       2       3       end
Archive 2016 · Leica SL observations compared to Q and M240
Ranma13
p.1 #1 · Leica SL observations compared to Q and M240
I rented a Leica SL from lensrentals.com and just received it today. I've been playing around with it for a few hours now, and since I have the M240 and Leica Q as well, I figured that I'd do a preliminary compare and contrast between the 3 cameras.
I rented the Leica SL because I've been having issues getting critical focus with the M240, especially on people's eyes. Even after calibrating the rangefinder and getting both the 1.2x and 1.4x magnifier, it's still sometimes difficult for me to make out the rangefinder patch (a symptom of getting older, perhaps?). I've also had issues holding the M240 steady enough to get sharp shots at 1/60 sec, which is normally my go-to shutter speed for the best compromise between shutter speed and ISO. I've been having a much easier time getting sharp shots with the Leica Q, but I love the M lenses. This made me wonder: how would the Leica SL do with M lenses? Here's my observations:
  1. For tripod work, the SL is by far the easiest to work with because the SD card slot is on the side of the camera, not the bottom. This means that you can remove the card without having to un-tripod the camera. Leica Q comes in 2nd because the card slot is on the bottom, and you need to un-tripod the camera to get to the card. Fortunately, it's possible to offset the tripod plate so that it doesn't block the door. M240 comes in a distant last place because not only do you have to un-tripod the camera, but you also have to remove the plate as well. This really, really sucks for any kind of tripod work where you need to remove the SD card frequently:
  2. For all 3 cameras, there's no way to disable noise reduction, and they all start using NR at 1-second exposures and higher. This may or may not affect you; it affected me pretty badly this past New Year's when I was trying to take pictures of fireworks in bulb mode. I had to wait for NR to complete before taking the next shot, which lead to a lot of missed shots, especially towards the end of the show when the fireworks are going off in rapid succession.
  3. The SL in aperture priority, unlike the Q and M240, will not drop the shutter speed below the minimum amount set in the auto ISO settings. This means that if your auto-ISO settings are 6400 with a minimum shutter of 1/60 sec, whereas the Q and M240 will drop the shutter speed below the minimum if it detects an under-exposure, the SL will cap it at 1/60, even if it means underexposing. This is an interesting design choice, as every other camera I've used will drop the shutter speed. Correction: the Q will also cap the shutter speed, like the SL:
  4. The Leica Q makes a soft, constant noise that sounds like water boiling. This is the OIS in action, and turning off OIS will reduce the sound, but not eliminate it entirely. The M240 and SL do not make any noise when using them (aside from the typical shutter noise, of course).
  5. The 6 buttons on the SL (4 on the back, 1 on top, and 1 in front) are configurable, but only for what they do when you long press them. There doesn't seem to be a way to configure their short press behavior, which is what I'd think that most photographers would want to do.
  6. The Leica Q's absolute (absolute meaning in there's no way to go any higher, no matter what you do) max shutter speed is 30 seconds. M240 is 60 sec. I've only tested the Leica SL for 2 minutes because I had to hold down the shutter manually, but it's definitely much longer. Keep in mind though that the noise reduction runs for the same amount of time as the exposure, so a 2-minute shutter will require 2 minutes of NR. Assuming that the SL can do 30-minute exposures, you will likely also have to wait 30 minutes for NR to finish. The shutter settings on the SL only allows you to set a max of 60 seconds before it goes into bulb mode.
