Moderated by: Carl Auer, Fred Miranda
Sports Corner Rules
Sports Corner Resource
2012 HS Football 5A Playoffs RV vs Ft Collins
Carl Auer
Moderator
p.1 #1 · 2012 HS Football 5A Playoffs RV vs Ft Collins
Cold night at the football field....I should have brought more of my cold weather gear from Alaska.
Ralston Valley won 42-0 and faces Pomona on this Friday night for a chance to head to the final 4
All photos with the 7D, 120-300 2.8 and 580ex II
1.
2.
3.
4.
5.
6.
7.
Nov 12, 2012 at 10:44 PM
mdalby
p.1 #2 · 2012 HS Football 5A Playoffs RV vs Ft Collins
Nice work Carl!!
Nov 14, 2012 at 11:37 PM
Carl Auer
Moderator
p.1 #3 · 2012 HS Football 5A Playoffs RV vs Ft Collins
Thanks...I think I am going to switch things up on Friday night. The 7D does ok with higher ISO than the Mark II, so I thing I might use the 1D on my 120-300 with 580EX II and then use my 7D as a grab camera with either the 85 1.8 (fastest lens I currently have) or with my 24-70 2.8 on it...with the 1.8 I might be able to get 1/500th at ISO 800-1000 on this field.....would have to go to 1600 to 2500 for the 2.8 lens without flash....
Nov 15, 2012 at 12:03 AM
sandman22
p.1 #4 · 2012 HS Football 5A Playoffs RV vs Ft Collins
Hey Carl what's max preps reasoning behind having to use a flash?
Ben
Nov 15, 2012 at 12:06 AM
Carl Auer
Moderator
p.1 #5 · 2012 HS Football 5A Playoffs RV vs Ft Collins
Keep the noise down as much as possible for larger prints.
Nov 15, 2012 at 02:06 AM
sandman22
p.1 #6 · 2012 HS Football 5A Playoffs RV vs Ft Collins
Ah makes sense
Nov 15, 2012 at 03:27 AM
Carl Auer
Moderator
p.1 #7 · 2012 HS Football 5A Playoffs RV vs Ft Collins
I have a feeling things will lighten up over the next couple years as more of the photographers upgrade to newer cameras. Canon 1DX and 1D4 and 5DMkIII's and D4's and D800's/700's handle high ISO's so much better than cameras from just 2 or 3 years ago that flash is going to be a thing of the past soon for MaxPreps. However, I will still strobe basketball because of cycling lights... There are a few guys shooting for them now that are using 1Dx's with 5D3's for backups that do not use flash for night games and their images look fabulous.
Nov 15, 2012 at 03:41 AM
Paulthelefty
p.1 #8 · 2012 HS Football 5A Playoffs RV vs Ft Collins
I am curious to know how often you get "called off" and have to stop using flash. I have been thinking about trying this myself.
Paul
Nov 15, 2012 at 02:45 PM
Carl Auer
Moderator
p.1 #9 · 2012 HS Football 5A Playoffs RV vs Ft Collins
Not once for football. Here in Colorado, CHSAA, the governing body, actually has written into the photographer rules that flash/strobe is permitted unless it directly affects the ability of players or officials to compete/perform their duties. So, as long as I am not pointing the flash/strobe directly into a volleyball players face, or putting strobes/flashes in areas the players or officials can run into them, you are good. I know in Alaska, strobes are not allowed for volleyball, but allowed for basketball, football, soccer (though not needed) wrestling, hockey and ROTC comps. Also not allowed for gymnastics
Nov 15, 2012 at 08:03 PM
