Archive 2012 · G1X lacks close focusing ability
Jim Quinn
p.1 #1 · G1X lacks close focusing ability
I've carried a Canon G9 in a belt pouch for years. I know some find the G series too big in relation to its sensor, but I've found it to be a useful go-anywhere tool. I really enjoy its close focusing. I can make tight closeup photos easily, without the need to add extension tubes or other devices to a DSLR.
When the G1X was announced, I read about its features (including its articulated finder and larger sensor) and decided to take a closer look at a local store. I was really disappointed to see that the new camera had nowhere near the same ability to take quick closeups. It's impossible to get sharp focus at the distances I have found useful with the G9.
A clerk at the store searched a Canon catalog and found that the company makes telephoto and wide-angle adapters for the G1X, but she couldn't find anything that would allow me to attach a closeup lens in front of the camera's zoom.
If anyone here has a convenient way to create this missing function in the G1X, I'd like to know about it. Otherwise I'll just have to look at products from other manufacturers. Thanks!
Oct 27, 2012 at 04:56 PM
RobDickinson
p.1 #2 · G1X lacks close focusing ability
Does it have a thread? you could add a 500d if it does.
Oct 27, 2012 at 05:44 PM
Jeff Nolten
p.1 #3 · G1X lacks close focusing ability
The principal design feature of the G1X is its nearly APS C sized sensor (1.8X crop vs APS C's 1.6X). It has six times the sensor area compared to the G12 or G15. This means that the lens must accommodate this much larger area. While Canon has managed to keep the lens compact in size compared to an equivalent EFs kit lens, the close focus ability is not up to previous G series cameras without external diopter lenses.
Fortunately a closeup filter like the Canon 250D can mount on the G1X with a simple filter adaptor available from Lensmate. These are universally backordered but I found mine on eBay new for about list price. The 250D is a 4 diopter filter which I think yields higher magnification than a G10 can achieve by itself. Hoya makes a 3 diopter closeup filter that should also work well. The Canon 500D is 2 diopters and may not be strong enough, but is another option. The filter adaptor is threaded 58 mm and can also take a polarizer.
The G1X offers better image quality than any other G series but its cost, diminished close focus, and somewhat slower performance are tradeoffs. If you like the G series but IQ is not your ultimate goal you might look at the G15 which is closer in design to previous Gs.
Oct 27, 2012 at 05:52 PM
RobDickinson
p.1 #4 · G1X lacks close focusing ability
Probably the close focus distance is similar to the g12 but the lower pixel density and larger sensor work against it as said above.
Oct 27, 2012 at 06:00 PM
Gunzorro
p.1 #5 · G1X lacks close focusing ability
+1
Excellent advice Jeff!
I have a G10, and love that, but have been waiting for used G1X prices to come down. I like the close-up ability and quick focus of the G10 and know I would sacrifice with the current G1X, but the IQ seems to be worth it to me.
The moral of the story is that no system is absolutely perfect in all respects. But the G1X looks very appealing as a "carry anywhere" for snapshots, travel, and mid-distance shots.
Oct 27, 2012 at 06:05 PM
davenfl
p.1 #6 · G1X lacks close focusing ability
Good advice on the use of the Canon 500D/250D closeup lens with an adapter.
For those looking for a good price on the the G1X Adorama is running a rebate deal combined with the inexpensive Canon 9000 printer which nets a price of $399 for the pair (discussed here recently). B&H has a similar deal but just a tad more expensive.
https://www.fredmiranda.com/forum/topic/1160815/0?keyword=G1X#11070707
Dave
Oct 27, 2012 at 06:28 PM
JameelH
p.1 #7 · G1X lacks close focusing ability
Hoya also sells a set of +1, +2 and +3 diopters (58mm) that you can attach with the lensmate adapter. See this FS listing as an example.
https://www.fredmiranda.com/forum/topic/1135127/0?keyword=G1x#10836000
Oct 27, 2012 at 07:15 PM
scottam10
p.1 #8 · G1X lacks close focusing ability
Agree, I don't know much about optical design but generally wide angle lenses can focus closer than telephotos - compare the min focal distance of the EFS 10-22mm (24mm) with the min focal distance of the 70-200mm zoom (about 1.2m)
Similarly, the actual focal length of the G1X with its APSC sensor is much longer than the actual focal length of the lens on a smaller-sensor point and shoot (eg my G9 has a 7.4mm - 44.4mm lens which gives a 35mm equivalent range of 35-210mm) - the lens on the G1X is much longer (15mm-60mm)
Point and shoots will often have very good macro ability, whereas SLR lenses are a lot more limited in close focus ability, and you need a dedicated macro lens or extension tubes/closeup lens to get good closeups.
It just seems to be an unfortunate tradeoff: with a larger sensor, macro becomes more difficult.
Oct 27, 2012 at 07:47 PM
Jeff Nolten
p.1 #9 · G1X lacks close focusing ability
A note on close focus filters, the Canon 250D, 500D and Hoya +3 are dual element lenses. These correct distortion much better than single element diopter sets but cost more.
Oct 27, 2012 at 08:37 PM
Jim Quinn
p.1 #10 · G1X lacks close focusing ability
Great thoughts, everybody. Many thanks! Jeff, thanks for the link to Lens Mate and its adapter. After a few more searches, I found out that Canon makes a similar ring, FA-DC58C, for more money than the Lens Mate item. Amazon is selling some aftermarket rings starting at $10 (http://www.amazon.com/Adapter-PowerShot-Required-Replaces-FA-DC58C/dp/B007YYZLHW). So somewhere out there, it should be possible to find an adapter to hold a closeup lens. Jameel, thanks for the tip on the Hoya filter set.
I have been unable to find the $399 Adorama G1X/printer deal, though. The lowest prices I've seen so far are well into the $500 range. If that's still out there, I'd appreciate knowing about it. Thanks!
Oct 28, 2012 at 12:14 AM
davenfl
p.1 #11 · G1X lacks close focusing ability
I pointed it out in my previous post but here is a direct link. Camera and printer are $799 minus the $400 rebate linked on the web page netting $399.
http://www.adorama.com/ICAG1XZ.html?utm_term=Other&utm_medium=Affiliate&utm_campaign=Other&utm_source=rflaid62905
Dave
Oct 28, 2012 at 12:41 AM
Jim Quinn
p.1 #12 · G1X lacks close focusing ability
Dave, thanks very much for that link.
Oct 28, 2012 at 02:59 AM
Jeff Nolten
p.1 #13 · G1X lacks close focusing ability
I've been using Lensmate adaptors since my G3, they are very well made. According to reports over on the DPR P&S forum, the filters tend to get stuck on the Canon adaptors while Lensmate uses a better plastic that lessens this. I have the Canon adaptors but I have two, one for my 250D and one for my polarizer, so I don't have to re-thread filters.
Oct 28, 2012 at 12:54 PM
Chrissearle
p.1 #14 · G1X lacks close focusing ability
Yep, close focussing ( although not true macro) is easily and relatively cheaply available on the G1X via the magic of ebay, I bought an adaptor and a set of three close up lenses for less than thirty quid and they work very well indeed.
Oct 31, 2012 at 02:27 PM
Jeff Nolten
p.1 #15 · G1X lacks close focusing ability
B&H just notified me that they now have 58 mm 250D close-up filters in stock, $90. Evidently Canon if finally shipping them again.
Oct 31, 2012 at 05:00 PM
