Archive 2012 · 24-70 & 82mm filter
rprouty
p.1 #1 · p.1 #1 · 24-70 & 82mm filter
This may have been discussed before but why does the new Canon 24-70 have a filter size of 82mm. It's still a f/2.8 so what changed?
Thanks
Rod
Oct 25, 2012 at 06:06 PM
p.1 #2 · p.1 #2 · 24-70 & 82mm filter
82 is the new 77.
I don't mind, at least not now. My first 82mm was a Zeiss 21/2.8 ZE, then a Canon TS-E 24/3.5L II. For these lenses, I bit the bullet and bought an 82mm B+W MRC Clear filter (one) and an 82mm KSM CP filter. Now I can use them on my new 24-70/2.8L II. It hurts a bit when you first look at the price of these puppies.
BTW, I'm very happy to say that I found my 82mm KSM yesterday - I hadn't been able to find it since using it this summer in Utah. Big sigh of relief.
Oct 25, 2012 at 08:38 PM
ben egbert
p.1 #3 · p.1 #3 · 24-70 & 82mm filter
Just a guess, but I suspect they need a larger front element to get sharper corners and edges. This has been the weakness of Canon zooms below 70mm
Oct 25, 2012 at 08:46 PM
S Dilworth
p.1 #4 · p.1 #4 · 24-70 & 82mm filter
The filter size doesnít depend on the f-number, but rather, the front element size and the need to avoid artificial vignetting.
The new Canon 24-70 mm changed from a negative-lead zoom type to a positive-lead type, resulting in its larger front element. Other positive-lead 24-70 mm f/2.8 zooms like the Tamron and Sigma have 82 mm filter threads for the same reason.
Oct 25, 2012 at 09:41 PM
rprouty
p.1 #5 · p.1 #5 · 24-70 & 82mm filter
Thanks for the replys, I'm old and don't know all that there technical stuff.
Oct 25, 2012 at 09:47 PM
S Dilworth
p.1 #6 · p.1 #6 · 24-70 & 82mm filter
Iím young and I donít!
Section 1 of this page talks about positive-lead versus negative-lead zooms, and shows a helpful diagram. Itís for another lens, but the basic idea is the same.
Oct 25, 2012 at 09:50 PM
rprouty
p.1 #7 · p.1 #7 · 24-70 & 82mm filter
Thanks Samuel, that was a good read about positive vs. negative.
Rod
Oct 25, 2012 at 09:55 PM
