Archive 2013 · Dust on sensor?
jc9394
p.1 #1 · Dust on sensor?
Sorry being newb on this, I have never need to clean a sensor before. I notice a few dust when I take long exposure or using aperture 8 or smaller, I did use a rocket blower after self clean does not help. Rocket blower removed most but there are few spots still there, it is not visible when I shoot with aperture larger than 8.
May 17, 2013 at 09:44 AM
jc9394
p.1 #2 · Dust on sensor?
I forget to ask the question, should I try to use the wet method? I don't shoot long exposure or higher than aperture 8 normally.
May 17, 2013 at 09:59 AM
BruceF99
p.1 #3 · Dust on sensor?
If the blower didn't get everything (or move the dust) then wet cleaning is a good idea, IMHO. I use the basic kit with QuickStrips from http://www.copperhillimages.com/ It's pretty easy to do once you get the hand of it. And they have a pretty good tutorial on their site.
May 17, 2013 at 12:21 PM
mike-in-ak
p.1 #4 · Dust on sensor?
I start with a rocket blower then move to a fine brush and finally a wet clean with photographic solutions swabs w/ eclipse brand cleaning solution.
Products and methods vary, I suggest a bit of internet searching.
I clean sensors at least once a year or as needed.
May 17, 2013 at 12:24 PM
jc9394
p.1 #5 · Dust on sensor?
Thanks guys, I did read both on my searches. I will just leave it for now and clean it it later since it is not visible for most of the pictures I take.
May 17, 2013 at 12:27 PM
jc9394
p.1 #6 · Dust on sensor?
Anyone used canned air? Copperhillimage.com stated Canon tech use it to clean their sensor.
May 17, 2013 at 08:49 PM
ckcarr
p.1 #7 · Dust on sensor?
I do, but I'm not sure someone new to the process should do it. You don't want to throw a big loogie in there from the can propellant. Depends on the camera body value I guess. Which body is it?
May 17, 2013 at 08:58 PM
jc9394
p.1 #8 · Dust on sensor?
D800E, I will not use the canned air. Just wondering.
Going to order the wet/dry kit.
May 17, 2013 at 09:05 PM
scottam10
p.1 #9 · Dust on sensor?
Take great care, I've seen a few bodies on ebay with the disclaimer 'I screwed up while cleaning it and scratched the sensor'
I prefer not to touch the sensor myself, but if you decide to go ahead just make sure you know what you're doing
May 17, 2013 at 09:16 PM
jc9394
p.1 #10 · Dust on sensor?
Same here, prefer not to touch the sensor too. The few tiny tiny spots does not brother me that much yet, I mostly shoot aperture 2-4. I will order the kit just incase I need it.
May 17, 2013 at 09:25 PM
ReyGay
p.1 #11 · Dust on sensor?
Pure Acetone and pure organic cotton buds on wooden sticks. Had been using it several times on my D3X and other dslr bodies (and lenses). Just make sure you don't touch any of those black coating inside the camera. I did try the commercial swabs etc...no good, leaves residues or rainbow colours on the sensor surface or that milky look, while pure acetone evaporates immediately.
My Flickr Gallery
My interesting photos on Flickriver
my Deviantart gallery
May 17, 2013 at 09:46 PM
shmn
p.1 #12 · Dust on sensor?
Doesn't pure acetone dissolve some plastics? Which is why it's stored in metal containers (I work in a boat yard and we go though a lot of acetone). I've never cleaned my sensor so I'm not an expert on this topic, but I would think using acetone could cause problems if you get it on areas it shouldn't be on. It is a great "cleaner" though.
May 17, 2013 at 11:23 PM
lukeb
p.1 #13 · Dust on sensor?
Be careful, that's an expensive fix should you make a mistake!
Having said that, I have successfully used the Pentax Imagesensor Cleaning Kit
http://www.adorama.com/IPXISCK.html?gclid=CJDSpdTpnrcCFclj7AodrlkAog
May 17, 2013 at 11:34 PM
Rags Hef
p.1 #14 · Dust on sensor?
The D800's were having oil spatter from shutter. Is it dust or oil? If it's its oil send it to Nikon they're fixing it.
If it's dust.. I would recommend not using acetone; posters are right - it can melt plastic
I like Bestine - a trade name for a fast disappearing solvent that doesn't leave spots. Available in art stores
It's really important to use a sensor swab (no lint); since I scratched my sensor (low pass filter actually) using a handbuilt deal.
If it's dust, it can come from shooting environment or from the camera sensor dust off. I used to dust off the sensor with the cam on it's side - thereby dislodging gravity held dust and redepositing it on the sensor - drove me nuts.
Good luck
Rags
May 17, 2013 at 11:41 PM
ReyGay
p.1 #15 · Dust on sensor?
It does dissolve some plastics. So using acetone for this purpose needs proper tools. I use a lamp with a magnifying glass and a pair of steady hands. Nikon has made sure the corners of the dslr sensors are metal so when cleaned with acetone, it won't dissolve and no it won't dissolve the low pass filter, it's made of hard glass with a hard coating on it that's resistant to acetone. Big reason why Nikon service centers use acetone to do the same task. People call this crazy but it is apparently suggested by Nikon engineers themselves, at least that's what I was told many years ago. Again, I suggest doing this after practicing on older dslrs, so you know your clearances so not to touch the black internal non reflective paint.
My Flickr Gallery
May 18, 2013 at 12:32 AM
jc9394
p.1 #16 · Dust on sensor?
Good call on the oil, it may be since I tried rocket blower few times and it did not come loose. I will wait for another 1,000 clicks before sending in to Nikon service. It only have around 3,000 now.
May 18, 2013 at 08:32 AM
ckcarr
p.1 #17 · Dust on sensor?
I never heard of an oil issue with the D800 or D800e. There is no free Nikon fix that I'm aware of. D600 - yes.
Forget the acetone. There are other perfectly safe products out there.
The proper steps in order to try:
Blowing. Then inspect.
Light brushing of the sensor with a Arctic Butterfly type brush to loosen any statically charged stubborn dust specs..
Blow again. (Or skip because sometimes it redistributes dust).
Inspect.
Wet clean if still needed.
I don't have the time to send a camera body in to Nikon with their current time frame.
You really just need to learn it yourself. But don't get discouraged. Often after the first attempt by someone, it becomes worse. Just patience and a redo.
Here's a decent video.
http://www.moosepeterson.com/blog/2012/06/11/sensor-cleaning-with-copperhill/
May 18, 2013 at 08:52 AM
Rags Hef
p.1 #18 · Dust on sensor?
Inspect.
Oooops... I'm wrong on the D800 oil issue (it's focus)... Sorry about that...
Errr.. We are all assuming the cam opening is upside down when blowing... right?...
Rags
May 18, 2013 at 09:00 AM
jc9394
p.1 #19 · Dust on sensor?
Inspect.
Yes, I watched this video few times already. I will order the wet/dry kit and try the brush first. Will try it with my Panasonic GF1 first.
May 18, 2013 at 10:21 AM
RCicala
p.1 #20 · Dust on sensor?
I'm one who cleans sensors often (well over 1,000 a year at work) - but I get really nervous doing a D800 sensor - replacement is $1,800.
May 18, 2013 at 11:25 AM
