Archive 2013 · need a solution to Pan head clamp release
Jglaser757
p.1 #1 · p.1 #1 · need a solution to Pan head clamp release
I have an Induro phq pan head. It has five movements. I love everything about except the clamp release plate,,the release knob sticks out to far and I prefer a lever release,,,,But I cannot find one,
http://www.indurogear.com/products/induro-phq-series-panheads-phq1.aspx
does anybody have any suggestions!!
May 24, 2013 at 03:11 PM
howardm4
p.1 #2 · p.1 #2 · need a solution to Pan head clamp release
I'm sure that one you remove that PCL-1 clone there will be a 1/4 or 3/8 male stud so then buy a lever QR plate from RRS or Markins or so. Do you require that PCL-1 functionality?
May 24, 2013 at 06:30 PM
Jglaser757
p.1 #3 · p.1 #3 · need a solution to Pan head clamp release
I like the functionality of the panning clamp. It really help when the camer is in the vertical position and I'm recon posing my image
May 24, 2013 at 08:46 PM
howardm4
p.1 #4 · p.1 #4 · need a solution to Pan head clamp release
Have you seen this? The knob appears to be much shorter but unfortunately, it's still a knob
http://www.amazon.com/SUNWAYFOTO-Panning-Tripod-Compatible-DDH-02/dp/B008EZ4O28
http://www.scvphotoideas.com/2012/10/sunwayfoto-ddh-02-compact-panning-clamp.html
May 25, 2013 at 05:02 AM
Jglaser757
p.1 #5 · p.1 #5 · need a solution to Pan head clamp release
Yeah I saw this,,I think it might be my only solution for now!!
May 25, 2013 at 09:04 AM
DearDuck
[X]
p.1 #6 · p.1 #6 · need a solution to Pan head clamp release
I have a idea, you can buy a lever-release clamp and a sunwayfoto Bi-directional adapter plate GHA-01. Then you can mount the GHA on the bottom of lever clamp, and then mount the combination to your panning clamp. At last, attach your plate to the lever clamp is ok.
Hope this information may help you.
May 26, 2013 at 09:13 PM
Gochugogi
p.1 #7 · p.1 #7 · need a solution to Pan head clamp release
I briefly owned the Sunwayfoto DDH-02 panning clamp (that's my review on Amazon), It's well made but way too small for serious DSLR use. The clamp jaws are barely 23mm, not even an inch. You might want to consider the next larger size:
http://www.amazon.com/SUNWAYFOTO-Panning-Tripod-Compatible-DDH-03N/dp/B009JPAAPW/ref=sr_1_1?s=electronics&ie=UTF8&qid=1369627063&sr=1-1&keywords=SUNWAYFOTO+DDH-03N
It has a short screw handle and panning is smooth as silk. Both of these panning clamps work great with Chinese Arca plates (38.5mm) and can top load or slide in. However large plates (39.5mm or larger) like the Camadapter Arca Plus or RRS are too large to top load and only can slide in.
May 26, 2013 at 11:01 PM
Mike V
p.1 #8 · p.1 #8 · need a solution to Pan head clamp release
http://www.videoguys.com.au/ProdImages/2240/mf323.jpg
These Manfrotto ones are really cheap and work OK.
May 29, 2013 at 03:21 AM
