Good wide angle lenses are overrated, and I feel you can achieve sharp results with cheap wide angles. They don't need to be as sharp wide open as other lenses, especially since much of the time you want to stop down to increase depth of field. And, I have seen the 18-55 compared to the 17-40 and there isn't much of a difference. For wide angle, my point and shoot gets results similar to a 17-40.
As for a telephoto, The 70-200 f/4 might be a good choice, but I don't think you need anything past 200 mm. You might want to get a wider lens than 70...maybe 28-200, so you don't have to switch lenses so much between your wide angle and telephoto. It will probably get annoying and you might miss fleeting moments.
Good luck!
