Archive 2013 · Win 7 64 bit driver for Canon i9900/9950
John-LS
p.1 #1 · p.1 #1 · Win 7 64 bit driver for Canon i9900/9950
I am looking for a 64 bit driver for my i9950 printer. It was working fine under Win 7 32-bit, but I have upgraded to Win 7 64-bit and cannot find a driver that will work anywhere - certainly not on any of Canon's sites. Same story for my old LBP 810 laser printer. Help please!!
May 08, 2013 at 06:35 AM
gse53
p.1 #2 · p.1 #2 · Win 7 64 bit driver for Canon i9900/9950
I had the same problem with mine. You have to install the driver and then this Printer Driver Add-On Module Ver.1.10 (Windows ...
Canon i9900 drivers
Good luck
May 08, 2013 at 12:16 PM
John-LS
p.1 #3 · p.1 #3 · Win 7 64 bit driver for Canon i9900/9950
Thanks GSE53. I got it to work when directly connected to a USB port. However it is connected to my second PC on the network, running XP 32-bit, and no way can I get the first PC running Win 7 64-bit to connect over the network?
The LBP-810 also seems to be a lost cause, no 64-bit driver to be found anywhere - I will have to swop it on to the XP PC.
May 10, 2013 at 05:59 AM
beretta
p.1 #4 · p.1 #4 · Win 7 64 bit driver for Canon i9900/9950
You have to use windows update for the 64 bit driver and install the driver add on here
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/i_series/i9900#DriversAndSoftware.
George
May 10, 2013 at 06:15 AM
gse53
p.1 #5 · p.1 #5 · Win 7 64 bit driver for Canon i9900/9950
Oh THAT problem!! Yes, I had, still have, that one. I let my son use my ip5000 connected to his 32bit XP desktop. I tried to connect to it, over the network, from my Win7 64bit desktop and laptop and cannot get it to work. If anyone has a workaround I would appreciate it greatly if you shared.
Thanks,
Gary
May 10, 2013 at 01:20 PM
