fredmiranda.com Login
This topic is in the 2013 archive. You can read it and like its posts here. It is read only.
Archive 2013Sony A7R sensor gets high scores from DxOMark
p.1 #1Sony A7R sensor gets high scores from DxOMark
Sony A7R sensor gets high scores by Dx0Mark
DxOMark puts the Sony α7R sensor to the test and although predictable, the results are incredible for such small mirrorless camera. The scores are pretty much identical to Nikon's DxOMark champion D800E.
"Compared to the 36-Mpix Nikon D800 models, the results are very similar indeed, implying the new Sony A7R uses the same (Sony made) sensor."
"Although we can’t provide any commentary on image sharpness at this stage in our tests, the sensor in the Sony Alpha 7R performs exceptionally and is on a par with that found in the D800 models. Given the Sony’s small size, low weight and outstanding sensor performance, it’s one of the most intriguing and compelling new additions in recent times." - Read more
_________________
Pre-order Information:
Cameras:Lenses & Accessories:
Oct 31, 2013 at 10:18 AM
snapsy
Details
p.1 #2Sony A7R sensor gets high scores from DxOMark
Results are basically equal to a D800E. 18% gray SNR is 1/6 stop behind the D800E. Dynamic range about the same save for the weird D800E blip at ISO 200, color response looks very close to the D800E but slightly worse. All the results look to be within the margin of error. Would have liked to see Sony improve the High ISO DR, although if it doesn't have the D800/E's amp noise it will still be a noticeable improvement over those bodies.
Oct 31, 2013 at 10:31 AM
Mescalamba
Details
p.1 #3Sony A7R sensor gets high scores from DxOMark
Yea and CFA almost exactly like D800E. No A7R for me then..
I thought it has slightly worse colors than A99, but said to myself, well its JPGs. Apparently it wasnt JPGs. Sigh. :/
Well, f*ck that.. back to dSLRs.
Oct 31, 2013 at 10:36 AM
naturephoto1
Details
p.1 #4Sony A7R sensor gets high scores from DxOMark
But look at the size, weight, and cost comparison between the D800/D800e and the A7r to say nothing of the number of adaptable lenses for the A7r.
Rich
Edited on Oct 31, 2013 at 11:20 AM · View previous versions
Oct 31, 2013 at 10:40 AM
dmora
Details
p.1 #5Sony A7R sensor gets high scores from DxOMark
It's like Sony is incapable of making a vertical grip that doesn't look like an afterthought or a huge brick...
Oct 31, 2013 at 10:54 AM
Rickuz
Details
p.1 #6Sony A7R sensor gets high scores from DxOMark
Ehm what? The A7R is awesome, at least in the eyes of us canonites with our ancient low DR and over-milked sensor tech.
I can understand you a little bit if you already have a D800 / D800E though.. But just a little bit.
Oct 31, 2013 at 10:58 AM
uhoh7
Details
p.1 #7Sony A7R sensor gets high scores from DxOMark
First negative comment I've heard about it. Is that all u got?
what else you hate?
Oct 31, 2013 at 11:05 AM
Tariq Gibran
Details
p.1 #8Sony A7R sensor gets high scores from DxOMark
I take it you are referring to the individual "color response" measurement and not the overall "Portrait (Color Depth)" score? Interestingly, it appears that it might be the case that Sony sensors with AA filters have a higher color response measurement than those without an AA filter. That is the case with the RX1 vs RX1r anyway. I don't know ultimately how important that measurement is - that it actually makes as much difference as it might seem...at least I believe theSuede said something to that extent. It was a while back when discussing the A900 (which does have amazing color and color response #s?) so I'm not 100% sure.
Oct 31, 2013 at 11:10 AM
cputeq
Details
p.1 #9Sony A7R sensor gets high scores from DxOMark
uhoh7 wrote:
dmora wroteIt's like Sony is incapable of making a vertical grip that doesn't look like an afterthought or a huge brick...
what else you hate?
That's really the first negative?
How about slow flash sync, no electronic first curtain, it's not free, no dual SD card slots, no IBIS, it'll be managed by Sony, my photos will still be average, no built-in flash, and it won't solve world issues
That said, I have to agree the grip is butt-ugly. Probably pretty comfortable, though.
Oct 31, 2013 at 11:18 AM
carstenw
Details
p.1 #10Sony A7R sensor gets high scores from DxOMark
I don't mind the look of the grip, but the placement of the front wheel is bizarre to say the least.
Oct 31, 2013 at 11:19 AM
Rickuz
Details
p.1 #11Sony A7R sensor gets high scores from DxOMark
When people talk about "ugly" cameras or "ugly" grips, are they seriously talking about the looks of the product, or are they referring to the ergonomics?
Sad and ridiculous if it's the former. Do these people use their cameras as some kind of chick-magnets?
