KapHn8d™ Offline Upload & Sell: Off
I can assure you that a short test shot won't shot you anything... heh.
The infrared cutback in the 1Ds is extremely strong... more so than any other Canon digital camera I know of... that being said, IR exposure works like visible light exposure ie. for a give aperture, the less light your have available, the longer you need to leave the shutter open. No magic there...
the IR cutback in the 1Ds is strong enough that you need plenty of time to take your shots... even with a very strong IR source like bright sun on a clear day at mid day, you can expect shutter times in minutes, not seconds.
This is a 1Ds IR shot taken from the top of Stanserhorn in Switzerland... the mountain in on the left is Mount Pilatus.
https://www.fredmiranda.com/hosting/data//500/17278ir_pilatus.jpg
The was taken in the harsh mid-day sun... exposure time was 2 minutes.
Since we're on the subject, here is a refresher on what Canon lenses are IR friendly. For those that aren't familiar with what I mean by that, there has been a documented effect with certain Canon lenses where an undesirable "hot spot" in the center of the frame develops during IR exposure. It is speculated that it has to do with the coating or fabrication of the elements in those lenses. Here is the list I have to date... please let me know if there are errors or if you have any to add:
Good
Canon EF 17-40mm f/4 L
Canon EF 24-70mm f/2.8 L
Canon EF 28-135mm/3.5-5.6 IS
Canon EF 28mm f/2.8
Canon EF 50mm f/1.8 MKI
Canon EF 50mm f/1.8 MKII
Canon EF 70-200mm f/4L
Canon EF 75-300mm/4.0-5.6 IS
Canon EF 135mm f/2L
Canon EF 100-400mm4.0-5.6 IS L
Canon EF 100mm f/2.8 macro
Bad
Canon EF 16-35mm f2.8 L
Canon EF 20mm f/2.8
Canon EF 35mm f/2
Canon EF 24-85mm f/3.5-4.5
Canon EF 28-70mm f/2.8L
Canon EF 28-105mm f/3.5-4.5
Canon EF 35-80/4.0-5.6
Canon EF 50mm/f1.4
Canon EF 50mm/f2.5 Macro
Canon EF 70-200mm f/2.8L IS
Canon EF 85mm f/1.8
Also, there is a decent link on IR basics here: http://dpfwiw.com/ir.htm
If you have a viewfinder shutter on your camera, shut it during the exposure to prevent light bleed through the viewfinder. If you don't have one, find osmething to stick over the viewfinder.
One more note about the 1Ds in particular... because of the long shutter times required for IR with the 1Ds, you will need a remote release with that ability to lock the shutter release because 99.9% of your IR shots will be bulb exposures.
Hope that helps answer your question...
-Clayton