  7. The noise reduction message screen for all 3 cameras does not allow you to do anything else with the camera. Even turning them off will wait for NR to finish before shutting down. The Q and SL only displays a message that noise reduction is in progress, whereas the M240 shows the time remaining before it's complete. Not sure why the timer was removed in the Q and SL, as this is pretty useful info:
  8. The Q's bulb mode is press-to-start, press-to-finish; it doesn't allow you to hold the button down. The SL and M240 use the standard hold-until-finish shutter press. On the Q and SL, there's no indication that the exposure is happening; the LCD screen displays a black image (like what you'd see if you covered up the lens), but there's no timer that counts up or an icon to indicate that an exposure is taking place. This is especially problematic on the Q because of the press-to-start shutter and lack of shutter sound due to the electronic first curtain (unless you enable the fake shutter sound effect); if you're taking a shot in a very dark setting, it's impossible to tell if the camera actually exposing or not. The SL doesn't have an electronic first curtain, so you still get the shutter sound at least, but SEE CORRECTION BELOW. The M240 is the best of the bunch; it will show you the exposure timer counting up in the rangefinder. Correction: The SL will show a timer counting down on the top OLED panel ("16" above the 50):
  9. The 2-stage shutter on the SL feels mushy for the first stage, and has a lot of travel before you reach the point where any additional pressure will trigger a full press. The M240 and Q are sharp with short travel. I prefer the shorter and sharper travel; the SL's shutter feels too mushy for my liking.
  10. When you half-press the shutter on the SL, the button labels that describe what the 4 buttons on the back are for, go away. If you want to activate any of the 4 buttons, you have to press the button first to bring back the labels, then press it again for the button to perform its action. You can change this behavior so that you don't have to do the double-press by setting Display Shortcut Icons to Off, but then you lose the labels completely. There's no way to get the opposite behavior, where the labels always show.
  11. When it comes to weight, the SL is the heaviest of the bunch, but feels decently-balanced thanks to the grip, although the bottom right hand corner digs into your hand. The M240 is heavy and unbalanced, and the handgrip didn't help much for me because you have to stretch your index finger to press the shutter, a very uncomfortable action. The Q has the same basic shape as the M240, but it feels decent because it's light. Unfortunately, none of the 3 cameras feel ergonomically great to me. The Q is forgettable and light, the SL is heavy but tolerable, and I actively dislike the M240's ergonomics.
  12. There are two ways to magnify the image for manual focusing M lenses: the lower left button on the back, and by pressing in the joystick to the right of the EVF. The lower left button doesn't pair well with M lenses because you have to keep your hand on the focus ring, which means you can't press the lower left button with your left hand. This means that you either have to stretch your hand a bit to press in the joystick, or use your nose to press the lower left button. Neither is really ideal, though the joystick is not too badly positioned where you'd have to stretch very far to press it.
  13. The rear LCD for the Q and SL stays on when doing a long exposure. Both cameras also 'freeze' as this is happening (dials and buttons do nothing, EVF sensor is unresponsive).
  14. The EVF in the SL shows a larger image than the Q, and fills the eye more. Whereas the Q feels like you're looking through a window with an EVF behind it, the SL is bigger and feels closer to the eye. Refresh rate for both feel about the same (120hz). I will update later with more info on dim lighting performance.
  15. The Q's focus peaking can be displayed at the same time along with the histogram and clipping, but only after the focus ring is moved. This means that, if you half-press the shutter, the focus peaking will go away until you move the focus ring again. For the SL, you can only view the histogram and clipping, or focus peaking, but not both at the same time (they are different 'pages' as you cycle through the display modes).
  16. Focus peaking is a bit thin on all 3 cameras, only displaying the peaking for very high contrast stuff (black on white). Anything with moderate contrast and below (white on dark gray, yellow on blue) tend not to show the focus peaking color. Luckily, the EVF on the Q and SL are good enough that you can achieve critical focus only using magnification. See picture below, where black and white shows good focus peaking, silver on gray shows thin peaking, and red on yellow shows almost nothing, despite having a well-defined edge:
    See original, where it's much easier to see the focus peaking than the resized thumbnail: https://i.imgur.com/uyMd1nY.jpg
  17. There appears to be a very small difference in flange distances between the SL (using the Leica M to T adapter) and the M240. With the M240, infinity on my 2 lenses converges exactly on infinity (right-most position on the focus ring), whereas on the SL, the lenses will extend a tiny bit past infinity:
  18. Shooting in DNG only mode on the SL does a weird thing with the image playback. Zooming into a taken photo when you shoot only DNG shows a very, very blurry image, which is pretty useless for anything. Zoomed out with DNG only looks fine, but you can't check focus. In order to get the zoom working normally, you must shoot DNG+JPG. See image below, where left is JPG+DNG, and right is DNG only.
