Archive 2012 · looks like portrait professional 11 is out
jzucker
p.1 #1 · looks like portrait professional 11 is out
Odd that I never received an email about it. There's no blurb about it on their front page and I couldn't find a list of what is new. Someone on dpreview said it does auto face detection now and is much more difficult to manually select the eyes, nose and mouth if you need to override.
I downloaded but have not installed yet.
No indication whether they fixed the spot-removal noise problem
Oct 28, 2012 at 04:45 PM
Gord SW Ont
p.1 #2 · looks like portrait professional 11 is out
I haven't used it that much yet, but I don't feel that it is more diffult to manually select the eyes, nose and mouth for editting ... just use the two image view and when your mouse is on the left (before) image the edit points are available. And since the zoom works in this mode you can zoom in to get better edits than in version 10 imo.
Not sure of the spot-removal noise issue
Oct 28, 2012 at 10:38 PM
jzucker
p.1 #3 · looks like portrait professional 11 is out
it doesn't matter if i specify the plugin folder manually or just select 64 bit cs6.
Oct 29, 2012 at 06:45 AM
jzucker
p.1 #4 · looks like portrait professional 11 is out
finally got it working. Turns out it does not show up if the activation code has not been entered.
However, I'm getting out of memory errors (I only have 16GB of memory). The out of memory error says "I notice you have a 64 bit computer. You can avoid this error by upgrading to the 64 bit version".
I still haven't seen a list of what has changed. I have to admit the face recognition is pretty good.
Oct 29, 2012 at 06:22 PM
buggz2k
p.1 #5 · looks like portrait professional 11 is out
Thanks for the info.
I just upgraded my 10.0 to 10.8
Oct 31, 2012 at 06:53 PM
JBPhotog
p.1 #6 · looks like portrait professional 11 is out
v10.8 has been out for a while, nothing new of major consequence. v11 is different how it handles the files from import to retouching. I just got it so I haven't pressed it hard to find out if they fixed the spot removal noise and blotchy skin issue that was pervasive in v10.8.
Oct 31, 2012 at 07:39 PM
jzucker
p.1 #7 · looks like portrait professional 11 is out
I spoke too soon. I'm getting out of memory errors on almost every attempt as long as I'm in 16 bit mode. I never had this error before. If I downsample to 8 bit, I do not get the out of memory error.
And I was wrong before. When I get this error it does not allow me to save.
Oct 31, 2012 at 09:30 PM
JBPhotog
p.1 #8 · looks like portrait professional 11 is out
Which edition of PP v11 are you using? I'm using the PPStudio64 edition and no out of memory warning here, Mac OS though.
Also, it looks to me with my brief tests that the Spot Removal issue has been corrected somewhat.
Nov 01, 2012 at 12:55 PM
jzucker
p.1 #9 · looks like portrait professional 11 is out
i have the pro version (not the 64 bit version). I'd be happy to upgrade to the 64 bit version but I'd like to have them acknowledge the problem and explicitly guarantee what and why the 64 bit version solves it since I never had the issue with version 10
Nov 02, 2012 at 07:02 AM
JBPhotog
p.1 #10 · looks like portrait professional 11 is out
Not sure which OS you are using but I assume you have seen this page http://www.portraitprofessional.com/support/?page=kb_view&id=65
It is a bit odd since the 32 bit version will run on both 32 and 64 bit OS's while the reverse is not true. Their edition sales pitch states:
Standard: For amateur photographers working with JPG or 24-bit TIFF files.
Studio: For amateur or professional photographers who work directly with RAW files or want the higher quality of 48-bit colors.
Studio 64: For professional photographers or those working with very large images.
So although they don't state it specifically(as in max file size), maybe the Studio version is choking on large files due to the new code in v11? Time to open a ticket with them if you haven't already done so.
Nov 02, 2012 at 12:45 PM
Tom Rouse
p.1 #11 · looks like portrait professional 11 is out
Are you guys using the trail version? I was wondering if the trail version was v11.
Thanks/Tommy
Nov 02, 2012 at 03:49 PM
JBPhotog
p.1 #12 · looks like portrait professional 11 is out
Nope, paid upgrade and my PPStudio64 version is 11.0.33.
Nov 02, 2012 at 07:27 PM
RDKirk
p.1 #13 · looks like portrait professional 11 is out
I have noticed that some PP plug-ins use the scratch disk even if you are using 64-bit PP and have plenty of ram. My suspicion is that they're using the same old kernel written for a 32-bit machine with max 4 gigs of ram--designed always to go to scratch disk.
I wonder if that's not the case with the 32-bit version of PP. I suspect it runs on a 64-bit machine but "thinks" it's on a ram-limited 32-bit machine.
Nov 03, 2012 at 09:42 AM
mshi
[X]
p.1 #14 · looks like portrait professional 11 is out
Blurring the skin to remove its texture is so 1999. Why people are still using that bad technique 13 years later?
Nov 03, 2012 at 09:53 AM
JBPhotog
p.1 #15 · looks like portrait professional 11 is out
Sounds like you haven't explored the software, blurring is not what it does.
Nov 03, 2012 at 11:28 PM
mshi
[X]
p.1 #16 · looks like portrait professional 11 is out
No, I haven't. But looking at their before/after images on their web site has turned me off completely already. My lowly taste prefers native skin texture, not the uniform artificial texture added using High Pass filter.
Nov 04, 2012 at 02:47 AM
RDKirk
p.1 #17 · looks like portrait professional 11 is out
I have many clients who don't like their native skin texture. In fact, I had one yesterday who made a point after our session to tell me so (just in case I didn't realize it).
Nov 04, 2012 at 11:57 AM
JBPhotog
p.1 #18 · looks like portrait professional 11 is out
Personally, the marketing department at Anthropics went way to far to show what the software can do. Some may like it but I dial it back quite a bit and clients love the results. I also disable the face sculpting in v10, I didn't like the artifacts at the edges of the warp. I haven't tried it in v11 yet but the skin texture is more refined from v10.
Nov 05, 2012 at 01:37 AM
mshi
[X]
p.1 #19 · looks like portrait professional 11 is out
this is what my lowly taste prefers in terms of preserving skin textures.
retoucher: Natalia Traffarel
http://fc08.deviantart.net/fs17/f/2007/192/b/2/Gab__s_retouch_01_by_NataliaTaffarel.jpg
http://fc04.deviantart.net/fs24/f/2007/328/b/2/t_h_e___f_a_c_e_by_NataliaTaffarel.jpg
Nov 05, 2012 at 02:00 AM
LisaD
p.1 #20 · looks like portrait professional 11 is out
http://fc04.deviantart.net/fs24/f/2007/328/b/2/t_h_e___f_a_c_e_by_NataliaTaffarel.jpg[/quote
Yes to that. Natalia is amazing, love her work!
Jealous
Nov 06, 2012 at 11:05 PM
