Archive 2012 · Do you leave your vertical grip in the "on" position?
eMikey
p.1 #1 · Do you leave your vertical grip in the "on" position?
Hello all.. I was curious if you leave you vertical grips on even while your body is powered off? I assume it's not pulling any power because my top LCD shuts off when the body is powered off, even if the grip stays in the on position.
Thanks.
Nov 03, 2012 at 03:57 PM
BenV
p.1 #2 · Do you leave your vertical grip in the "on" position?
When I had one, i always just left it on
Nov 03, 2012 at 04:01 PM
leighton w
p.1 #3 · Do you leave your vertical grip in the "on" position?
I leave it on all the time.
Nov 03, 2012 at 04:07 PM
jsbeith
p.1 #4 · Do you leave your vertical grip in the "on" position?
It is on all the time.
Scott
Nov 03, 2012 at 04:27 PM
brian_sp
[X]
p.1 #5 · Do you leave your vertical grip in the "on" position?
always left mine on with no problems but now turn them off till needed, with camera slung over my shoulder i was always getting pictures of the ground as the swinging camera banging against my hip as i walked would trigger the shutter
Nov 03, 2012 at 10:52 PM
Dave_EP
p.1 #6 · Do you leave your vertical grip in the "on" position?
There's an off switch ?
Nov 04, 2012 at 04:10 AM
joshn
p.1 #7 · Do you leave your vertical grip in the "on" position?
Mine actually has no batteries in it but still works off the body power. I only put batteries in it when I need an FPS boost so it's nice and light and I get the vertical buttons. That said I do leave it on all the time.
Nov 04, 2012 at 10:50 AM
hjanssen
p.1 #8 · Do you leave your vertical grip in the "on" position?
The switch on the grip is only for the controls.
Nov 04, 2012 at 12:47 PM
runamuck
p.1 #9 · Do you leave your vertical grip in the "on" position?
The MB-D80 requires the battery be used in the vertical grip. I think the 5100 grip is the same way.
Nov 04, 2012 at 02:49 PM
JCLittle
p.1 #10 · Do you leave your vertical grip in the "on" position?
Can't seem to get mine off my D4
Nov 04, 2012 at 03:07 PM
dlabrecque
p.1 #11 · Do you leave your vertical grip in the "on" position?
I leave it on till I accidentially bump the trigger into something and my camera takes 12 closeups of my shoes/butt/pants zipper; then I turn it off.
Nov 04, 2012 at 04:55 PM
gugs
p.1 #12 · Do you leave your vertical grip in the "on" position?
All my grips always stay on the cameras. In the past there was no need to even remove them once, with the new "improved" designs, you always need to remove them to change the batteries. What a ridiculous step backwards (I guess product managers and engineers never use their products) !
Guy
Nov 04, 2012 at 05:12 PM
derry1
p.1 #13 · Do you leave your vertical grip in the "on" position?
installed on on my D300 when purchased and it never left the body,,
strongly considering one for my 800E but will hold off till the diving starts at school,, not doing much portraiture at present,,
Derry
Nov 05, 2012 at 01:17 PM
