       2       3              54       55       end
Archive 2016 · Techart PRO LM-EA7 FAQ
genji
p.1 #1 · Techart PRO LM-EA7 FAQ
This is our Techart PRO FAQ. Corrections and suggestions for additional topics are welcome. Please post them in this thread and I will update the FAQ accordingly.
TechArt PRO is available from the below vendors:
Adorama | B&H Photo | Amazon
What is the Techart PRO?
The Techart PRO adapter (abbreviated as "TAP") is an autofocus adapter for manual focus camera lenses when mounted on certain Sony mirrorless cameras. According to the Techart PRO website:
[The TAP] is basically a lens adapter with a motor and a printed circuit board, allowing the camera to measure the focus and communicate with the motor, [which] will move the lens closer or further away from the camera sensor to reach the focal point. The principle is similar to the Contax AX camera in that the flange distance is adjusted to reach the focus. The maximum z-shift is 4.5mm which is sufficient to cover the focusing distance for most of the lenses. And the optical performance will NOT be affected for unit focusing lenses.
Controversy regarding the Fotodiox Pro Pronto
A Techart representative has claimed that the Fotodiox Pro Pronto is an unlicensed fake of Techart's patented design. However research by FM member, Aerocolor, reveals that while Techart has applied for a patent for the Techart Pro, they do not appear to have been granted one. Therefore, although the Fotodiox Pro Pronto (in Aerocolor’s words) “bears all the markings of a shameless knockoff clone”, it is not illegal for Fotodiox to offer the Pronto for sale. Aerocolor’s extensive explanation of the issues, complete with extensive references, can be read in this post.
Problems encountered with the Techart PRO
1. Loose screws
FM member DavidBM reported (and other members confirmed) that the screws on the camera mount plate had become loose.
With a lens mounted on the camera, the whole TechArt system was wobbling on the camera!
Eventually I realised that the TechArt's camera mount plate - the one that's like the mount on a lens - was loose.
Tightening the four tiny screws with a 1.4mm jeweller's screwdriver bought it back to normal! It was wobbling badly, and if it had come off, might have been hard to get back (especially if the screws were lost).
In this case, the fix is to check for loose screws and to tighten them.
2. The TAP wobble
Fred Miranda described a design flaw that results in the TAP developing a "wobble". This is unrelated to the wobble caused by loose screws described above and there is no fix for it.
However, as others have reported on this and other threads, there is design flaw that needs to be addressed by TechArt.
The issue is how the 'lens carrier' (the section that moves in and out) was designed. It will develop a wobble after a while because its top area it's not supported at all!
The heavier the lens, the faster it will wobble but it's an issue even if only using light lenses.
Point in case: I have tried three brand new adapters and used them solely with two lenses: Zeiss 50/1.5C and Zeiss 35/1.4. The latter is only about 380g. Within a
2. The TAP becomes jammed on the camera body
This issue is a more serious variant of the first problem listed. FM member Kressouille reported that he initially encountered the wobble but it became progressively more extreme until finally he was unable to remove the TAP from his A7R II. He was still able to remove the lens from the TAP but the TAP would not move when he pressed the lens release button and turned the TAP counter-clockwise. He contacted Techart and they were able to suggest a solution:
"Try to put the camera+adapter upside down (with the monitor of the camera facing the sky). And try to gently pad the camera and adapter so that the connecting pins (which may have mistakenly protrude), will return back the original position. And try to remove the adapter while holding this position."
Finally, when I removed the TAP, there were 3 screws that got unscrewed! I screwed them back, and the wobble disappeared. Then I really encourage the Techart Pro owners to always have a screwdriver on your bag when using this TAP. And if there is a sign of wobble, to check
What are the main features of the Techart PRO?
