I believe if push via ISO setting, the CMOS sensor gain (sensitivity) increases (along with system noise), you lose a bit in signal to noise ratio. If push via under-exposure, you lose dynamic range. For 1 stop underexpose, you turned a 12 bit sensor in the 10D into a 11 bit but gained a lttle bit in lower noise.