  19. Focus magnification for all 3 cameras are:
    Leica Q: 3x, 6x
    Leica SL: 4x, 6x
    Leica M240: 5x, 10x
I will update this post with more information as I play around with the camera more (I have it until Friday), along with some images.
Edited on Jan 08, 2016 at 06:01 AM · View previous versions
Jan 05, 2016 at 03:08 AM
Ranma13
p.1 #2 · Leica SL observations compared to Q and M240
A sample image:
Original: http://i.imgur.com/kJeZXz9.jpg
1:1 shows that it's tack sharp (view original, imgur resizing sucks):
Original: http://i.imgur.com/Hmk2NvL.jpg
But pushing an under-exposed file up +5 EV shows a ton of hot pixels:
Original: http://i.imgur.com/7wSGocK.jpg
This ain't no Pentax 645Z for sure.
Jan 05, 2016 at 03:44 AM
rscheffler
p.1 #3 · Leica SL observations compared to Q and M240
Thanks for taking the time to list your findings!
Do you feel your M lenses perform as well on the SL as on the M?
Jan 06, 2016 at 01:30 PM
hiepphotog
p.1 #4 · Leica SL observations compared to Q and M240
Thank you for sharing and organizing your findings. You pointed out some of the big flaws, to me, that I have not read anywhere else (i.e. forced LENR, forced min. Ss, etc.). Quite sure that I wouldn't get one even if with price drop.
Jan 06, 2016 at 06:42 PM
Steve Spencer
p.1 #5 · Leica SL observations compared to Q and M240
I agree the LENR should be fixed with a firmware upgrade, but the forced minimum shutter is only in A or P mode with auto ISO. Personally I almost never use auto ISO, but set it manually for what I want and that should be a viable work around for most people if you want really slow shutter speeds. Just set the ISO lower and you can get those slower shutter speeds in A or P mode, or use manual mode (setting the aperture and SS you want) and use auto ISO to get proper exposure. Either work around should be fairly easy. I suppose this could be fixed with a firmware upgrade, but 1/60 isn't a bad minimum shutter speed for lots of types of shooting and some people might prefer this built in floor.
I do appreciate the detailed review by the OP, as someone likely to get the SL I this amount of detail is very much appreciated.
Jan 06, 2016 at 11:08 PM
beauport
p.1 #6 · Leica SL observations compared to Q and M240
Hello, and thanks for the detailed comparison. I have a question regarding the sound you mentioned from the Q. "The Leica Q makes a soft, constant noise that sounds like water boiling. This is the OIS in action, and turning off OIS will reduce the sound, but not eliminate it entirely. The M240 and SL do not make any noise when using them (aside from the typical shutter noise, of course)."
I was curious about this and so I took my Q into the quietest space in the house, really very dead. I leave OIS off all together. The only sound I could get from the Q is when the shutter was released and that is the very quiet leaf shutter.
Do you think perhaps there is a residual sound if the OIS was used and then turned off?
Jan 07, 2016 at 12:14 PM
Jman13
p.1 #7 · Leica SL observations compared to Q and M240
Looking at the negatives you noted for the SL - anyone find them rather inexcusable for a camera of this price? If those items were noted on any other brand's mirrorless they'd be roasted alive for failing to address even the most simple usability concerns. A lot of those seem like fairly big issues in actual usability.
I only spent about 10 minutes with the SL at PhotoPlus and I liked it fine at first blush, but I did not like the control placement and configuration.
Jan 07, 2016 at 12:25 PM
arduluth
p.1 #8 · Leica SL observations compared to Q and M240
Steve Spencer wrote:
I agree the LENR should be fixed with a firmware upgrade...
Should be, but I wouldn't hold your breath. It's been almost 3 years since the M240 came out, and they haven't bothered to fix it yet.
Jan 07, 2016 at 08:34 PM
arduluth
p.1 #9 · Leica SL observations compared to Q and M240
I was thinking the same thing while reading the OP. Can you imagine the complaining if Sony or Fuji had those limitations? Or if you couldn't move around the focus mag box? Honestly, it kind if blows my mind.
Jan 07, 2016 at 08:43 PM
rattymouse
p.1 #10 · Leica SL observations compared to Q and M240
Leica can be like Fuji now and fix all their defects via firmware updates.