  1. Leica M Lens to Sony E-Mount Camera
  2. Optimized for Use with A7 II, A7R II, A6300, and A6500 cameras
  3. Shifts Lens up to 4.5mm for Autofocus
  4. Supports PDAF with AF-S & AF-C Modes
  5. Improves Close Focusing Ability
  6. Bluetooth 4.0 Connectivity & Mobile App
  7. Stores 10 Sets of Lens Data
  8. Compatible with 3-Axis Stabilization (pitch, yaw, and roll)
  9. Drives Lenses Weighing up to 700g
Reviews of the Techart PRO
  1. FM member d-intrigue offers a realistic assessment of the Techart PRO
  2. FM member John Leathwick (navmannz) has written a comprehensive review of the Techart PRO (in essence a concisely written distillation of the most important information in this FAQ
Can the Techart PRO be used with any Sony mirrorless camera?
The Techart PRO has been designed to provide optimum performance with Sony cameras that support 3rd party PDAF (Phase Detection Auto Focus):
  1. Sony A7 II
  2. Sony A7R II
  3. Sony A6300
  4. Sony A6500
  5. Sony A9
Techart do not recommend using the TAP with cameras that are CDAF-only or whose on-sensor PDAF works only with native lenses (e.g. the A7, A7R, A7S, and A6000). A number of FM members have reported poor autofocus performance with these cameras.
How does the Techart PRO perform with the Sony A9?
FM member k-h.a.w posted a comprehensive comparison of the Techart PRO performance on the Sony A9 and A7R II models.
Which autofocus features does the Techart PRO support?
  1. Focus Mode: AF-S, AF-C
  2. Focus Area: Wide, Center, Flexible Spot (S/M/L
  3. Smile/Face Detection
Eye AF is not currently supported.
Why does the Techart PRO does not autofocus with my Sony A7 II / A7R II / A6300 camera?
The Techart PRO relies on PDAF (Phase Detection Auto Focus). Check Menu > Custom Settings (Gear Icon) > 7 > AF System and see that Phase Detection AF is selected.
Why is my Techart PRO having difficulty finding focus?
FM member GMPhotography offered a useful tip:
Remember focus is best achieved on vertical lines and not horizontal. Always look for a vertical contrast spot to get the best focus. This really is how Sonys work best.
FM member ecarlino suggested the reason for this:
The Nikon Phase-Detect module with 51 AF points has 15 points that are "cross-type sensors" to be able to detect contrast in both vertical and horizontal lines. I believe these are concentrated in the center of the frame.
I think none of the Sony On-Sensor Phase Detect AF points are "cross-type" and therefore only capable of detecting "vertical" contrast (with the camera in landscape orientation).
I am unsure of the Contrast Detect algorithm, but it's likely that it's reading row by row, left to right so it also is only detecting vertical contrast - but i haven't seen any details on that algo.
FM member k-h.a.w offered a tip for focusing fast lenses more accurately:
For shooting a fast lens, like f/1.2 or f/1.4, wide open I use AF-C and Flexible Spot: S and give it plenty of time (holding the shutter button halfway down) to focus precisely. On the A7r.2 I use IBIS and have selected Phase Detection AF and Phase Detect. Area ON.
FM admin Fred Miranda suggested a tip for using the TAP with slower lenses:
I've noticed that with slower lenses like the ZM 85/4 in low light, it's essential to keep focus on the center of the frame. It works surprisingly well as long as it stays there.
FM member rji2goleez expanded upon Fred Miranda's observation about the position of the AF focus point:
I have found this to be the case with many lenses and not necessarily slow lenses. The further to the edges of the frame the focus point is moved, the slower or more difficult it is to get AF confirmation.
FM member DavidBM confirms rji2goleez's point concerning AF acquisition with faster lenses:
Yes: sometimes very fast ones! I've noticed that the Zuiko 50mm f1.2 is more than usually sensitive to off centre focus point placement, even wide open. I'm guessing it's because the contrast drops off and aberrations increase off axis in a way that fools the focusing. Or even that the angle of incidence of the rays at very fast apertures confuses the PDAF.
Why does the Techart PRO drain my battery so quickly?
The excessive battery usage is a known issue/bug. Fred Miranda suggested a method to stop battery drainage:
Once you store your camera with TAP connected, just remove the battery and insert it back in. I have not found any drainage after doing this for a few days.
That could explain why battery drainage is not consistent and why I never found any drainage when inserting a fresh changed battery.
