Archive 2013 · The Basics of Time Lapse Photography
Admin
p.1 #1 · The Basics of Time Lapse Photography
Canon Digital Learning Center just posted a four-part video tutorial on some basic time lapse techniques by photographer Vincent Laforet.
Be sure to stop by Vincent’s blog to read the write up that accompanies the video.
" width="400" height="300" frameborder="0" webkitAllowFullScreen mozallowfullscreen allowFullScreen>
Topics covered:
  • Suggested camera equipment and accessories needed to shoot time lapse, including how to use the Timer Remote Controller TC-80N3.
  • How to optimize your EOS camera settings and features for capturing time lapse images.
  • Calculating minimum frames needed and accurate interval settings to ensure smooth movement for projects of any length.
  • Creative considerations for lensing, movement, and composition.
  • Understanding the benefit of shooting time lapse with RAW files, and processing your images with Digital Photo Professional for dynamic results.
  • How to manage time lapse workflow, and assemble and export your finished time lapse movie with Apple QuickTime Pro.
Apr 29, 2013 at 04:53 PM
Lunchb0x8
p.1 #2 · The Basics of Time Lapse Photography
This looks like a great tutorial series, my one question, why don't canon offer an option to download these videos?
I would love to be able to watch them on my iPad or other device when I might be out in the wilderness without a data connection...
Oh well, looks like I am stuck watching at home, might just have to take notes should I want to put these tutorials into practice in the real world.
Apr 29, 2013 at 06:53 PM
stanj
p.1 #3 · The Basics of Time Lapse Photography
Yeah. Good stuff. We had to learn it the hard way years ago
Apr 30, 2013 at 12:49 AM
Beni
p.1 #4 · The Basics of Time Lapse Photography
How do you deal with changing light over a long period? He recommends manual mode but if I want to do a sunrise to sunset including night at either end, it's not going to cut it. Is the only solution to stand over the camera and change with the light? Doesn't that give you a jump in brightness as you change?
Apr 30, 2013 at 10:20 AM
Chris Fawkes
p.1 #5 · The Basics of Time Lapse Photography
Thank you.
Apr 30, 2013 at 10:25 AM
Maxis42
p.1 #6 · The Basics of Time Lapse Photography
I believe he also mentions using AV mode for sunrise, sunsets!
Thanks!
Apr 30, 2013 at 10:35 AM
Beni
p.1 #7 · The Basics of Time Lapse Photography
Problem with that is that Av will try and turn night into day which is why he doesn't like it I assume. Add to that if the sun comes anywhere into the frame which it would do at one point, you're royally screwed.
Apr 30, 2013 at 10:42 AM
Maxis42
p.1 #8 · The Basics of Time Lapse Photography
I'm with you..
Apr 30, 2013 at 10:45 AM
DopamineHunter
p.1 #9 · The Basics of Time Lapse Photography
It won't be perfect but if you're doing all day time lapse you are bound to have light change, nothing you can do about it unless you want to go change the settings.
I've shot timelapse from evening to mid morning, around sunrise (i wasn't directly shooting at the sun or anything) i change the setting so that i don't have overblown skies. it does look natural because thats what you experience as well..going from dark night to bright daylight.
Apr 30, 2013 at 10:50 AM
stanj
p.1 #10 · The Basics of Time Lapse Photography
In my experience, this is best dealt with Av mode and the occasional adjustment of EC and ISO. This works while there's some daylight. When you reach full night (assuming day->night transition), you go full manual. Then you set the last and first frame around an EC/ISO change as anchors, match them, and let software do the interpretation between.
If you have a 1-series camera and there's an evenly lit object in the picture, you link spot metering to AF point and use EC to get the right overall exposure, in Av mode.
In general, Manual is too much hassle to really use, except for starry nights / nature sequences.
Apr 30, 2013 at 11:54 AM
Beni
p.1 #11 · The Basics of Time Lapse Photography
Thanks Stanj, that makes sense.
