This topic is in the 2016 archive. You can read it and like its posts here. It is read only.
Archive 2016Tripod Leg Wraps for RRS TVC 34
bobmcg
p.1 #1Tripod Leg Wraps for RRS TVC 34
I would appreciate a recommendation for leg wraps for Really Right Stuff TVC 34 tripod. Has anyone used the Lenscoat 312 with this tripod? Thanks in advance.
May 23, 2016 at 06:49 PM
EB-1
Details
p.1 #2Tripod Leg Wraps for RRS TVC 34
I don't know the specific numbers, but I use Lenscoats on three of my tripods.
May 23, 2016 at 09:57 PM
sjms
Details
p.1 #3Tripod Leg Wraps for RRS TVC 34
where lenscoat does a neat color scheme change up for tripods as a padding for over the shoulder heavy carry they tend to lack. I have gone through a accessories reduction program and basically found for carry the Aquatech tripod leg wraps do pretty much what they're designed to do which is to reduce should stress and or bruising while transporting your setup OTS. easy on easy off for use with other legsets.
May 23, 2016 at 11:05 PM
Roland W
Details
p.1 #4Tripod Leg Wraps for RRS TVC 34
I also am a happy user of the Aquatech tripod leg wraps. They pad quite nicely, and tend to stay put fairly well, but in some cases will slowly slide along the leg as you carry the tripod. But they are much better than the styles like the Lenscoat brand ones which I used to use.
May 24, 2016 at 09:37 AM
calvin2
Details
p.1 #5Tripod Leg Wraps for RRS TVC 34
I don't like the Lenscoat pads - over time the Velcro curls up and catches on some materials.
May 24, 2016 at 12:29 PM
kwilliam8
Details
p.1 #6Tripod Leg Wraps for RRS TVC 34
As you probably know, LensCoat makes two similar, but different, things for tripod legs. For example, for the RRS 34L tripod, they make both:
http://www.lenscoat.com/legcoatreg-wraps-p-1387.html
http://www.lenscoat.com/legcoat%C2%AE-5530s-p-308.html
The first ones are called LegCoat Wraps, while the second ones are called LegCoats. This can be confusing. The LegCoats (second one) have more padding, but are much more bulky. The LegCoat Wraps have less padding, but are less bulky. I use the LegCoat Wraps (for both my RRS 34L and my RRS 24L) for three reasons – (1) slight padding, (2) warmer legs in cold weather, and (3) protection for the tripod legs. The camo is also nice.
Now, for the purpose of padding while shoulder carrying a tripod, I use the following (in addition to the LegCoat Wraps):
https://www.outdoorphotogear.com/pod-pad-tripod-shoulder-pad/
When I carry my tripods over my shoulder (e.g., with a long lens on a gimbal head), this pad is the one that helps much more than any padding that might be put on the legs themselves. This happens to be the area of the tripod that hits my shoulder the most.
These are just my experiences and preferences. I hope this helps in some way.
Keith W.
May 24, 2016 at 01:45 PM
Jeffrey
★ Featured Winner
Details
p.1 #7Tripod Leg Wraps for RRS TVC 34
Are you after padding or gripping or insulation? For grip and insulation I use thick road bike handlebar tape. Lots of choices in thickness and colors. Really good grip, too.
Jun 07, 2016 at 06:50 PM
jancohen
Details
p.1 #8Tripod Leg Wraps for RRS TVC 34
I actually prefer OP/TECH USA Tripod Leg Wraps over Lenscoat covers. Cheaper and better padding.
At Amazon
Jun 07, 2016 at 09:28 PM
chez
Details
p.1 #9Tripod Leg Wraps for RRS TVC 34
Jeffrey, that is exactly what I use. And the thicker tape does provide some cushioning.
Jun 08, 2016 at 06:15 AM
JPAZ
Details
p.1 #10Tripod Leg Wraps for RRS TVC 34
I've got the LensCoat on my TVC-34 (regular size) and it fits fine. Great padding but the velcro does curl up as others have said. Maybe next time I'll try the cheap pipe insulation and tape method
Jun 10, 2016 at 08:47 PM
FM ForumsGeneral Gear-talkJoin Upload & Sell
