Archive 2012 · Playbutton locked on D4
mirrels
p.1 #1 · Playbutton locked on D4
Hi all,
I noticed that I can't review my pictures when I use a remote cable on my D4. (If I press the play button nothing happends.) I use a cheap Chinese cable so this might be the problem. (However there was no problem with my D300s.) Anyone of you knows if the (cheap) remote is the reason for this or is it normal that the play button does not work when using a remote cable control?
Nov 13, 2012 at 06:23 AM
SebastianS
p.1 #2 · Playbutton locked on D4
Is it the kind with a switch? My d700 would do the same thing if the switch was in one position. I believe the switch is for bulb mode... as soon as I switched it to the other position all was well.
Nov 13, 2012 at 09:11 AM
jamez
p.1 #3 · Playbutton locked on D4
Happens with the D3 as well. When a cable is controlling the camera, playback is disabled until the cable is physically removed.
It's not the cable, it's the firmware.
Nov 13, 2012 at 10:28 AM
mirrels
p.1 #4 · Playbutton locked on D4
Ahhh Jamez, thanks. That really sucks. Is there no way around that you know of?
Nov 14, 2012 at 04:16 AM
jamez
p.1 #5 · Playbutton locked on D4
No solution for the D3 (I can't remember if I tethered it via USB and my laptop to get around it).
With the D4 I now instead shoot wirelessly connected via the Ethernet port and command (and review) with my iPad/iPhone/laptop.
Nov 14, 2012 at 07:51 AM
SteveF
p.1 #6 · Playbutton locked on D4
Hi,
This has been a "feature" of Nikons for several years now. I'm currently using the Pocket Wizard camera cable. It has a switch on it to keep the camera awake, but in this mode the playback doesn't work.
Same thing with an IR trigger that I use.
If someone had figured a work around to this I'd like to hear it as well.
Nov 15, 2012 at 09:59 AM