In a later post Fred elaborated:
If you put a fresh battery and turn the camera off, there will be no drainage.
Alternately, if you have been using the camera and turn it off, drainage will occur UNLESS you remove the battery and re-insert it.
Somehow, physically removing the battery and re-insterting it completely cuts the connection with the adapter when the camera is in "off" position.
Why don't the Techart people answer email messages promptly?
FM member DavidBM provided a credible explanation:
My experience dealing with smaller companies in China and HK is that communication beyond the selling phase is patchy at best. I don't really blame them: they have few staff, and running close to the edge, and they need to find competent English speakers to deal with issues from folks like me that don't write Chinese.
It's not customer service as some of us have come to expect. But I factor it in to my expectations. I've ordered a TechArt and am looking forward to it. But will they be around to provide service and upgrades in a few years, and will
How does the Techart PRO affect image quality?
For unit focusing lenses (i.e. those in which the entire optical assembly moves back and forward as the focusing ring is turned), the TAP does not affect image quality. For lenses with a floating element (FLE) design (i.e. the distance between lens groups is adjusted as the lens is focused in order to improve performance at close range), the TAP will have an effect on image quality. In this case, if using the lens at close distances, it will be preferable to pre-focus manually before allowing the Techart PRO to achieve accurate focus.
FM member freaklikeme elaborates:
I'm not saying it will be particularly impactful for every shooting situation, or that every lens with an FLE will be impacted the same amount. FLEs are implemented differently. Some are like the Canon FD 85L or your Summicron 75, where the rear group remains static while the other groups move, or the Samyang TS 24/3.5, where the rear collection of groups move until about 3M when the front group also starts moving. Some are like the Touit 50 that moves multiple groups at different times in different directions. How tolerant all of those lenses are to extension tubes should vary.
Using the TAP with floating element lenses is discussed at length in this thread.
Will the Techart PRO autofocus over the full focusing range of the lens?
The autofocus range varies with the lens. According to Techart, the focusing ranges with the focus ring on the lens is set to Infinity are:
15mm: 6.5cm –> Infinity
21mm: 12cm –> Infinity
24mm: 15cm –> Infinity
28mm: 20cm –> Infinity
35mm: 31cm –> Infinity
50mm: 60cm –> Infinity
90mm: 1.8m –> Infinity
135mm: 4.2m –> Infinity
Must the focusing ring on the lens always be set at Infinity?
No, the focusing ring on the lens can be set according to the circumstances. FM member k-h.a.w explained in this post how he divides his lenses into groups:
• Normal to WA lenses, simply set the M lens to infinity, typically no pre-focusing required.
• Lenses where the reach of the adapter's helicoid isn't large enough, so pre-focusing is necessary.
• Special lenses, e.g. with floating elements that need to be in the right position, also require pre-focusing.
• Extreme close focus, using the adapter's helicoid to achieve closer distances than possible with a rangefinder camera doesn't require pre-focusing but simply turning the M lens focus to closest distance.
How should I configure my A7 II / A7R II to switch from autofocus to manual focus and back?
Although this can be done via the (Android) configuration app, it is best to assign a Custom Button to do this. Choose Menu > Custom Settings (Gear Icon) > 7 > Custom Key Settings and assign AF/MF Ctrl Toggle to a button. FM member d-intrigue suggested using the Center Button whilst others prefer to use the AF/MF button.
The Techart PRO has a Parking feature which determines what the adapter does when switching from AF to MF mode:
  1. F36 parks the adapter at infinity focus
  2. F40 parks the adapter at closest focus
  3. F45 parks the adapter at the current focus
To implement this, set the aperture on the camera to the desired value, take a picture, then set the aperture on the camera back to F2. (Note that the camera must be set to change aperture in 1/3 stop increments for all of these options to be accessible.)
What is the heaviest lens that can be used with the Techart PRO?
According to the Techart PRO FAQ, the adapter can support lenses "as heavy as 700g". However, multiple FM members have reported success with much heavier lenses as long as the lens is supported firmly with one hand. In other words, instead of holding the camera and allowing the TAP to move the lens back and forward, one holds the lens so that the TAP moves the camera body back and forward.
