Archive 2013 · Zeiss Sonnar 85mm f/2.8 circle within hightlight disc bokeh
sonics
p.1 #1 · Zeiss Sonnar 85mm f/2.8 circle within hightlight disc bokeh
Recently I got myself a Zeiss Sonnar 85mm f/2.8 c/y mount.
I love the IQ but one thing bugs me a bit.
As seen on the photo below I see a disc with the highlight disc. Something not seen on my Canon EF 100 f/2 (bottom photo). Both are 100% crop photos.
What is the reason this happens? the Zeiss glass looks 100% clean
http://data.squee.nl/example5.jpg
sonnar 85mm f/2.8
http://data.squee.nl/example4.jpg
EF 100mm f/2
May 13, 2013 at 01:49 PM
rscheffler
p.1 #2 · Zeiss Sonnar 85mm f/2.8 circle within hightlight disc bokeh
I'd guess it's due to the optical design, not a defect. You'll probably find that the rendering of the out of focus specular highlights is different for objects in front of the plane of focus vs. those behind the plane of focus. Most seem to be primarily concerned with background rendering and overlook that foreground rendering can be different.
May 13, 2013 at 01:53 PM
sonics
p.1 #3 · Zeiss Sonnar 85mm f/2.8 circle within hightlight disc bokeh
I think you are right. I made 2 quick tests with objects behind the plane of focus. f/2.8 and f/4
http://data.squee.nl/example6.jpg
http://data.squee.nl/example7.jpg
May 13, 2013 at 02:35 PM
Makten
p.1 #4 · Zeiss Sonnar 85mm f/2.8 circle within hightlight disc bokeh
Foreground bokeh rendering is in 99 out of 100 cases irrelevant for "real" photography. Try the same test while defocusing the background instead.
Edit: Too late! There you go!
May 13, 2013 at 02:36 PM
