Archive 2005 · sensor cleaning - Kinetronics products
Imagemaster
p.1 #1 · sensor cleaning - Kinetronics products
www.kinetronics.com
Has anyone used their SpeckGRABBER or Anti-static brushes? Their products seem similar to Visibile Dust products, only at a less expensive price.
Tony
Mar 21, 2005 at 08:16 PM
HinduG
p.1 #2 · sensor cleaning - Kinetronics products
http://194.100.88.243/petteri/pont/How_to/a_Brush_Your_Sensor/a_Brush_Your_Sensor.html
Summary: Highly likely that Visible Dust Products nothing more than nylon brushes...
Mar 21, 2005 at 08:31 PM
Larry Carter
p.1 #3 · sensor cleaning - Kinetronics products
I have a sneaky feeling those Visible Dust brushes are nothing more than white nylon (acrylic paint brushes) soft flat and fan brushes. By blowing air over nylon hairs it creates a static charge to pick up dust. And only less than 5.00 a brush for high quality brushes, too. I'm going to test it out.
Mar 21, 2005 at 08:46 PM
nutek
p.1 #4 · sensor cleaning - Kinetronics products
I don't recommend. I have their Outdoors Photographer's Optics First Aid Kit.
Their "Tiger" cloth is no more than a standard spectacles-cleaning cloth, and does not absorb oil well at all. It ended up smearing more oil onto the glass than removing them.
The speckgrabber might be good for getting large, visible specks of dust off the sensor or glass, but if you're going to dabbing the sensor for all the sub-visible dust-spots, you might be better off using the Copperhill method or the SensorBrush. I dabbed my sensor a little too hard, and it did leave a bluish residue/mark which could be clearly seen by the eye.
The antistatic brush is usable but is not meant for use on the sensor.
The cleaning fluid looks ok. I have the Eclipse fluid too, and both perform similarly.
Mar 21, 2005 at 08:55 PM
UFO™
p.1 #5 · sensor cleaning - Kinetronics products
Very interesting read. Time to shop for artist brushes.
Mar 21, 2005 at 09:37 PM
Imagemaster
p.1 #6 · sensor cleaning - Kinetronics products
Thanks Alan for that link.
I think I will give the Antistatic Foam Over Cotton Swabs with and/or without a solution of 50% isopropyl alcohol and 50% water.
http://www.mgchemicals.com/products/swabs.html
Mar 21, 2005 at 09:50 PM
azurephoto
[X]
p.1 #7 · sensor cleaning - Kinetronics products
I use what I'm suprised more people don't - an electroic mini-vaccum, used to clean out keyoard gunk....eliminates dust pronto!
Mar 21, 2005 at 10:22 PM
gfiksel
p.1 #8 · sensor cleaning - Kinetronics products
Which one? Do you have a link?
Mar 21, 2005 at 10:26 PM
azurephoto
[X]
p.1 #9 · sensor cleaning - Kinetronics products
http://www.bestbuy.ca/catalog/proddetail.asp?logon=&langid=EN&dept=0&sku_id=0926INGFS10016953&catid=&newdeptid=20007# though I made my own smaller 'nook' tool.
Mar 21, 2005 at 10:33 PM
Bob Bell
p.1 #10 · sensor cleaning - Kinetronics products
I have a speckgrabber and have used it a few times. It can leave more marks than you started with if you dont clean it super well. The only thing is you kind of need to map out where the dust is to grab it and that is kind of annoying. But I would pay the 3 bux to buy one if I had to again.
Mar 21, 2005 at 10:38 PM
Canon 10D
p.1 #11 · sensor cleaning - Kinetronics products
Swiffer Dusters does it all
U have to try it, and u will know what I mean. This thing is really a dust magnet.
http://www.homemadesimple.com/swiffer/usenglish/products/dusters.shtml
Disclaimer: May cause severe "Wow!!!"
Mar 22, 2005 at 12:37 AM
andrew_rs
p.1 #12 · sensor cleaning - Kinetronics products
Yes, very interesting indeed
Mar 22, 2005 at 12:43 AM