Does the Techart PRO provide autofocus only with Leica M lenses?
No, other manual focus lenses with a longer flange distance (such as legacy SLR lenses) can also be auto-focused by inserting the appropriate M-mount adapter between the lens and the Techart PRO. For example, Contax C/Y or Olympus OM lenses can gain autofocus by adding a C/Y->M or OM->M adapter respectively.
Are any Leica M lenses incompatible with the Techart PRO?
FM member OpticalFlow reports that the Dual-Range Summicron does not work with the Techart PRO.
When set to infinity, the range finder coupling binds with the adapter. It can only be mounted when set to about 2m. Then, it will focus to about 10 meters with the TAP, but when trying to focus to infinity the rangefinder coupling binds and everything locks up.
Where do I buy the adapters for non-Leica M lenses?
Techart sell a wide range of Leicaist brand adapters in their store. However, the same Leicaist adapters can be purchased at lower prices on eBay.
FM members have reported varying degrees of success with other inexpensive XX->M adapters. In order for it not to interfere with the protruding motor of the Techart PRO, the adapter needs to be quite narrow at the M-bayonet end. The Leicaist adapters are tapered to achieve this.
Do non-Leicaist XX->M adapters also work with the Techart PRO?
According to posts in the Techart PRO AF adapter now In Stock! thread some inexpensive adapters have been reported to work with the TAP. The following list shows all the adapters that are known to work.
Canon EF(EOS)
  1. Leicaist EF->M adapter
Canon FD
  1. Leicaist FD->M adapter [Note that this adapter does NOT support Canon FL-mount lenses. However, FM member bluloo has explained how the FD->M adapter can be physically modified to work with FL lenses.]
Canon FL
  1. FM member HWH7 reported that he successfully used a Canon FL 55/1.2 with the TAP by combining a Canon Lens Mount Converter B with an LTM->M adapter (the Lens Mount Converter B allows FL lenses to be used on L39/M39/LTM mount bodies).
Contax C/Y
  1. Leicaist C/Y->M adapter
  2. K&F CY->M Concept adapter
  3. Fotodiox CY->M adapter
  4. Gobe CY->M adapter
Hexanon AR
  1. Leicaist AR->M adapter
Leica R
  1. Leicaist LR->M adapter
  2. Fotodiox LR->M adapter
  3. K&F LR->M adapter
  4. Novoflex LEM/LER adapter
Minolta MD
  1. Leicaist MD->M adapter
  2. Fotodiox MD->M adapter
  3. Fotasy MD->M adapter
M42
  1. Leicaist M42->M adapter
  2. Fotasy M42->M adapter
  3. Fotodiox M42->M adapter
Nikon F
  1. Leicaist Nikon AI->M adapter
  2. Fotodiox Nik->L/M adapter
  3. K&F Nikon AI->M Concept adapter
Nikon G
  1. Leicaist Nikon G->M adapter [FM member bluloo reports that the aperture adjustment ring "is awkward to grasp when attached to the TAP, and the throw is very short, but it's a workable solution for those with Nikon G glass."]
Olympus OM
  1. Leicaist OM->M adapter
  2. K&F Concept OM->M adapter
Pentax K
  1. Leicaist PK->M adapter
  2. K&F Concept PK->M adapter
  3. Fotodiox PK->M adapter
Rollei QBM
  1. Yeenon QBM->M adapter
How do I attach the Techart PRO and lens?
  1. Turn off the camera and remove the currently mounted lens.
  2. Align the white dot on the Techart PRO with the white dot on the camera's lens mount and rotate the adapter clockwise until it locks into place.
  3. If you are using a legacy SLR lens, attach the XX->M adapter.
  4. Align the red dot on the M-mount lens (or on the XX->M adapter) with the red dot on the Techart PRO and rotate the lens (or adapted SLR lens) clockwise until it locks.
  5. Turn on the camera.
  6. Set the aperture on the camera body to F2.
  7. Set the aperture on the lens to the desired working aperture.
Can I use the Techart PRO with an L-bracket?
