Archive 2013 · Jpg to Pdf Conversion
DanMitroi
p.1 #1 · Jpg to Pdf Conversion
Hi All,
Can someone share with me his best tip on how to transform multiple jpg files to Pdf ?
Thanks
Feb 08, 2013 at 04:41 AM
James_N
p.1 #2 · Jpg to Pdf Conversion
Do you have Photoshop CS4 or later? If you do its quite simple to do using Adobe Bridge. Simply select the JPEG files you want to convert to PDF format, then select the Output workspace in Adobe Bridge and you will see options to save the selected files as either PDF or a Web Gallery. Choose the PDF option, then use the Layout section to configure how you want the files to appear, and click the Save button to generate the PDF file(s).
In older versions you can use the Contact Sheet and Picture Package plug-ins in Photoshop to save JPEGs to PDF. And if you don't have Photoshop there are several tools online that can also do the conversion.
Feb 08, 2013 at 06:10 AM
cgardner
p.1 #3 · Jpg to Pdf Conversion
I've used Bridge output to create "contact sheets" for reviewing shots. It's convenient. The PDF file is just a layout "wrapper" for the embedded reduced JPGs in it.
There's no control over the image quality in the reduction process for the photos that I recall (been a while since I've done one) so you might experiment with making the contact sheets directly from out of camera file size vs. first making a reduced size copy closer to the size on the contact sheet with the other output utility in Bridge. That way it is possible to apply USM or other action driven automated PP like adding water mark. Then create the PDF sheets from them. Whether that extra step is worth the trouble will be something only decided by trying it and comparing.
Feb 08, 2013 at 08:02 AM
cltmte
p.1 #4 · Jpg to Pdf Conversion
I just created a pdf file from jpegs using adobe acrobat X pro and it did a nice job of 1 photo per page. They have a free trial on their site if you want to see if it meets your needs.
Mark
Feb 08, 2013 at 08:12 AM
mirkoc
p.1 #5 · Jpg to Pdf Conversion
if you are using canon gear, DPP has easy way in print options. it should work with any jpeg files, not just canon
Feb 09, 2013 at 05:14 PM
hugowolf
p.1 #6 · Jpg to Pdf Conversion
You can adjust compression in Bridge,
Brian A
Feb 09, 2013 at 05:27 PM
DanMitroi
p.1 #7 · Jpg to Pdf Conversion
Thank you all for your advices!
I solved my issue, i discovered on Google a Conversion Tutorial.
Regards,
Feb 13, 2013 at 03:57 AM
Bifurcator
p.1 #8 · Jpg to Pdf Conversion
Select your multiple files,
Print to PDF,
Done.
BatchPro? Seriously? Ug!
Feb 13, 2013 at 05:54 AM
markmohan
p.1 #9 · Jpg to Pdf Conversion
Hello,
You can try to use Kernel for image to PDF conversion is a proficient utility for storage of single or multiple image files in the portable document.. This Tool converter smoothly convert different image files in portable document file format. You with image to PDF conversion program can create single PDF file for each or multiple image files.
Mar 12, 2013 at 06:36 AM
PV Hiker
p.1 #10 · Jpg to Pdf Conversion
Lightroom versions 3 and 4 will do it.
May 20, 2013 at 05:12 PM
jsycwangzhi
p.1 #11 · Jpg to Pdf Conversion
i created a tool which can help you to transfer multi images to the PDF file. You can try it here :https://www.jpginpdf.de/. If you have any questions, please let me know it. https://www.jpginpdf.de/
May 12, 2024 at 04:15 AM
Imagemaster
p.1 #12 · Jpg to Pdf Conversion
Photoshop > File > Automate > PDF Presentation
May 13, 2024 at 04:17 PM
Kenneth Lee
p.1 #13 · Jpg to Pdf Conversion
This can make a slideshow too. Thanks !!
If we view one of these files (like this one https://www.kennethleegallery.com/pdf/slideshow.pdf) in a web browser like Firefox or Safari, the browser's PDF plugin shows the document as consisting of a list of images. However, if we save the file and then open it in Adobe Acrobat Reader, it can be viewed as a full-screen slideshow.
To view the resulting .PDF file as a slide show at full-screen size, can require some extra keystrokes, but when it works, it works very nicely.
On macOS, Adobe Reader doesn't seem to render the transition effects between images, but on Windows11 it works nicely.
Since we're on the topic: can you recommend a good program for making slideshows ? I presume the resulting file is some kind of video format. I don't want the images to be downsized.
May 14, 2024 at 10:21 AM
Imagemaster
p.1 #14 · Jpg to Pdf Conversion
You can have a look here: https://filme.imyfone.com/video-editing-tips/make-slideshow-in-photoshop/
May 14, 2024 at 11:04 AM
AnnJS
p.1 #15 · Jpg to Pdf Conversion
See if JuiceBox Pro would work for you?
I have used it for many years to build Galleries which display on Browsers:
https://www.juicebox.net
May 14, 2024 at 11:15 AM