Jan 07, 2016 at 08:46 PM
arduluth
p.1 #11 · Leica SL observations compared to Q and M240
They always have had that capacity. The M240 has upgradeable firmware, yet they haven't fixed the issue(s) talked about in the OP. I wouldn't hold my breath hoping that Leica suddenly does about face and starts fixing issues like this with firmware upgrade.
Don't get me wrong, they should. If any camera company should be providing this kind of support, it's Leica.
Jan 07, 2016 at 09:17 PM
Ranma13
p.1 #12 · Leica SL observations compared to Q and M240
Sorry for the late reply, I've been slammed these past few days and only had some serious time with the SL today. Here are some additional things I've found. I've also added some pictures to the original post and updated some of the points, so feel free to have a read through it again.
  1. Focus peaking will show in review mode, even when zoomed in. This is pretty cool, but would be vastly more useful if the focus peaking wasn't so anemic. As it stands now, it's much easier to evaluate focus based on the image itself rather than the peaking.
  2. If you set one of the back 4 buttons to exposure compensation and you're looking through the EVF, you won't be able to change the exposure comp using the button unless you enable Menu access in EVF in the settings. This is strange, as the default exposure compensation button (long hold the FN button on top of the camera) works fine when this setting is disabled. I believe this is a bug.
  3. Unlike the Q and M240, you can move the focus point around using the joystick after zooming in. However, zooming out and back in again will reset the focus point to the center. This makes it difficult to toggle between checking focus and composition if you're focusing on something off-center.
  4. The lower left button will zoom in 3x, 6x, 1x when pressed, but pressing in the joystick will only toggle between 6x and 1x.
  5. When using auto white balance, it will sometimes noticeably change the white balance in between shots. When you press the shutter button, the EVF will blank out for a split second and come back, but you'll see slightly different colors. This happened to me multiple times today while I was shooting at the zoo, so there's no changing light sources, and the animals I shot were mostly stationary.
  6. ISO 50 is nice and lets you shoot wide open in bright daylight. According to Leica, it's a push ISO, but it doesn't lose any stops. I haven't done enough testing to verify this either way.
  7. The FN button on the front of the camera toggles between aperture preview and aperture + shutter preview. The shutter preview is nice, as it allows you to keep the EVF refresh fast, while still allowing you to see a shutter preview when you want it.
  8. You can set a custom white balance by long pressing the FN button on the front of the camera, which switches the camera into graycard mode. The camera then auto-adjusts white balance based on what you're pointing it at, and pressing the FN button again will take a picture and set it as the white balance. This allows you to set a custom white balance very quickly, faster than most of the other cameras I've used. Unfortunately, because it takes a picture, it will obey your set shutter speed, so if you have it set to 5 seconds, it will take a 5-second white balance adjustment picture.
  9. I didn't test continuous mode except for one quick test using high speed continuous shooting. The EVF didn't blank out between shots, and showed as if you were doing an image preview of each shot. This is consistent with the behavior of other mirrorless cameras.
  10. If the GPS was unsuccessful in acquiring GPS coordinates, it will record 0°0'0" N 0°0'0" E, which is in the middle of the ocean near Africa. This is my first camera with built-in GPS, so I'm not sure if this behavior is consistent with other GPS-enabled cameras.
  11. Due to the un-ergonomic shape of the grip, the weight distribution of the camera is not even across your right hand. It will put pressure on the bottom half of your hand when holding the camera (particularly your pinky), and this also makes the back right corner (which I've mentioned earlier is sharper than I'd like) dig into your hand harder than it normally would.
  12. Long pressing one of the 6 buttons takes 1 second before the camera recognizes it as a long press. This means that you cannot, for example, press and hold a button and immediately turn the dial. You have to wait for the 1 second to pass before you can change the setting. This makes rapid changes of ISO and exposure compensation slower than it should be. The M240 and Q don't behave this way when changing ISO and exposure comp, you can press and hold and turn the dial immediately for an instant response.
  13. Unlike the Q and M240, there appears to be no way to set the rear dial for direct exposure compensation. You need to assign one of the FN buttons to it, then long press and hold it to change exposure comp.