Various FM members have reported incompatibility with the TAP and certain L-brackets. The following L-brackets are said not to interfere with the TAP:
  1. L-bracket for Sony A7II / A7RII (USD50.00 from the Techart Store)
  2. RSS L-bracket
  3. LB-A7M2 L-bracket on eBay
  4. Neewer NW-A7M2 L-bracket on eBay
  5. A7IIL L-bracket on eBay
Does SteadyShot (IBIS) work with the Techart PRO?
Yes. There are two ways to approach this:
  1. Configure either three Custom Buttons (or, alternatively, three Function Button options) for SteadyShot Adjust (Auto/Manual), SteadyShot (On/Off), and SteadyS. Focal Len. With SteadyShot (On) and SteadyShot Adjust (Manual), you can then use SteadyS. Focal Len. to set a value from 8mm to 1000mm.
  2. Set SteadyShot Adjust to Auto and set the correct focal length to be recorded by the Techart PRO as explained later in this FAQ.
How do I update the firmware?
The Techart PRO firmware is updated via Bluetooth using a mobile phone app.
  1. Download and install the Firmware Update app using the links on the Techart Downloads page for iOS or Android.
  2. Ensure that both the phone and camera batteries are fully charged.
  3. Make sure the Auto-Lock of the phone is set to Never (iOS) or Sleep is set to 30 minutes (Android).
  4. Attach the Techart PRO adapter to the camera body (see above).
  6. Set the aperture on the camera body to F90 and take a picture.
  7. Turn the camera off.
  8. Launch the Techart Update app.
  9. Select the firmware version from the list.
  10. Press Update.
  11. Wait for the update to complete (approximately 10 minutes).
  12. When the firmware update success message appears, wait for at least one minute before turning the camera back on.
  13. You can check that the firmware has updated correctly by accessing Menu > Setup (Toolbox icon) > 6 > Version. The Techart PRO firmware version is displayed under Lens.
  14. Reset the Auto-Lock or Sleep setting on the phone.
How do I configure the focal length of the lens so it is correctly recorded in the EXIF data?
If the Techart PRO is used as shipped from the factory, a focal length of 15mm will be recorded in the EXIF. The Techart PRO can store up to ten focal lengths, with the default settings as follows.
  1. F11: 15mm
  2. F13: 18mm
  3. F14: 21mm
  4. F16: 24mm
  5. F18: 25mm
  6. F20: 28mm
  7. F22: 35mm
  8. F25: 50mm
  9. F29: 90mm
  10. F32: 135mm (MF only)
To change the focal length to be recorded in the EXIF:
  1. Check that the camera is set to change aperture in 1/3 stop increments.
  2. After switching lenses, turn on the camera.
  3. Set the aperture on the camera body to the corresponding aperture (listed above) for the desired focal length (e.g. F20 for a 28mm lens).
  4. Release the shutter (i.e. take a picture)
  5. Set the aperture on the camera body back to F2.
  6. Set the aperture on the lens to the desired working aperture.
Note that the default setting F32 for a 135mm lens switches the Techart PRO into Manual Focus mode. There seems to be general agreement amongst FM members that this was a poor choice by the Techart engineers. Firstly, because alternating between AF and MF is best achieved by setting a Custom Button on the camera for AF/MF Toggle. Secondly, because AF is just as desirable for 135mm lenses as for other focal lengths. However, this default setting for the 135mm focal length can be modified via the LM-EA7-CONFIG app.
How do I set focal lengths other than the default ones listed above?
The default focal lengths can be modified via Bluetooth using an Android mobile phone app. (Note: Currently there is no iOS version of this Configuration app.).
  1. Ensure that both the phone and camera batteries are fully charged.
  2. Download the Android APP for data settings (LM-EA7-Config.apk) from the Techart Downloads page to your Android phone.
  3. Install the LM-EA7-CONFIG app.
  4. Set the aperture on the camera body to F90 and take a picture.
  5. Turn the camera off.
  6. On the phone, go to Settings and in Display preferences set it to sleep after 10 (or 30) minutes of activity (so the display doesn't turn off during the update).
