Archive 2013 · Floral ... 52BB
RustyBug
p.1 #1 · Floral ... 52BB
Playing with the Tammy 90/2.5
May 18, 2013 at 10:04 PM
Bob Jarman
p.1 #2 · Floral ... 52BB
#2 is very nice - well done.
Another try with higher position to diminish the petals in front?
Bob
May 19, 2013 at 09:41 AM
RustyBug
p.1 #3 · Floral ... 52BB
Thanks Bob,
Here's a different angle that doesn't have as much petal interference. Access (higher angle) was somewhat restricted in the first, but this one seems a bit "straight on" / static ... pick your poison, I guess.
May 19, 2013 at 09:59 AM
Camperjim
p.1 #4 · Floral ... 52BB
Bullseye..dead centered on all of the images
May 19, 2013 at 01:53 PM
RustyBug
p.1 #5 · Floral ... 52BB
Is that "good" or "bad" for these?
May 19, 2013 at 02:18 PM
Camperjim
p.1 #6 · Floral ... 52BB
I think these are too centered for my taste. The center of each flower is pretty close to the center of the image. I guess that could be good but for me the compositions seem a bit static.
May 19, 2013 at 06:04 PM
beanpkk
p.1 #7 · Floral ... 52BB
For what its worth I really like the first shot. I think a more straight on view on the second one might improve it, but that first one really sings.
Just my $.01.
keith
May 19, 2013 at 06:12 PM
gregfountain
p.1 #8 · Floral ... 52BB
Nice job on these Kent. I like the second the best. Nice job maintaining the detail in the whites. The angle you chose gives it depth. Centered, not centered, it's subjective..it's all about feel and sometimes centered feels right.
Greg
May 19, 2013 at 09:17 PM
AuntiPode
p.1 #9 · Floral ... 52BB
I like the colors, but somewhat centered and somewhat closely cropped in square frames combine with negative synergism to make the first and third too static to my eyes. That's why I like the second better. The oblong side ratio and the flow of the visual lines makes it seem more dynamic.
May 19, 2013 at 11:15 PM
RustyBug
p.1 #10 · Floral ... 52BB
Thanks guys.
I normally shoot manual exposure, but I these were a couple end of the day shots using camera metering @ aperture priority. I might have to rethink my willingness to let the camera do the math (few more test shots of course) as I was a bit surprised by the color rendering (following camera setting changes).
May 20, 2013 at 10:53 AM
Camperjim
p.1 #11 · Floral ... 52BB
RustyBug wrote:
Thanks guys.
I know several photographers who routinely use manual exposure. I usually fix the ISO, use aperture priority which means the camera adjusts shutter speed. I check all the settings before hitting the shutter. Regardless of the exposure mode it seems we are always relying on the camera's light metering and the choice of exposure mode is just a matter of preference. Is there something I am missing or don't understand?
May 20, 2013 at 11:22 AM
RustyBug
p.1 #12 · Floral ... 52BB
I've been trying to find the optimal technique/strategy for retaining detail without blowing a channel. As I have started to take an interest in floral it seems that they have a tendency to have a "purity" of color that is easily blown in a given channel, that doesn't necessarily correspond to "proper exposure" techniques.
Given that even in a "regular" scene, meters can be readily fooled, I was surprised by how well this seemed to work for these two. I guess my question is simply what value (0-255) should be the maximum value in a given channel that will reveal detail/not blow the channel?
These turned out a bit to my liking, but since it was "Av" mode, I'm not sure why / why not I can trust this setup for future shooting. It seems as though the same metering mode handled two very different kinds of scenes/subjects. If I don't "understand the why", then I typically don't trust it very much, so I'm at "Hmmmm" atm.
May 20, 2013 at 11:37 AM
gregfountain
p.1 #13 · Floral ... 52BB
Simply put, I have found a light meter to be the best measure of exposure values for any given shot since you can measure light beyond a vertical plane, which I believe is what causes most "blown" channels when using the camera's metering system. For instance, when you frame a shot, even if you are using evaluative metering, or "matrix" metering, wherein the camera uses the whole scene to calculate an average, it is only "seeing" a flat vertical plane. In this case, anything on the plane that averages low, will pull the curve to the right, and anything on that plane to the highlight side will pul the curve to the left. Having the ability to meter exactly where you want, and set the exposure accordingly, gives you an advantage......
Food for thought....
Greg
Edited on May 22, 2013 at 01:49 AM · View previous versions
May 20, 2013 at 11:51 PM
Jglaser757
p.1 #14 · Floral ... 52BB
my vote is too bracket your shots,,that way you be sure to get "closer" in your best exposure..Also,you could even try HDR with this!!!
May 21, 2013 at 04:43 AM
RustyBug
p.1 #15 · Floral ... 52BB
Thanks Greg,
I've been skipping out on using an incident meter, trying to do things off of histo and RGB values, and using Sunny 16 as a baseline for those times when I've not got an incident meter with me. I realize the differences in metering @ reflective vs. incident, but I think I've been struggling to properly place the values for such "pure color".
After looking at theses a bit, I'm inclined to think that the "expose to the right" mantra when dealing with such channel oriented subjects may not be my approach.
I think I've been striving for a wrong target in my RGB values (expose to the right), which has been resulting in an overexposure/toning of the colors, and thus a corresponding tendency for me to "multiply" or "gamma" correct in pp. I've run some numbers using the 32 bit 0-1 scale in Excel and think I know why/where things have been going awry for me now.
It'll be interesting to test out a few things, but I think I've got "half-a-clue" at where I've been off before ... we'll see.
+1 @ bracketing is an option ... but I'm the kind who'd prefer to calculate than guess, when I've got the option. The fact that my calculations haven't been yielding my desired results means I've been calculating wrongly (based on a wrong premise, I now believe). Too much boring math to present here, but if things test out I'll share my findings if anyone is interested.
May 21, 2013 at 09:05 AM
AuntiPode
p.1 #16 · Floral ... 52BB
Maybe a few tweaks to selections for gamma and exposure, some selective vibrance/sat reduction, plus some mid-tone boost and a wee bit of retouching?
May 21, 2013 at 03:51 PM
gregfountain
p.1 #17 · Floral ... 52BB
ETTR is more of a shooing scheme of those that typically shoot people, where minute detail isn't the goal (who wants to see skin pores?). I tend to go more ETTL and pull the shadows a bit in post....
May 21, 2013 at 03:59 PM
RustyBug
p.1 #18 · Floral ... 52BB
Karen, definitely a bit more on the vivid side of things. Always a challenge to decide where to put the gamma/contrast.
Greg, thanks ... I'm a bit saddened by the volumes of images I've shot chasing the ETTR mantra. Hopefully, I can correct some things and get on track.
BTW ... Congrats on your recent WA win.
May 21, 2013 at 11:38 PM
