Archive 2012 · W I D E Seamless needed- Can you place two together?
Lance_K
p.1 #1 · W I D E Seamless needed- Can you place two together?
I need to shoot an object that has a 16 foot wingspan on white seamless. Is it possible to layer two 11.6 foot seamless together to make the background wider?
How would you do that? C stands with Arms or something? I think i can see it done in my mind but wanted to check first.
Oct 23, 2012 at 05:25 PM
hugowolf
p.1 #2 · W I D E Seamless needed- Can you place two together?
I did something a couple of years ago with two rolls of seamless white, I think I had a gap of a couple of inches and just fixed it in post porcessing.
Brian A
Oct 23, 2012 at 06:51 PM
cordellwillis
p.1 #3 · W I D E Seamless needed- Can you place two together?
Depending on the subject you may want to also use white tape to cover the seam as much as possible. Even masking tape is better than no tape to cover the gap. This can help when it comes to post processing because the gap will be closed (less noticeable) just a little more.
Oct 24, 2012 at 08:01 AM
eSchwab
p.1 #4 · W I D E Seamless needed- Can you place two together?
It's going to be hard because of the way that you support it. There will be a gap in the middle unless you find a way to clamp the whole roll at one end where it overlaps. Otherwise there will be a gap where your pipe comes out the end and needs to be supported.
Oct 24, 2012 at 09:53 AM
_Rob_S_
p.1 #5 · W I D E Seamless needed- Can you place two together?
Can you run the seamless sideways? If you then need more height, you could tape two or more together with the seams running horizontal. In any event, you will likely have some cleanup in post to deal with...
Rob
Oct 24, 2012 at 10:04 AM
PeterBerressem
p.1 #6 · W I D E Seamless needed- Can you place two together?
It may be easier to support a super wide white muslin, if this is an option.
www.rosebrand.com/fabric-stage-curtains-backdrops/muslin.aspx?sid=yPl6T6nZ8XB2la4T%2bCs7v%2bxyOVzESwuXA9pw61TKOFiTR%2bce2vCIDA%3d%3d
You can support a long 2x4 wooden beam unnoticed by a stand midway....
Oct 24, 2012 at 10:52 AM
BrianO
p.1 #7 · W I D E Seamless needed- Can you place two together?
Another option would be to simply cut off from the roll(s) the lengths you need, and tack the resulting sheets -- slightly overlapping -- to a wall (or a length of 1X12 supported at the ends if you need a free-standing BG.)
Paper's (relatively) cheap, so if you don't absolutely need to reuse it, this would be the easiest way.
Oct 25, 2012 at 12:36 AM
jeremymeier
p.1 #8 · W I D E Seamless needed- Can you place two together?
You may be able to find a studio in your area with a cyc wall that you could rent for an hour or so for not too much money... We have a place you could easily shoot a school bus in for $400. Per day, so hourly might be worth it...
Nov 10, 2012 at 04:56 PM
