Here are two more images for review. Per Chuck's suggestion I tried a Check Mate, and the last board played on the Bobby Fisher - Spassky, match, 1972.. Fisher forced a obvious untenable position and Spassky conceded. Thank you for looking and please leave comments as that is how we learn. Jim
I'm not worthy of much note, but I think the from-the-top viewpoint doesn't do as well as a more horizontal "through the pieces" look. The problem I have with the first one as a chess player is that it's an impossible position and therefore obviously a setup. The second one has too much in focus and would benefit from a less vertical viewpoint.
Get down behind the fallen king, looking more or less horizontally, and with the king in focus show that he is surrounded by enemies. You'll have to move the taken white pieces out of the way.
It might work better with a chess set that has larger pieces. Chess is a fascinating subject for this sort of photography.
Thank you. Image one is a figurative "check mark" With the fallen king representing Defeat.. Image #2 is a reproduction of the final board in the 1972 Fisher - Spassky 6th game. Spassky conceded when Fisher's move created a "Forced Mate".. Thank you for the input. The chess set is "Tiny", maybe 4x4 inch with 1/2 inch figures. I Leave the big board at home when we travel. I am posting 2 more today as we narrow down our WA entry. Jim (Credit need be given to Chuck Gardener for the chess photo's idea. Thanks Chuck)
Thanks for trying the suggestion... I'd shoot it as if it were seen from behind Spassky showing his POV of Fisher's winning strategy with a lower angle, fallen King in foreground, surrounded by the other pieces seen OOF in the background.
I'd like to see the camera angle low enough so the pieces in the background seem to loom over the fallen King, but high enough so the board squares and piece positions can be seen.
You might also try several exposures with different focus points then blend them with layers / masks to selectively control what is sharp and blurred.
You might also try several exposures with different focus points then blend them with layers / masks to selectively control what is sharp and blurred....Show more →
thanks, I will give it a shot an post the results. Jim
