Help with radio trigger
stanzel
p.1 #1 · Help with radio trigger
I just upgraded to 2 new alien bees from some old Britek's I have a generic radio setup, but found it to be unreliable at times. I want something that is 1) reliable 2) can get a transmitter and 2 receivers for around $300. I do not need ttl or control for hot shoe flashes.
any suggestions?
Steve
Dec 31, 2012 at 01:51 AM
BrianO
p.1 #2 · Help with radio trigger
stanzel wrote: I just upgraded to 2 new alien bees...
One of these: http://paulcbuff.com/cst.php
and two of these: http://paulcbuff.com/csrplus.php
will get you started nicely. Very reliable, and 100% compatible with Alien Bees.
Dec 31, 2012 at 04:58 AM
Michael White
p.1 #3 · Help with radio trigger
Go with. The new pocket wizard 3's. they not much more than your budget nd they're the standard for. Triggers
Jan 02, 2013 at 03:38 AM
kenyee
p.1 #4 · Help with radio trigger
Also look at Radiopopper JrX Studios...remote manual power control of bees and older hotshoe flashes. I noticed someone has a set in the buy/sell forum...
Jan 02, 2013 at 06:19 PM
Brody LeBlanc
p.1 #5 · Help with radio trigger
Radiopopper JrX Studios or the Paul C. Buff products. I've been using the cybersynchs for ages and can't believe I havent busted them yet.
Jan 02, 2013 at 07:07 PM
gpop
p.1 #6 · Help with radio trigger
another vote for the radiopopper jrx (studio). very reliable.
my only nits with them is that the transmitter adjusting knobs have no detent, so it can be hard to return quickly to a previous setting, and a little easy to disturb the setting without meaning to. and they use not-so-common batteries.
Jan 03, 2013 at 08:38 PM
BrianO
p.1 #7 · Help with radio trigger
I should add that with the CyberSyncs you can add a Cyber Commander at a later date as your budget allows, giving full remote control and strobe metering of the Alien Bees. The CC will work with the CS receivers.
http://www.paulcbuff.com/cc.php
Jan 03, 2013 at 08:51 PM
