Archive 2013 · Balancing Rock - Halos in HDR
TerryCzap
p.1 #1 · p.1 #1 · Balancing Rock - Halos in HDR
Hi,
I've noticed a repetition of haloing effects in many of my HDR merges (3 images in this one), especially when trees are involved. Can anyone tell me where the cure might lie? What can I do to avoid this situation?
I've cleaned this one up a bit, but the trees on lower left are blemished still.
Terry
Balancing Rock - Garden of the Gods Park - Colorado Springs, CO
Jun 15, 2013 at 07:01 PM
Bob Jarman
p.1 #2 · p.1 #2 · Balancing Rock - Halos in HDR
Fascinating image and scene. Don't think I've ever seen this before, which doesn't mean anything .
As for your question, we could play a bit if you'd post the series? Otherwise, I have no idea.
Best of luck with the fires out that way,
Bob
Jun 15, 2013 at 10:14 PM
TerryCzap
p.1 #3 · p.1 #3 · Balancing Rock - Halos in HDR
Thanks Bob, Here ya go.
Terry
Jun 15, 2013 at 10:24 PM
Bob Jarman
p.1 #4 · p.1 #4 · Balancing Rock - Halos in HDR
Thanks for the set,
I've not dabbled in HDR much, and then usually with a single image.
Here is my first experience with a series and Nik's (HDR Efex Pro 2). If you like it all credit to the software, I merely pushed sliders around. As with all Nik products, there are about 2 dozen presets for all sorts of styles/looks as jumping-off points.
Have not sharpened or done anything other then run through HDR EP2.
Well, change 1 - had to run through CS6 to convert to jpeg, applied some sharpening in ACR too. No science, just eye-balled it. Ramping up the radius did spawn jaggies in the tree...
Regards,
Bob
Jun 15, 2013 at 11:36 PM
TerryCzap
p.1 #5 · p.1 #5 · Balancing Rock - Halos in HDR
Looks very nice Bob. I'm using Photomatix and don't know what I'm doing to create the halos.
Terry
Jun 15, 2013 at 11:39 PM
Bob Jarman
p.1 #6 · p.1 #6 · Balancing Rock - Halos in HDR
Terry
Thanks,
Not familiar with that, surely someone else is,
Someone?
Regards,
Bob
Jun 15, 2013 at 11:43 PM
TerryCzap
p.1 #7 · p.1 #7 · Balancing Rock - Halos in HDR
I've located the quirk, though I'd still like to find a workaround. If I process the series with the "realistic" effect, then I get the same results that you are showing Bob. Occasionally I like to use the "painterly" effect in Photomatix, and that is when I get the haloing, primarily in trees.
Terry
Jun 16, 2013 at 12:48 AM
RustyBug
p.1 #8 · p.1 #8 · Balancing Rock - Halos in HDR
Took a stab at using 2 images and layers/masks.
Edited on Jun 17, 2013 at 02:59 PM · View previous versions
Jun 16, 2013 at 02:24 AM
TerryCzap
p.1 #9 · p.1 #9 · Balancing Rock - Halos in HDR
Thanks Rusty. I've much to learn.
Terry
Jun 16, 2013 at 02:26 AM
TerryCzap
p.1 #10 · p.1 #10 · Balancing Rock - Halos in HDR
Thanks for your input Barbara, your re-work looks good. I'll check into Tony's software. Post processing, (along with everything else), is my weakest link.... but time and experience will assist me much. I believe I chose the "painterly" effect due to the way it enhances the clouds. This is my version using the "realistic" mode in Photomatix.
Terry
Balancing Rock - 30 ft. tall, weighs 140,000 lbs. Garden of the Gods Park - Colorado Springs, CO
Jun 17, 2013 at 12:37 PM
Bob Jarman
p.1 #11 · p.1 #11 · Balancing Rock - Halos in HDR
+1 Barbara, re Tony Kuyper's Luminosity mask set. Excellent tutorials and cost is minimal. Will take some time and thought but marvelous set of tools.
Bob
Jun 17, 2013 at 02:02 PM
