Sports Corner Rules
Sports Corner Resource
Archive 2013 · HS Soccer (Boys) 10 images.
xicotencatl
p.1 #1 · HS Soccer (Boys) 10 images.
Hi Amigos!
I've been shooting some soccer games, but I'm afraid to post some pics since I'm having problems with 'white uniforms'.
I hope you like these images from last tuesday's game.
Lio.
1.- Almost full frame. Can't crop any better.
2.-
3.-
4.- (someone suggested to see some grass).
5.-
Edited on Apr 25, 2013 at 09:15 PM · View previous versions
Apr 25, 2013 at 09:12 PM
xicotencatl
p.1 #2 · HS Soccer (Boys) 10 images.
Thanks for looking.
#let's keep shooting.
(Edited to show EXIF data).
Lio.
6.-
7.-
8.-
9.- Ref said the ball rolled in and out of the line and then it hit the pole.
10.- The celebration after the PK.
Apr 25, 2013 at 09:14 PM
gome1122
p.1 #3 · HS Soccer (Boys) 10 images.
Numbers 3 and 4 seem pretty overexposed, but that's probably just because of the highlights and the sky as a background.
Apr 26, 2013 at 05:30 AM
schlotz
p.1 #4 · HS Soccer (Boys) 10 images.
White uni's are always an issue especially on very bright days. Best advise I can give is expose for the faces and let the rest fall as it may. Some very good work here Lio!. Really like #5. #10 would have been better if not cropped at the bottom cutting off shoes and a bit of field.
Matt
Apr 26, 2013 at 10:50 AM
xicotencatl
p.1 #5 · HS Soccer (Boys) 10 images.
Thanks for your comment gome1122.
I wish I could use another background, but there are houses on the West and South side. North side is the school and East side is the one I usually use.
Lio.
Apr 26, 2013 at 11:56 AM
xicotencatl
p.1 #6 · HS Soccer (Boys) 10 images.
Matt
Matt;
another thing could be the sun coming out every 5 mins. I don't really like to shoot Av, I just can't trust my camera enough. And this field is weird. It has a bump in the middle and that's why pics #5 and 10 look like this. I know I can always stand up and shoot this way, but I rather to be on the grass.
Thanks for your comment.
Lio.
Apr 26, 2013 at 12:00 PM
xicotencatl
p.1 #7 · HS Soccer (Boys) 10 images.
Another set where I had problems with whites.
Lio.
11.- Matt, look at the player in the background.
12.-
13.-
14.-
15.-
Apr 26, 2013 at 12:05 PM
jmcaverly
p.1 #8 · HS Soccer (Boys) 10 images.
Nice set of photos. White uniforms are always tough in the sun. Just make sure the faces are good and let the uniforms blow out. I have the same issue right now with our white baseball uniforms in the afternoon sun. Not much you can do except to tell them to play later in the sweet light.
Apr 26, 2013 at 12:43 PM
schlotz
p.1 #9 · HS Soccer (Boys) 10 images.
#11 does look a bid strange, almost appears as over the top post processing which I doubt is actually the case having reviewed a number of your posts. BTW: is this a raw conversion or jpg SOOC ?
Matt
Apr 26, 2013 at 04:34 PM
