Does the 6D actually have 19 AF points?
stargazer78
p.1 #1 · Does the 6D actually have 19 AF points?
I saw this interesting piece of detective work at dpreview by someone named hpjfromdk.
It appears as though the EOS 6D may have up to 8 invisible assist points surrounding the center AF point. The AF points aren't mentioned in any of Canon's marketing literature. However, a close inspection of the 6D AF sensor chip seems to reveal their presence:
So there is a possibility that the EOS 6D may have a 19-point AF system after all. 11 selectable, 8 non-selectable, and 3 high precision with f2.8 lenses.
Oct 11, 2012 at 06:04 PM
Ralph Conway
p.1 #2 · Does the 6D actually have 19 AF points?
Interesting. But wich are the three?
Oct 11, 2012 at 06:10 PM
stargazer78
p.1 #3 · Does the 6D actually have 19 AF points?
Center AF point, and the two assist points directly above & below it. Just like the 5D2.
Oct 11, 2012 at 06:12 PM
kewlcanon
p.1 #4 · Does the 6D actually have 19 AF points?
Canon cripples it .
Oct 11, 2012 at 06:21 PM
Ralph Conway
p.1 #5 · Does the 6D actually have 19 AF points?
kewlcanon wrote:
Canon cripples it .
Yes! Again and again ... !
Oct 11, 2012 at 06:27 PM
skibum5
p.1 #6 · Does the 6D actually have 19 AF points?
hmm i think i better get my 5D2 sold fast
Oct 11, 2012 at 07:05 PM
abqnmusa
p.1 #7 · Does the 6D actually have 19 AF points?
The 5D and 5D II had 6 assist points for AI Servo use ....
see the 5D II manual; page 80, 83,
page 198 -- custom function III-7 enables the 6 assist points
so actually 15 focus points total
-- 9 focus points plus 6 hidden assist points around the center point
Oct 11, 2012 at 07:15 PM
skibum5
p.1 #8 · Does the 6D actually have 19 AF points?
Yeah they do but the thought had been that the 6D had gotten rid of them, now it seems perhaps not.
Oct 11, 2012 at 07:31 PM
n0b0
p.1 #9 · Does the 6D actually have 19 AF points?
Doesn't matter, you still have to focus and recompose.
Oct 11, 2012 at 07:39 PM
stargazer78
p.1 #10 · Does the 6D actually have 19 AF points?
If you're talking about all the peripheral AF points being non-cross type... then you can make the same complaint about every single Nikon DSLR out there. Including the D4 and D800.
Oct 11, 2012 at 08:27 PM
jorkata
p.1 #11 · Does the 6D actually have 19 AF points?
Note that this is a possible AF point mapping. It's not been confirmed by Canon.
The AF sensor, though, shows that the center AF point has been beefed up quite a bit.
So, auto focus with only the center AF point should be an improvement over the 5Dc/5DII.
Maybe more so if those hidden AF points are active all the time.
Oct 11, 2012 at 08:49 PM
joeisayo
p.1 #12 · Does the 6D actually have 19 AF points?
Honestly I would rather have the 11 point AF system of the 6D with -3 EV center point over the 19 focus point, -1 EV of the 7D.
Oct 11, 2012 at 10:21 PM
thw2
p.1 #13 · Does the 6D actually have 19 AF points?
Good to know
Precisely. The D600 is probably the most offensive because all the cross AF sensors are tightly clustered around the middle.
Oct 11, 2012 at 10:53 PM
n0b0
p.1 #14 · Does the 6D actually have 19 AF points?
Why would I? I don't use Nikon system.
I'd rather have the 60D or even better, the 7D AF in the 6D. I could focus fine inside dark caves with the 7D so I can't see any real world advantage of that -3EV focus capability.
Oct 12, 2012 at 01:15 AM
RobertLynn
p.1 #15 · Does the 6D actually have 19 AF points?
Lordy Lordy look who's 40.
Oct 12, 2012 at 01:48 PM
ardvorak
p.1 #16 · Does the 6D actually have 19 AF points?
What is the center point sensitivity of the 5DIII? I think I remember reading that it was -2EV?
Will the 6D's added sensitivity really translate to performance you can feel in dim lighting? My understanding is that the 5DIII is already very snappy.
Oct 12, 2012 at 03:19 PM
RobertLynn
p.1 #17 · Does the 6D actually have 19 AF points?
It is -2.
Oct 12, 2012 at 10:04 PM
CW100
p.1 #18 · Does the 6D actually have 19 AF points?
extra AF points are good, even if they are invisible
Oct 13, 2012 at 11:08 AM
bushwacker
p.1 #19 · Does the 6D actually have 19 AF points?
here's my question...
It's a fact the 6D can go up to -3V... it's a given. The -3V is this for all AF points or just the center?
Oct 14, 2012 at 11:25 AM
Dietrich
p.1 #20 · Does the 6D actually have 19 AF points?
Just the center - all other points are specified to work from +0.5 to 18 EV.
Oct 14, 2012 at 07:25 PM