  14. The menu does not remember your last-selected setting, instead always defaulting to the favorites page.
  15. The camera has a 2-3 second startup time, including coming out of sleep mode. If you're looking for an instant shot, you'll be greeted by a black nothingness until the proximity sensor is initialized and turns on the EVF.
  16. The OLED display on top has a backlight, and it only turns on when the ambient light sensor on the front of the camera (top left corner) detects that light levels has dropped enough. There is no way to configure its sensitivity, but it seems to be set at a good level.
  17. The shutter stays open if you're removing and mounting a lens, but the EVF will go dark. Once you remove or mount the lens completely, the EVF will turn back on. This is probably to let you know if you didn't completely mount your lens. You can also free lens with this camera, as long as you don't half-mount it. Not sure how this will affect time lapsers who disengage the contacts on AF lenses to prevent the aperture from changing slightly between shots (would only affect the TL and T lenses though).
  18. If you look through the EVF for a decent time period, looking back out into the world will make your left eye and right eye focus on different points, which is a bit disorienting. I've experienced this a little with the Q as well, but it's a little more severe with the SL, possibly due to the larger EVF.
  19. You can zoom into a photo, then change the photo while keeping the same zoom and position. This makes it easy to check focus across shots without having to zoom out, change photos, and zoom back in.
  20. I was able to get 385 shots before the camera shut down due to low battery power. The LCD timeout was set to 1 minute and camera timeout was set to 2 minutes. This is on par with its CIPA rating of 400 shots.
And to answer your questions:
Do you feel your M lenses perform as well on the SL as on the M? I personally haven't noticed a difference in quality. Sean Reid (of reidreviews.com) has some examples that shows the same performance at center, and very slightly reduced performance in the corners for the SL using M lenses. The difference is so slight though that you probably wouldn't be able to tell if the two weren't side-by-side. At this level, your composition and subject matter matter much more, and if you're printing big enough where it'd be noticeable, you'd be in the market for medium format, not full frame.
Regarding Leica Q boiling water sound: it seems to be coming out of the right-hand side of the camera. I tried setting a manual ISO, aperture, shutter speed, and focus, but I'm still getting the sound. It might be just my camera; it's very faint and doesn't seem to affect the camera in any way though, so I'm not too bothered by it.
I'll post my final impressions sometime later as it's getting late, but spoiler alert: I don't really recommend this camera for anyone, particularly at this price point.
Jan 08, 2016 at 04:46 AM
rscheffler
p.1 #13 · Leica SL observations compared to Q and M240
Too bad about the 2-3 second start up time. It's the same with the M240, but at least there you can disable sleep and not have to worry about an EVF draining the battery rapidly. Would have hoped Leica could eliminate such a long delay by now.
The camera does sound like a first generation product... No direct exp comp makes me wonder, but I recall the wheel on the M9 was too easy to accidentally turn inadvertently.... Maybe they're being too cautious. Does make me wonder how seriously they take user feedback, given some of the UI choices. That said, can it be as bad as some of Sony's? Every Leica I've owned/used has been a mix of love and hate. So far there has always been enough to love to forgive the shortcomings. But sometimes I wonder what the thought process was around some of these quirks. I suspect the SL will be similar and how usable it is will ultimately depend on the needs and expectations of each photographer.
Jan 10, 2016 at 09:04 PM
Arai
p.1 #14 · Leica SL observations compared to Q and M240
The start up time is rapid if not only a second, not sure why you had 2-3 second start up time and I used Sony 94mbs sdxc.
I agree about the ergonomic though, it will make your bottom right hand sore if you holding it by one hand but mostly I use both hands because it balance well with both hands.
Jan 19, 2016 at 11:03 PM
Ranma13
p.1 #15 · Leica SL observations compared to Q and M240
The camera starts up in about a second, but the EVF takes another second or two to initialize.
