Archive 2013 · IQ of 28-70/3.5-4.5 II vs 28-135 IS
ZoneV_Nikon
p.1 #1 · IQ of 28-70/3.5-4.5 II vs 28-135 IS
Which has overall better IQ for those who have used both, the 28-70/3.5-4.5 (I believe people have said version II is better than I) or the 28-135 IS?
Thanks.
May 07, 2013 at 07:20 AM
Ian.Dobinson
p.1 #2 · IQ of 28-70/3.5-4.5 II vs 28-135 IS
Are you sure you mean the 28-70 and not the 28-105 USM (or the 24-85 USM) ?
I don't know anything about the 28-70 other than the 2.8 L version . But I used to have the 28-105 USM (mk1) and it was a fab little lens . Very fast AF (proper ring USM) and very good IQ . In the time I had it I also had the 28-70L and before the a tokina 28-80 2.8 (not great) and the little lens more than held its own . I let it go when I got the 24-105L but in truth I wish I'd kept it as it was just as nice IQ in a much smaller lens .
I did try a 28-135 IS and was not that impressed ,
May 07, 2013 at 07:28 AM
Chris Fawkes
p.1 #3 · IQ of 28-70/3.5-4.5 II vs 28-135 IS
I cannot comment on the 28-70 but the 28-135 gives nice sharp images enlarged to 20x30 inch.
I don't own one now simply because variable aperture is a pain when shooting manual but optically I had no complaints.
The barrel is very sloppy and the lens creeps but after I had it calibrated they fixed that. Not sure why Canon let them out so loose.
May 07, 2013 at 07:42 AM
dhphoto
p.1 #4 · IQ of 28-70/3.5-4.5 II vs 28-135 IS
I have a 28-70/3.5-4.5 version II and it is surprising optically, really very good.
The build is pretty awful but the IQ more than makes up for it
Here's a review (for Ian):
http://www.photozone.de/Reviews/187-canon-ef-28-70mm-f35-45-ii-test-report--review
May 07, 2013 at 01:22 PM
Gochugogi
p.1 #5 · IQ of 28-70/3.5-4.5 II vs 28-135 IS
I owned the EF 28-70 3.5-4.5 in the early 90s and it was a great optic for its day but truly terrible and gritty MF ring, slow focus and loud AF motor. However the plastics used in the barrel were battle ready: really thick and heavy compared to later plastic barrels like the 28-135 IS. I think Canon over engineered early EF barrels so they'd earn some credibility for using what many perceived as cheap materials.
I must say I greatly preferred the 28-105 3.5-4.5 USM I replaced it with a couple years later. I remember thinking the plastics in the new fangled design sure were thin compared to the 28-70 3.5-4.5. I recently saw a 28-70 in a pawn shop. They wanted $25 for it without filter. It looked beat and smelled of mildew...
May 07, 2013 at 01:45 PM
Mike Sowsun
p.1 #6 · IQ of 28-70/3.5-4.5 II vs 28-135 IS
I bought a EF 28-70mm 3.5-4.5 II new in 1990 to use with my Canon EOS 630. I also used it with my 10D. From what I remember, it is sharper than the 28-135 IS I owned and the AF was noisy but fast.
The front element retracts into the front of the lens at certain focal ranges which make it difficult to use Polarizing filters. My solution for that was to use an 52mm Cokin extension ring.
http://www.bhphotovideo.com/c/search?Ntt=Cokin+Extension+Ring&N=0&InitialSearch=yes
They are basically a filter with male and female threads and No Glass.
I used them with my EF 28-70 3.5-4.5 II and my EF 28-80 3.5-5.6 USM:
Cokin 52mm Extension Ring added to EF 28-70 3.5-4.5 II
May 07, 2013 at 03:01 PM
ronno
p.1 #7 · IQ of 28-70/3.5-4.5 II vs 28-135 IS
IMO the lens to get in this range is the 24-85 3.5-4.5 USM. I have found focus and optics to be great, and it's very cheap used (not a lot of people know about it...)
May 07, 2013 at 05:41 PM
ZoneV_Nikon
p.1 #8 · IQ of 28-70/3.5-4.5 II vs 28-135 IS
Everything but optics!
Can anyone speak to the optics of the two compared to each other?
Or are they so close it's not an issue?
May 07, 2013 at 05:48 PM
Mike Sowsun
p.1 #9 · IQ of 28-70/3.5-4.5 II vs 28-135 IS
Take a look at Photozone reviews for both lenses. They say the 28-70 is sharper and that is my opinion as well.
http://www.photozone.de/canon-eos
May 07, 2013 at 06:50 PM
EB-1
p.1 #10 · IQ of 28-70/3.5-4.5 II vs 28-135 IS
You are comparing two no-so-hot lenses, the older of which is non-repairable. In the budget normal zoom class the Tamron 28-75/2.8 should also be considered.
May 07, 2013 at 07:50 PM
Gochugogi
p.1 #11 · IQ of 28-70/3.5-4.5 II vs 28-135 IS
The 24-85 USM was a very popular lens from the mid to late 1990s. I used one for nearly 10 years and have a lot of sharp images on my wall from it. Even did a write-up on it:
http://emedia.leeward.hawaii.edu/frary/canon_ef24-85usm.htm
May 07, 2013 at 09:37 PM