Oct 31, 2013 at 11:23 AM
douglasf13
Details
p.1 #12Sony A7R sensor gets high scores from DxOMark
I find it a little odd that someone who is apparently interested in the visual art of photography wouldn't be interested in the visual design from a camera maker. I'm not saying that function should follow form, but they're both important.
Oct 31, 2013 at 11:33 AM
Mescalamba
Details
p.1 #13Sony A7R sensor gets high scores from DxOMark
Tariq Gibran wrote:
Mescalamba wroteYea and CFA almost exactly like D800E. No A7R for me then..
...Show more →
http://www.dxomark.com/About/In-depth-measurements/Measurements/Color-sensitivity
Simply called SMI. A7R result of 78/75 is a "meh". D800E has 77/74 (I guess these sensors are really very similar). And for example 1D-X has 73/74, which is a bit.. tragic. Especially compared to 1D/s MK3 .
Bottom is currently 6D with 69/70. Thats somewhere around "tragicomedy" level. Quite visible in all pics taken with it.
Obviously people dont have same vision of colors and some are more or less colorblind. Since most photographers are still men, which are even more colorblind, it doesnt matter that much as it could.
That said, SMI is directly tied to CFA used. Better you get, better SMI you will have as results. Downside is that thicker CFA means also less light = more noise (tho in case of something like D4 sensor, it wouldnt have exactly big impact on SNR).
Issue with SMI is that it doesnt tell "where those color errors are". It doesnt tell if camera cant find difference between violet and blue flowers, or pink vs red skin tone. Even then its rather good tool for getting overall idea how much good or bad colors will be.
In case of A7R, if you are fine with current Nikon and Canon offerings, you will be fine with this. Actually you will probably gain in colors too.
Me? I will pass and wait if Nikon came to senses with Nikon "Pure" DF or whatever that will be and see then.
Oct 31, 2013 at 11:40 AM
Rickuz
Details
p.1 #14Sony A7R sensor gets high scores from DxOMark
douglasf13 wrote:
Rickuz wroteWhen people talk about "ugly" cameras or "ugly" grips, are they seriously talking about the looks of the product, or are they referring to the ergonomics?
Maybe it's just me, but as long as the camera delivers in the IQ department and feels good in my hands, I wouldn't care if the Camera is pink with neon-green smiley faces all over it.
Actually, an ugly camera is probably less prone to theft also.
That said, I don't find the A7R ugly.
Oct 31, 2013 at 11:41 AM
Mescalamba
Details
p.1 #15Sony A7R sensor gets high scores from DxOMark
A7/R looks slightly "strange" and that grip seems to follow rest of the body. It might look better, but Im not sure it would be comfortable.
Both A900 and A99 have bit "strange" grips, but both are great.
But ofc, Im always happy when camera looks nice too.
Oct 31, 2013 at 11:42 AM
naturephoto1
Details
p.1 #16Sony A7R sensor gets high scores from DxOMark
I handled the camera at PhotoPlus and I found that the camera with the grip handled and balanced quite well.
Rich
Oct 31, 2013 at 11:47 AM
uhoh7
Details
p.1 #17Sony A7R sensor gets high scores from DxOMark
what else you hate?
First negative about the grip, I mean, haha
They use them instead of chicks.....
like that nikon DF guy
Oct 31, 2013 at 11:51 AM
Tariq Gibran
Details
p.1 #18Sony A7R sensor gets high scores from DxOMark
...Show more →
So, if we take the RX1 (84/81) and RX1r (79/75) example I cited, your conclusion is that these two cameras are using a completely different CFA which is why they differ? I suspect there is more to it, perhaps including the AA filter as well as software tuning. Anyway, I bet the A7 with it's AA filter will likely have a better measurement. Incidentally, the Leica M 240 only scores 75/71 but I really don't hear folks talking about how bad Leica color is. I suspect the delta has to be pretty large to really matter. Per DxO:
"In practice, the SMI for DSLRs ranges between 75 and 85, and is not very discriminating." Given the somewhat arbitrary nature of these scores you mentioned (and theSuede previously also mentioned), I don't think these scores really mean that much in practice.
Oct 31, 2013 at 11:57 AM
sebboh
Details
p.1 #19Sony A7R sensor gets high scores from DxOMark
not effectively.
i'm curious though, is there a manufacturer that actually does make visually appealing grips? i sure haven't seen one. to be fair though, i think pretty much all cameras are objectively ugly.
Oct 31, 2013 at 12:00 PM
JonPB
Details
p.1 #20Sony A7R sensor gets high scores from DxOMark
I guess I really need to start reading spec sheets for what they don't include. I'm stunned that those aren't included in the box.
I think I should start a meta-rumors site about what people will complain about next, for everyone who wants to be on the cutting edge of curmudgeonry.
Oct 31, 2013 at 12:03 PM