Jan 19, 2016 at 11:29 PM
rscheffler
p.1 #16 · Leica SL observations compared to Q and M240
In the last week I had the chance to try the SL briefly a couple times at a Leica store. The portraits I did with the 24-90 looked technically good and I liked the rendering of the lens. AF was good too for this kind of thing. But the lens was huge. No way around that, unfortunately. I tried a bunch of M lenses on it and liked the experience a lot. I found I could focus 50mm and longer quite effectively by eye without magnification. The camera had the latest firmware installed and pushing down on the joystick to activate image magnification was very good, but I agree that how it resets to the center of the frame after leaving magnified view is at times annoying. Where I'm a bit disappointed is with performance of the 21 SEM and (original) 28 Cron at wider apertures compared to the M bodies. Images with both lenses on the SL were somewhat degraded in the outer zone. Probably wouldn't be much to worry about except for technical type work where sharpness is desired in those areas.
Compared to Sony a7 series IMO the SL is leagues ahead in usability. I would buy one if I had the money kicking around for a 'want' rather than a 'need' in respect to photo gear. But at the moment I feel I get better wide angle performance with the M240 and will wait to see what the next M brings in respect to EVF/live view. On the other end of the spectrum, there are things for which I still need a high-end DSLR, such as shooting field sports, where I don't believe the SL will compete effectively (let alone the lack of suitable lenses). Therefore while the SL is way more desirable IMO than the Sony mirrorless cameras, it still falls in a gray middle area between the overlapping extremes of the M system and DSLRs, not effectively replacing either for certain aspects I need/value and is thus not a complete replacement for one or the other. I still think the SL with a set of smaller Summicron primes would be attractive. Maybe in time once the lens range fleshes out more...?
Jan 21, 2016 at 07:14 PM
Lee Saxon
p.1 #17 · Leica SL observations compared to Q and M240
Man, all this time I've been trying to come up with creative ways to try to explain to people what's wrong with Leica and all I had to say was "you have to take the base plate off the M240 to remove the memory card because a proper card slot door would ruin the vintage aesthetic." If only I'd known.
Still, sounds like the SL is a very strong attempt, and I'd very tempted if it was about the price of a D810. Oh well, maybe Sony will give me an A9 soon.
Jan 21, 2016 at 07:57 PM
naturephoto1
p.1 #18 · Leica SL observations compared to Q and M240
Hi Lee,
In the case of the M240 you also have to remove the bottom plate to replace the battery and if the camera is tripod is mounted, guess what you also have to do to remove the memory card and the battery.
Rich
Jan 21, 2016 at 08:08 PM
Ranma13
p.1 #19 · Leica SL observations compared to Q and M240
I was going to post my final impressions, but wanted to wait until I had the chance to try out the A7R II, which I did try out a week ago and instantly disliked due to its handling (both interface and feel in hand) and short battery life. The pictures also look horrible in the corners with Leica lenses. I'm aware of the Kolarivision mod for the A7R II, but that won't fix the handling issues.
Ultimately, there's only 3 choices for full frame mirrorless cameras that can mount Leica M-mount glass: the A7R II (and family), Leica SL, and Leica M240. However, the M240 is in another category altogether, so that really leaves us with only two choices. Comparing the SL to the A7R II for M-mount lenses, I would vastly recommend the SL over the A7R II for its handling, image quality, the much better and larger EVF, and longer battery life.
One thing to keep in mind though is that Photokina is at the end of this year (2016), and it's right about the time that Leica should be introducing the next M camera. Given their recent foray into modern, EVF-centric cameras, it's not crazy to think that the next M camera will also have a high-res EVF, whether external or built-in, perhaps even some kind of hybrid EVF + rangefinder combination (electronic rangefinder?).
For now though, I'm definitely in the market for a Leica SL, despite my initial recommendation that it's not for anyone. It's definitely above the competition when shooting with manual focus glass, if only because of that gorgeous EVF.
Jan 21, 2016 at 09:09 PM
uhoh7
p.1 #20 · Leica SL observations compared to Q and M240
One of these days we will see a A7r2 with the Kolari and that will be really interesting
Excellent bullet points on the three cameras.
The SL is not such a joke as DPR and many others made out in the beginning. Of course the A7 and A7r were widely trashed prior to release as well.
Jan 22, 2016 at 03:25 AM
       2       3       end
       2       3       end