Apr 30, 2013 at 12:12 PM
Mr Joe
p.1 #12 · The Basics of Time Lapse Photography
Av mode can sometimes induce a flicker effect when assembling the time-lapse. This can be reduced in some software packages. Another option to look up for day/night transitions is called bulb ramping. This can be done with a Promote remote, or Magic Lantern firmware. Another option is to manually adjust the images -- here's a LRTimelapse video that explains how to do ramping without an external device:
Apr 30, 2013 at 12:31 PM
stanj
p.1 #13 · The Basics of Time Lapse Photography
Manual exposure doesn't prevent flicker, contrary to popular belief. Aim your camera at a white, constantly lit wall, and take a 1000 frame sequence and check for yourself. Even with the meter out of the equation, at any aperture other than wide open, the blades have certain tolerance and will not expose evenly. And in most cases you're not shooting a white, evenly lit wall, which will add to flicker (moving clouds, etc).
Bramping has the same problem like any settings adjustment - it requires two anchor points per adjustment, and that adds up pretty quickly. Doing a gradual ramp with Av (esp. if you use centerweighed metering and not matrix) is oh so much easier in most cases.
Like in most things, manual gives you the most control but you'll pay for it with time in post processing. I calculate about 1h per 1s of final movie, and Manual mode has the potential to blow it beyond that.
Apr 30, 2013 at 12:47 PM
jforkner
p.1 #14 · The Basics of Time Lapse Photography
Very informative. Thanks for the info.
Jack
May 03, 2013 at 10:16 AM
Sneakyracer
p.1 #15 · The Basics of Time Lapse Photography
Thanks for posting!
He talks about shooting more images and that the main downside is storage and post-production but one thing he does not mention is the wear and tear on the camera's shutter. One need's to factor the cost of replacing the shutter since it's a real possibility if you shoot timelapses.
May 03, 2013 at 11:07 AM
astro-ep
p.1 #16 · The Basics of Time Lapse Photography
Sneakyracer wrote:
Thanks for posting!
Absolutely...
The few I've tried added a couple thousand clicks to my camera. The good thing is that even the oldest DSLR's have many times the resolution of the HD format. So even an older / obsolete DSLR works good for most time-lapse applications.
Eric
May 04, 2013 at 06:38 PM
stanj
p.1 #17 · The Basics of Time Lapse Photography
In our NASA time lapses, we have shot literally millions of frames on about a dozen bodies, over the course of three years. One shutter failed. I think that's a very low cost, low failure rate. In contrast, we had three bodies and about 5 lenses die due to weather. And that despite the cameras always being protected against weather. Water is a bitch, and always finds a way...
I know people get fixated on shutter wear, but at the end of the day, it actually turns out to be the least of your worries - both financially and from a redundancy standpoint.
May 04, 2013 at 07:17 PM
jforkner
p.1 #18 · The Basics of Time Lapse Photography
Thanks again for turning me on to the world of time lapse. I made my first one yesterday. Over a period of 3 hours, I took 1106 photos---one every 10 seconds. The time period was about 6:00am (just before sunrise) until 9:00am.
I followed the tips presented in the video series; and as mentioned above, ran into a few issues with lighting. I shot in RAW and everything in manual using a Nikon V1. Things went well for the first 10 minutes or so until the sun came up; then as expected, I started to get overexposed images. Over the next 2+ hours, I reset the f-stop and aperture every 20 minutes or so in an attempt to manage exposure.
As you might imagine, this became a bit of a nightmare in post when I tried to blend the images from slightly over-exposed to the new settings. I took groups of 100 or so images and adjusted the exposure in ACR in an attempt to make the blending appear seamless. In the end, I did not achieve that goal and just accepted the obvious light changes. I'm not sure
I still have a lot of experimentation ahead of me; but for a first attempt, I'm generally pleased with the result. I'm not sure aperture-priority or shutter-priority would have been any easier, but I'm going to do some experimentation.
I should mention I also took another series of photos over the same period using My GoPro Hero2. If you don't know, it only takes photos in JPG-format in auto-everything mode and its default ultra-wide angle view. Anyway, I'm not sure I don't like the result better.
Jack
May 05, 2013 at 09:59 AM
stanj
p.1 #19 · The Basics of Time Lapse Photography
That's why I say - don't use manual exposure unless you're shooting at night.
But yes, as you pointed out, there's a huge learning curve and regardless of which approach you take you will spend a lot of time. Better practice in your back yard than on location!
May 05, 2013 at 10:42 AM
trilce84
p.1 #20 · The Basics of Time Lapse Photography
I thought this a great series. And very informative, just--let's be honest--professional looking tutorial.
May 17, 2013 at 03:39 PM