  7. Still in Settings, open the Bluetooth preferences. The LM-EA7 (i.e. the Techart PRO adapter) should be listed as an available device.
  8. Launch the LM-EA7-CONFIG app.
  9. The configuration app opens with a scrollable list of apertures, enabling you to change the focal length, parking behavior, and focus mode for up to ten lenses.
  10. Modify the default settings as desired and press CONFIG.
  11. When the configuration info has been successfully updated, turn the camera back on and set the aperture on the camera body back to F2.
  12. Test that it has worked by setting the aperture on the camera body to invoke a different focal length then take a picture.
  13. Set the aperture on the camera body back to F2, take a picture, and check the EXIF data.
  14. Reset the phone's Display settings if necessary.
Why does the EXIF data always show F2 even though I set a different maximum aperture with the LM-EA7-CONFIG app?
The EXIF will show F2 no matter what maximum aperture you have set via the config app. Fred Miranda asked the Techart people about this and they explained that, although they originally intended for the aperture value to be recorded into the EXIF via the app, they couldn't get it to work properly, so that functionality is currently blocked.
Why are my pictures overexposed when I set the aperture on the camera to a value other than F2?
When a legacy lens is attached via a dumb adapter the aperture value in the EVF on the LCD shows as "F--", because there is no electronic communication between the lens and the adapter. Correct exposure is then achieved by setting the camera to either A or M mode and using either a fixed ISO or ISO Auto.
However, in order to provide autofocus via Sony's 3rd party PDAF protocol, the Techart PRO emulates a Sony LA-EA3 adapter, in essence "pretending" to be an E-mount lens. The Techart engineers have chosen to emulate a 40mm SAM lens, probably because no such lens exists. Unlike a real A-mount lens whose aperture can be controlled electronically, the aperture on a legacy lens must be set manually. But the TAP still has to to provide an aperture value and F2 was the value chosen. Consequently, no matter what aperture is set manually on the lens, the TAP has been designed to give the correct exposure only when the aperture on the camera is set to F2. If the aperture on the camera is set, for example, to F2.8 then the camera increases the exposure to compensate and the picture will be one stop overexposed.
However, there is a way of circumventing this restriction, which is explained in the next topic.
Is there a way that I can have the actual aperture recorded in the EXIF?
FM member joe256 has reported a method of recording an aperture value (from F2 to F8) in the EXIF, whilst still exposing correctly:
Learned something new (to me at least) about the TAP. You can put the f/stop set on the lens in the EXIF (2.0 - 8.0) in addition to the focal length AND maintain the correct exposure. You do this by using exposure compensation. Set the aperture on the camera the same as on the lens, then compensate accordingly by dial or menu:
f/2.0 = 0, f/2.8 = -1, f/4.0 = -2, f/5.6 = -3, and f/8.0 = - 4 . F/8.0 has to be done in the menu while the first three can be done on the top dial or the menu.
View previous versions
Sep 27, 2016 at 06:00 PM
MIRANDA1
p.1 #2 · Techart PRO LM-EA7 FAQ
Great job documenting this. I can confirm that the Fotodiox M42-Leica adapter is also compatible.
Sep 27, 2016 at 06:12 PM
genji
p.1 #3 · Techart PRO LM-EA7 FAQ
Thanks. I've added the Fotodiox M42-Leica adapter.
Sep 27, 2016 at 06:29 PM
Admin
p.1 #4 · Techart PRO LM-EA7 FAQ
Amazing job! Thank you genji!
I just cross-posted this thread to the Alt board.
Best,
Fred
Sep 27, 2016 at 06:49 PM
arduluth
p.1 #5 · Techart PRO LM-EA7 FAQ
Techart do not recommend its use with CDAF-only cameras (Sony A7, A7R, A7S, etc) and a number of FM members have reported poor performance with these cameras.
Minor quibble, but the A7 isn't CDAF-only and uses on sensor PDAF. This ability is limited to native lenses.
Thanks for putting this together!
