Archive 2005 · My Canon 24-70 is a dud!!!!
Brandon Mizar
p.1 #1 · My Canon 24-70 is a dud!!!!
Ok I shot all of these shots with my 1D Mark II @ f/3.5, 1/125, ISO400
My focus was aimed center focal point at the bullet marks on the 2nd paragraph closest to the edge of the box.
24mm
35mm
70mm
Anything that I shoot at 24mm is out of focus. 70mm appears to be the only focal length where anything will be in focus. Can Canon fix this or should I just exchange it for a new one. I just bought it off the boards and the guy bought it brand new for the UPC rebate. Should I send my camera in and have them calibrated or should I just get a new lens?
I shot the same camera with a 17-40mm and it worked perfect. So I know its not the camera.
Feb 14, 2005 at 07:56 PM
RushMan
p.1 #2 · My Canon 24-70 is a dud!!!!
https://www.fredmiranda.com/forum/topic/183917
I'll know Wed how it all works out.
If you're in no hurry, I'd send it in. If it's warranty repair, it should be at no charge [pending the verification of no water damage, drops, etc].
If you want to just replace it, I have 1st dibbs on buying that old one from you
Feb 14, 2005 at 08:01 PM
The Image
p.1 #3 · My Canon 24-70 is a dud!!!!
exchange it if you still got time.
Feb 14, 2005 at 08:14 PM
Malcolm Stitt
p.1 #4 · My Canon 24-70 is a dud!!!!
If the guy send in the upc, then it has to be sent in under his name. Work it out with him as to where to ship it to. Hopefully you can ship it to his name/Care of you/ at your address.
It is really worth sending it in and waiting about 10 days for calibration. I did that with 5 of my lenses and all are right on. It sure beats the return and test cycle.
You don't need to send it in with your camera, unless you suspect that the camera is off too. They calibrate them seperately.
One other thing. When you send lenses in with a new camera they seem to do a complimentry check /calibration on all of the lenses. Not sure if this is always the case, but they did it for me. Some of mine were out of warrantee.
Edited by Malcolm Stitt on Feb 14, 2005 at 08:40 PM GMT
Feb 14, 2005 at 08:39 PM
kalieaire
p.1 #5 · My Canon 24-70 is a dud!!!!
how far did you aim the shot from?
Malcolm Stitt
p.1 #6 · My Canon 24-70 is a dud!!!!
What was the angle of that box? It looks more than 45 degrees. Also, the light grey print is prety low on contrast against the white background.
Before you tried the angled test, did it pass a shot against a same plane object?
Feb 14, 2005 at 08:41 PM
Brandon Mizar
p.1 #7 · My Canon 24-70 is a dud!!!!
The shot is from about 4 feet away. I tried it against flat surfaces as well. I took it outdoors and shot a few shots as well. Every shot at 24 up to 68mm is waaaay out of focus. 70mm appears to work ok. I took a shot of my office and aimed at a chair from about 10 feet away and at 24mm on up every single thing in the picture was out of focus. I took the same shot at 70mm and the wall was in focus behind the chair. It is definately a bad copy. My 17-40 that I just sold on here was spot on.
Feb 14, 2005 at 08:55 PM
braindeadmac
p.1 #8 · My Canon 24-70 is a dud!!!!
It's my personal belief that this is caused by the video card used in your Mac. This is a well known bug in OS X which causes all 24-70 tagged images processed with a G5 having a NVIDIA 6800 video card to become defocussed. You should therefore send your video card (you can keep the G5) to me.
Seriously, I would send it back for return if you are able, otherwise, back to Canon.
Feb 14, 2005 at 09:38 PM
RJJR
p.1 #9 · My Canon 24-70 is a dud!!!!
My 24-70 was also a dud. My 17-85 and 28-135 are considerably sharper at all tested focal lengths, even at 5.6 - 11. I returned it and the shop is getting in another I'll try. If that's also a dud I'm done with it.
Feb 14, 2005 at 11:11 PM
trijicon
[X]
p.1 #10 · My Canon 24-70 is a dud!!!!
Did you get the 30" monitor for the DDL?
Feb 15, 2005 at 12:52 AM
jtorral
[X]
p.1 #11 · My Canon 24-70 is a dud!!!!
Manual Focus. The old fashion way.
I would exchange it.
Feb 15, 2005 at 01:35 AM
Brandon Mizar
p.1 #12 · My Canon 24-70 is a dud!!!!
I just tested the lens on a Digi Rebel and at 70mm it is spot on. 35mm just a hair off but at 24mm it front focuses instead of back focuses.
Weird stuff.
Feb 15, 2005 at 12:57 PM
Brandon Mizar
p.1 #13 · My Canon 24-70 is a dud!!!!
Hey Rushman did you get your lens back yet? How is it working?
Feb 17, 2005 at 02:57 PM
RJJR
p.1 #14 · My Canon 24-70 is a dud!!!!
I just picked up my second 24-70 form the store and gave it the same test I did previously comparing it against my 17-85 and 28-128.
I'm happy to say that this 24-70 is considerably better than the last one. The focus is much better and the action of both the zoom and focus rings even feel smoother. I'll shoot around with it a few days before I decide to keep it. That last one has me spooked but good.
Feb 17, 2005 at 04:13 PM
RushMan
p.1 #15 · My Canon 24-70 is a dud!!!!
Canon required a signature so they didn't leave it yesterday. I picked it up today but just got home from work... and on my way out the door with the kids for a school event.
I'll break it out Saturday at one of my sons soccer games - and cross my fingers
update:
I just took one shot with it. Indoors, crappy lighting.. it's awsome!!! weeeeeeeeeee
Now I'm pumped for Saturday!! [although it's supposed to rain.. hmm]
Feb 17, 2005 at 06:31 PM
Brandon Mizar
p.1 #16 · My Canon 24-70 is a dud!!!!
Good to hear that it is working good. I cannot wait to get mine back. I hate not having a camera.
Feb 18, 2005 at 04:08 PM
RJJR
p.1 #17 · My Canon 24-70 is a dud!!!!
I shot around with my second 24-70 and though it's considerably better than the last one I had it's still not knocking my socks off so I did more rigorous focus testing using 24, 28, 35, 50 and 70mm at f2.8, 4, 5.6, 8, and 11 I found it back focuses from 24 to 50 but at 28 oddly enough it hardly focuses at all and I have to focus manually. The only spot it's decent is at 70mm, there it's darn near perfect.
Since I've had no issues like this with my other lenses I decided I wasn't going to bother with the 24-70 and returned it, swapping it for a 100-400 f4.5-5.6L (the next lens on my wish list).
Feb 18, 2005 at 04:51 PM
Brandon Mizar
p.1 #18 · My Canon 24-70 is a dud!!!!
Ok that is exactly what mine was doing. 70mm is what perfect and anything below that was way backfocused. I pray mine comes back good.
Feb 18, 2005 at 05:31 PM
TonyKaz
[X]
p.1 #19 · My Canon 24-70 is a dud!!!!
I am curious, is this a USA version of the lens? I know your next ? is why, because i went through 3 USA versions of that lens before they had no more USA versions and sent me the cheaper Non USA version which was dead balls on accurate. Then i went through the same thing with the 16-35L but 2 copies of that were terrible, told them to send me the Non USA Version and bingo another dead balls on hit, i will never buy another Canon made USA lens again. JMO
Feb 18, 2005 at 06:15 PM
Brandon Mizar
p.1 #20 · My Canon 24-70 is a dud!!!!
Yes mine is a US version. That is very weird that the gray market lenses have been better.
Feb 18, 2005 at 06:49 PM
