Archive 2013 · DNG converter
3iron
p.1 #1 · p.1 #1 · DNG converter
DNG converter is a new thing to me, is that something you would use with Lightroom or is a stand alone program?
Do you even need it if you have LR?
Thanks for your help and best wishes.
Apr 07, 2013 at 09:07 PM
howardm4
p.1 #2 · p.1 #2 · DNG converter
you generally dont need it. LR can read/write DNG.
The most common use case is if you have an older version of LR or PS that can't read your new camera's raw format and you're too cheap to upgrade.
Or if your a devotee of the DNG format
Apr 07, 2013 at 09:36 PM
3iron
p.1 #3 · p.1 #3 · DNG converter
howard, thanks you for your help. I just wasn't sure.
Best to you.
Apr 07, 2013 at 11:35 PM
Alan321
p.1 #4 · p.1 #4 · DNG converter
It is a stand-alone program. Best to install it so that it is there is needed. I use a program called image verifier that calls on DNG converter to determine whether or not image files are at least likely to be valid. If DNG converter fails than chances are that the image file has major structural problems.
Sometimes Adobe can take a little while before releasing updates for Lr and ACR that let you use raw files from brand new camera models. In that event DNG converter can help in the interim.
Apr 14, 2013 at 08:08 AM
EB-1
p.1 #5 · p.1 #5 · DNG converter
Or if you find the latest version of LR/PS too crappy and buggy.
Apr 14, 2013 at 03:03 PM
