Archive 2004 · Cleaning Sensor
Softechie
[X]
p.1 #1 · Cleaning Sensor
I've found some unwanted soft grey spots against clear sky on my photos and lens is clean. It's about time for me to clean the sensor. This will be my first. Got any advice on what to use and what to do? TIA.
Nov 13, 2004 at 12:16 PM
alanS
p.1 #2 · Cleaning Sensor
check this out
http://www.pbase.com/copperhill/ccd_cleaning
Nov 13, 2004 at 12:20 PM
john Lee
p.1 #3 · Cleaning Sensor
My advice - first, do exactly as it says in your instruction book. I found that cleans off most of the dust spots..... check against new image pointed at light object, with the lens stopped down fully. Its worth trying before probing deep into your camera..... thats my advice.... best regards john Bristol UK
Nov 13, 2004 at 12:25 PM
kansashoops
p.1 #4 · Cleaning Sensor
I'm buying the stuff reviewed here:
http://www.robgalbraith.com/bins/content_page.asp?cid=7-6460-7296
Nov 13, 2004 at 01:25 PM
alanS
p.1 #5 · Cleaning Sensor
I purchased my 10D at best buy with an extended service plan. When the sensor needed cleaning I brought it in. Long story short the gave me a new one. I am waiting for them to run out of 10D's, then I hope to have themgive a service my 10D to a 20D.
Nov 13, 2004 at 01:30 PM
Tom Buerk
p.1 #6 · Cleaning Sensor
Cleaning your sensor is easier than returning a camera to circuit city. I just did it for the first time and if you follow the copperhill instructions you will be blown away by how easy it is.
It took me three swipes but now its cleaner than new. Its really as easy as changing a roll of film.
Nov 13, 2004 at 02:30 PM
intero
p.1 #7 · Cleaning Sensor
Copperhill - without a doubt!
My 10D was used, though very lightly when I got it, it had been sitting around for a while, and there was some serious dust on the sensor. I didn't know this, and shot way. Such a noob.
Well, my sky shots were littered with junk. To Google I went.
Bought a $3 spatula, cut it down, bought some Eclipse (it comes with 10 Pec Pads) and went to town.
Had to go through the procedure 4 times to get the stubborn stuff off, but wow, what a difference! During the process I got very comfortable with it, and now wouldn't hesitate to do it on my 20D (I just won't wait as long).
Do yourself a favor, clean the lens with a method that gets the dirt out, not just blows it around so the next time the sensor has any charge on it, all the dust jumps back onto it!
Of course, your milage may vary.
-Tom
Nov 13, 2004 at 03:06 PM
lexvo
p.1 #8 · Cleaning Sensor
I second the copperhill method. I bought the Eclipse fluid and the sensor swabs. After one or two cleanings, it is really easy and only takes a few minutes to clean the sensor.
Nov 13, 2004 at 05:27 PM
Lars Johnsson
p.1 #9 · Cleaning Sensor
Before you try anything else just use a bulb blower the first time.
Nov 13, 2004 at 05:39 PM
Softechie
[X]
p.1 #10 · Cleaning Sensor
Thanks everyone. I will heed your suggestions.
Nov 13, 2004 at 10:32 PM
nutek
p.1 #11 · Cleaning Sensor
After any cleaning method, put the camera into burst mode and fire away some shots at your highest framerate. If you only take a single shot after checking, you might not see any dust jumping back to the sensor, but after a series of fast shutter movement, you'll see more. Then clean again
Nov 14, 2004 at 12:03 AM
Softechie
[X]
p.1 #12 · Cleaning Sensor
OK! Finally I'm done and it's 99% clean. Only one very very tiny spot in the corner. I'm counting my blessing for now.
Nov 14, 2004 at 04:12 PM
intero
p.1 #13 · Cleaning Sensor
Well, method did you use?
-Tom
Nov 14, 2004 at 05:11 PM
Softechie
[X]
p.1 #14 · Cleaning Sensor
Method 1: Using bulb blower. That didn't work. It just rearranged the dirt.
Method 2: Wiping sensor. Used cut-off plastic knife and lens paper. No solution applied. Wrapped lens cleaning paper around the cut-off knife. Wiped the sensor couple of times.
I had to wipe at least 2 times to get 99% of dirt out.
Nov 14, 2004 at 09:00 PM
alanS
p.1 #15 · Cleaning Sensor
very brave!
Nov 14, 2004 at 11:07 PM