Sep 27, 2016 at 06:55 PM
triniart
p.1 #6 · Techart PRO LM-EA7 FAQ
Hi. Fotodiox Nik-L/M works with the TAP
Sep 27, 2016 at 07:05 PM
AGeoJO
p.1 #7 · Techart PRO LM-EA7 FAQ
Yes, great job ! You should get some kind compensation from Techart for doing such a great job in writing the Q&A of the "instruction manual".
Sep 27, 2016 at 07:06 PM
genji
p.1 #8 · Techart PRO LM-EA7 FAQ
Best,
Fred
Thanks, Fred!
Correction made, thank you.
Fotodiox Nik-L/M adapter added, thanks.
Maybe I could hit them up for another TAP -- a couple of members have said how much they like having a spare.
Sep 27, 2016 at 07:19 PM
Admin
p.1 #9 · Techart PRO LM-EA7 FAQ
genji wrote:
Thanks, Fred!
I just informed TechArt about this FAQ.
Sep 27, 2016 at 07:33 PM
GMPhotography
p.1 #10 · Techart PRO LM-EA7 FAQ
Great idea folks and nice work
Sep 27, 2016 at 07:41 PM
AdaptedLenses
p.1 #11 · Techart PRO LM-EA7 FAQ
Thanks for consolidating this info. Forgot about f/45 setting which solves one problem and exposure compensation is a neat idea to record Aperture.
Question about the configure app, can I pick which aperture gets a lens set to it? Or do I have the same 10 slots, I can just change their values?
Thanks again.
Sep 27, 2016 at 09:34 PM
brendans
p.1 #12 · Techart PRO LM-EA7 FAQ
Do you have to toggle between MF/AF or can you just leave it in AF and to prefocus/tweak focus manually?
Thanks for the work!
Edited on Sep 27, 2016 at 11:55 PM · View previous versions
Sep 27, 2016 at 09:48 PM
Admin
p.1 #13 · Techart PRO LM-EA7 FAQ
Thanks again.
Unfortunately we can't pick a new aperture. We can only tweak the ones already offered by the adapter.
Sep 27, 2016 at 10:06 PM
GMPhotography
p.1 #14 · Techart PRO LM-EA7 FAQ
Not sure it's here but I use Custom function 1 for magnify and use Custom button 2 for AF/MF toggle switch. I love how fast I can go back and forth
Sep 27, 2016 at 10:20 PM
strohscw
p.1 #15 · Techart PRO LM-EA7 FAQ
I would like to know how to handle a zoom (Leica R35-70 F4) on the Techart Pro according the IBIS. What is "best", switch off ibis or use 35, 50 or 70mm as FL?
Any suggestions?
Sep 28, 2016 at 12:49 AM
k-h.a.w
p.1 #16 · Techart PRO LM-EA7 FAQ
Any suggestions?
I have that lens and use IBIS. With the push of one button one can select 35, 50, or 70mm.
In any case I would not over-correct IBIS by selecting an IBIS focal length that is larger than the actual one used to shoot the image.
K-H.
Sep 28, 2016 at 02:01 AM
genji
p.1 #17 · Techart PRO LM-EA7 FAQ
K-H.
I'm planning to add an item to the FAQ with recommendations for Custom Button assignments and your setup is one that I'll definitely include. (Guy's tip a couple of posts ago too.)
Sep 28, 2016 at 03:36 AM
k-h.a.w
p.1 #18 · Techart PRO LM-EA7 FAQ
Thank you genji.
K-H.
Sep 28, 2016 at 03:57 AM
genji
p.1 #19 · Techart PRO LM-EA7 FAQ
Any suggestions?
FM members are successfully using a number of different zooms with the TAP (Contax C/Y 35-70/3.4, Minolta MD 35-70/3.5, Vario-Elmar-R 35-70/4, etc) so it's worth adding a topic about this to the FAQ. Thanks!
Sep 28, 2016 at 05:15 AM
Admin
p.1 #20 · Techart PRO LM-EA7 FAQ
An alternative is set the IBIS aperture setting to 50mm when using one of the above zooms.
Sep 28, 2016 at 09:02 AM
       2       3              54       55       end
       2       3              54       55       end
