       2       3       end
Archive 2012 · Qustion on Gitzo three-leg carbon fiber tripod
epphoto
p.1 #1 · Qustion on Gitzo three-leg carbon fiber tripod
OK Im looking to buy a 3 leg carbon fiber tripod from Gitzo with leveling base
can you please help me with Gitzo? I got so confused
Thanks
Oct 10, 2012 at 11:02 PM
dcains
p.1 #2 · Qustion on Gitzo three-leg carbon fiber tripod
Is this what you're looking for?
http://www.bhphotovideo.com/c/product/568869-REG/Gitzo_GT2531LVL_GT2531LVL_Leveling_6X_Carbon.html
FWIW, I've got the 4-section version (GT2540LVL), and it's a great tripod.
Oct 11, 2012 at 12:49 AM
epphoto
p.1 #3 · Qustion on Gitzo three-leg carbon fiber tripod
I was looking one with leveling base
Thanks
Oct 11, 2012 at 04:54 AM
EB-1
p.1 #4 · Qustion on Gitzo three-leg carbon fiber tripod
What other kind is there? You want a tripod with 4 legs?
I use a 3531LS with the RRS leveling base. I strongly recommend the RRS base as it weighs half as much as the Gitzo leveling base. Here is the one you should order, because it has the longer handle.
Oct 11, 2012 at 06:11 AM
dcains
p.1 #5 · Qustion on Gitzo three-leg carbon fiber tripod
Thanks
That tripod has a leveling base built in, thus the LVL designation in its model number.
Oct 11, 2012 at 06:18 AM
epphoto
p.1 #6 · Qustion on Gitzo three-leg carbon fiber tripod
Thanks my friend
Its leveling colom I'm looking for leveling base
Oct 11, 2012 at 06:25 AM
epphoto
p.1 #7 · Qustion on Gitzo three-leg carbon fiber tripod
Haha!! I made a mistake
Thanks but I'm not looking for RRS
Oct 11, 2012 at 06:29 AM
dcains
p.1 #8 · Qustion on Gitzo three-leg carbon fiber tripod
Do you want just the leveling base, so you can remove it from the tripod when not needed? The built in leveling base in the Gitzo LVL tripods is lighter and more compact than adding a separate leveling base to a regular tripod, but it works exactly the same (15 degrees of adjustment, I believe).
From the description on the B&H page: This Leveling tripod has a ball joint-mounted center column designed to let you get your camera perfectly level simply by adjusting the column inclination, instead of having to set each leg individually.
Oct 11, 2012 at 06:32 AM
dcains
p.1 #9 · Qustion on Gitzo three-leg carbon fiber tripod
I can post some detailed pics of mine later, if you need them. Let me know.
Oct 11, 2012 at 06:44 AM
sjms
p.1 #10 · Qustion on Gitzo three-leg carbon fiber tripod
legs
http://www.bhphotovideo.com/c/product/846212-REG/Gitzo_GT3532S_GT3542LS_6x_4_SECTION_SYSTEMATIC.html
platform/base/halfball
http://www.bhphotovideo.com/c/product/569209-REG/Gitzo_GS5121LVL_GS5121LV_Leveling_Base.html
the other option is to go straight to the top and not look back:
legs HD
http://reallyrightstuff.com/ProductDesc.aspx?code=TVC-33&type=4&eq=&desc=TVC-33-Versa-Series-3-Tripod&key=it
platform/base/halfball HD
http://reallyrightstuff.com/ProductDesc.aspx?code=TA-3-LB&type=0
legs RD
http://reallyrightstuff.com/ProductDesc.aspx?code=TVC-23&type=4&eq=&desc=TVC-23-Versa-Series-2-Tripod&key=it
platform/base/halfball RD
http://reallyrightstuff.com/ProductDesc.aspx?code=TA-2-LB&type=0
Edited on Oct 11, 2012 at 06:56 AM · View previous versions
Oct 11, 2012 at 06:49 AM
epphoto
p.1 #11 · Qustion on Gitzo three-leg carbon fiber tripod
This is exactly what i was looking to get !!
Question for you, Gitzo has lots of tripods do you know of any to spent total of $800.00??
like an older model or something
Thanks for your help
sjms wrote:
legs
platform/base
Oct 11, 2012 at 06:53 AM
dcains
p.1 #12 · Qustion on Gitzo three-leg carbon fiber tripod
Great choice if you need a 3-series. The LVL class tripods only come in 2-series, which is smaller and lighter, and the center column can not be removed.
EB-1
p.1 #13 · Qustion on Gitzo three-leg carbon fiber tripod
I meant just the leveling base, not the tripod. The Gitzo leveling base is very heavy. You'll see.
Oct 11, 2012 at 07:01 AM
sjms
p.1 #14 · Qustion on Gitzo three-leg carbon fiber tripod
as a kit together i will have to say no.
they are coming out with lighter duty models similar to RRS. unfortunately for you they to will command a higher price. they will be the series 2 systematic models.
http://www.gitzo.us/product/72038.71837.72020.0.0/GT2532S/_/SYSTEMATIC_Series_2_carbon_tripod%2C_3-section_standard_level
if your in this pricing i'd be looking into RRS for a better design, functionality, lighter weight better built.
at this point i know of no other manufactures other the RRS and Gitzo that offers the level of quality and versatility they both bring to the market.
Oct 11, 2012 at 07:02 AM
epphoto
p.1 #15 · Qustion on Gitzo three-leg carbon fiber tripod
Thank you my friend !!
Oct 11, 2012 at 07:07 AM
dcains
p.1 #16 · Qustion on Gitzo three-leg carbon fiber tripod
That new 2-series systematic is actually a few ounces heavier than my GT2540LVL, even without a leveling function, column, and 4-section legs. At that price RRS is looking like the better choice.
Oct 11, 2012 at 07:33 AM
epphoto
p.1 #17 · Qustion on Gitzo three-leg carbon fiber tripod
I find out 4 section tripods are not my think
I got use to 3 section for 7 years now,I had one and sold it
Thanks again
Oct 11, 2012 at 07:43 AM
sjms
p.1 #18 · Qustion on Gitzo three-leg carbon fiber tripod
i use 3 and 4 section models interchangeably. the only 3 section one i have out of the 3 i use is my largest the RRS TVC33 and that is setup with the leveling head. the mid sized one used to be my travel and is still my close up/macro setup which is a Gitzo GT2540ex (explorer) where the 4 section legs are a definite plus. last and the most recent add on is the RRS TQC14 which is as rigid as a 25xx series Gitzo but more compact and lighter but supports in the same range.
at this point my golf bag of tripods is complete.
Oct 11, 2012 at 07:58 AM
dcains
p.1 #19 · Qustion on Gitzo three-leg carbon fiber tripod
When you're dealing with Gitzo's G-Lock legs, the 4-section are just as stable as the 3. Wish I could say I've had experience with the RRS tripods, but it's a sure bet the same is true.
Oct 11, 2012 at 11:29 AM
sjms
p.1 #20 · Qustion on Gitzo three-leg carbon fiber tripod
It is
Oct 11, 2012 at 02:44 PM
       2       3       end
       2       3       end
