Archive 2012 · AF fine tune on or off?
311erin
p.1 #1 · AF fine tune on or off?
I thought it might be interesting to see how many people do or don't use the AF fine tune feature and why, since the use and test methods are nearly a religious endeavor.
Myself, I turn it off in both my D4 and D800E and get great results with four different lenses, three 1.4's and a 2.8. My results when turning AF fine tune on and calibrating, or far more erratic than with it off. I think Nikon is right in warning not to turn it on unless you have a specific problem.
Oct 13, 2012 at 02:24 PM
BenV
p.1 #2 · AF fine tune on or off?
if its needed, i use it
Oct 13, 2012 at 02:30 PM
jojomon11
p.1 #3 · AF fine tune on or off?
depends which camera
Oct 13, 2012 at 02:42 PM
mfletch
p.1 #4 · AF fine tune on or off?
Same here. I have one lens(Sigma 50) that needs some adjustment, probably only noticable because of the thin DOF. Most of my primes don't really need adjustment, and the FineTune is pretty useless with a zoom lens.
Andre Labonte
p.1 #5 · AF fine tune on or off?
The one time I needed it, the lens needed to be calibrated. Once the lens was calibrated, I shut it off.
Oct 13, 2012 at 04:20 PM
myam203
p.1 #6 · AF fine tune on or off?
I don't obsess over it, but if I use a new lens and notice that it's missing focus, I will make some rough adjustments until I'm happy.
Oct 13, 2012 at 04:27 PM
trenchmonkey
p.1 #7 · AF fine tune on or off?
To each his own re: "fine tune" 5 bodies (4 capable) with 9 lenses. Zero AF fine tune on any.
Lucky, perhaps....I dunno. I shoot, I sell. Not measurebating has set me free to enjoy my craft.
Oct 13, 2012 at 04:46 PM
Creative Edge
p.1 #8 · AF fine tune on or off?
I shoot, I sell, I fine tune :-)
Oct 13, 2012 at 04:56 PM
trenchmonkey
p.1 #9 · AF fine tune on or off?
Yet, I didn't have to fine tune the 200 f2 VR I bought from you...just sayin'
(and if you're gonna use "I shoot, I sell" ya owe me a beer)
Oct 13, 2012 at 05:08 PM
Creative Edge
p.1 #10 · AF fine tune on or off?
Monkey I owe you a beer :-)
Oct 13, 2012 at 05:23 PM
trenchmonkey
p.1 #11 · AF fine tune on or off?
Oct 13, 2012 at 05:29 PM
Hendrik
p.1 #12 · AF fine tune on or off?
My D200 is perfect with my 24-70 and 70-200 lenses. It doesn't have AF adjustment.
My D800 needs -14 for the central sensor on my 24-70; but the right and especially left is too bad. The camera needs a repair.
I would always use it, when needed.
Oct 14, 2012 at 04:59 AM
Red Rover
p.1 #13 · AF fine tune on or off?
It is pretty simple to check if a lens/body combo needs to be AF fine tuned. It's not like it's on or off, you either adjust + or - to fine tune the AF or you don't. Different lenses may require different adjustments and some none at all, even when they are all used on the same body.
You can make it complicated with gadgets and/or software if you want to, but there are some pretty simple ways to test for it.
I used the method in this link and discovered my D7000 / 17-55 f 2.8 combo still slightly back focused even with the AF Fine Tune at -20. It also contains a good explanation of how AF sensors work.
I sent the combo to Nikon for callibration. I am glad to have the feature available.
http://focustestchart.com/focus21.pdf
Oct 14, 2012 at 09:07 AM
sjms
p.1 #14 · AF fine tune on or off?
my lenses are all dialed in on the bodies so both bodies i own are switched on.
Oct 14, 2012 at 10:56 AM
wcowan
p.1 #15 · AF fine tune on or off?
I dial in all new lenses on my D700, then I don't worry about it. Most of them are within +/-5.
Oct 14, 2012 at 07:08 PM
davidnholtjr
p.1 #16 · AF fine tune on or off?
Never used fine tune, never really seemed to need it. So I voted #3.
Oct 15, 2012 at 06:53 PM
Cliff L.
p.1 #17 · AF fine tune on or off?
Leave it off - no reason to use it unless you get a bad lens.
Oct 16, 2012 at 08:11 PM
Doug Maclean
p.1 #18 · AF fine tune on or off?
I did a ridiculous amount of shots with every lens I had with a d7000.Found plus 15 is the sweet spot on my 300 f4 but the other lens needed nothing..go figure.Anyway camera remembers the lens and applies a plus 15 and it is stupid sharp now. Doug M
Oct 16, 2012 at 09:30 PM
Hendrik
p.1 #19 · AF fine tune on or off?
Most of the time the lenses are fine, it's the camera.
Oct 17, 2012 at 01:17 PM
Next39
p.1 #20 · AF fine tune on or off?
FWIW, my D7000 needed some tuning with a few of my lenses, but my D3s is spot on perfect with every combination.
Oct 17, 2012 at 01:59 PM
