Archive 2012 · Leica R 19/2.8 VS Zeiss 21/2.8
Paul Yi
p.1 #1 · Leica R 19/2.8 VS Zeiss 21/2.8
Has anyone used both lenses?
I'd like to get some input on the pros and cons in comparing the two lens.
I have used Zeiss 21 briefly, but have no experience with the leica 19mm lens.
How is the distortion on Leica 19mm?
I'm looking for an ideal lens for a landscape.
Thank you in advance for kind inputs.
Oct 08, 2012 at 09:04 AM
plasticmotif
p.1 #2 · Leica R 19/2.8 VS Zeiss 21/2.8
http://16-9.net/lens_tests/best19_21.html
his results mirror my findings.
the ZE 21, is better than the C/Y 21 as well.
I also found this article:
http://diglloyd.com/articles/ask/lenses-D3x-Zeiss-Leica.html
Oct 08, 2012 at 11:12 AM
Toothwalker
p.1 #3 · Leica R 19/2.8 VS Zeiss 21/2.8
Does the last statement also mirror your findings?
Oct 08, 2012 at 11:41 AM
FlyPenFly
p.1 #4 · Leica R 19/2.8 VS Zeiss 21/2.8
Wow not much between the Olympus F2 and F3.5. Considering how much smaller and less than half the price it is, I'm surprised it's so close.
Oct 08, 2012 at 12:09 PM
S Dilworth
p.1 #5 · Leica R 19/2.8 VS Zeiss 21/2.8
In what way do you find it better?
plasticmotif
p.1 #6 · Leica R 19/2.8 VS Zeiss 21/2.8
Native mounts, auto-aperture, new coatings.
Oct 08, 2012 at 12:12 PM
FlyPenFly
p.1 #7 · Leica R 19/2.8 VS Zeiss 21/2.8
A new production unit is likely to be closer to factory calibration than an older used one.
Oct 08, 2012 at 12:18 PM
telyt
p.1 #8 · Leica R 19/2.8 VS Zeiss 21/2.8
OTOH, a well-used sample may have been used for good reason:
http://16-9.net/lens_tests/28mm_2.html
Oct 08, 2012 at 12:36 PM
FlyPenFly
p.1 #9 · Leica R 19/2.8 VS Zeiss 21/2.8
I don't think a sample comparison of 2 copies is really that valid.
If anything, Lens Rental Blog showed how much variance there is!
My next big step in photography I think will be to learn how to effectively use test charts and compare the numbers against other findings.
Oct 08, 2012 at 12:40 PM
JimUe
p.1 #10 · Leica R 19/2.8 VS Zeiss 21/2.8
what do you look for in a "landscape lens"?
judging by this sample image library:
http://forum.xitek.com/thread-619411-1-1-1.html
compared to a z21/2.8 z*, the leica 19/2.8v2 has 'leica colours', and softer everywhere but the centre. distortion seems well controlled though.
fyi here's another comparison test, but i didn't find it all that informative: http://www.16-9.net/lens_tests/canon1635ii_a/c1635ii_a2.html
Oct 08, 2012 at 12:59 PM
Toothwalker
p.1 #11 · Leica R 19/2.8 VS Zeiss 21/2.8
Very well, but none of these qualities is related to the three performance measures on that 16-9.net page.
Oct 08, 2012 at 01:38 PM
plasticmotif
p.1 #12 · Leica R 19/2.8 VS Zeiss 21/2.8
That article was written before Zeiss released the new 21. So, I elaborated. The newer 21 is better.
Oct 08, 2012 at 05:17 PM
Paul Yi
p.1 #13 · Leica R 19/2.8 VS Zeiss 21/2.8
Thank you all for the kind input....
I think I'll go for the ZE21 ....
Oct 08, 2012 at 07:22 PM
freaklikeme
p.1 #14 · Leica R 19/2.8 VS Zeiss 21/2.8
I can't believe the f/2 scored that well. I liked the lens, but it was not something I'd put up as wide-angle perfection.
Oct 08, 2012 at 10:12 PM
freaklikeme
p.1 #15 · Leica R 19/2.8 VS Zeiss 21/2.8
If you're shooting it on a Canon, Paul, that's the best choice anyway. The 19 vII fouls Canon FF mirrors without something getting shaved. And the first version, which doesn't foul the mirror, is good, but introduces distortion issues (like the gull-wing distortion) not evident in the second version.
Oct 08, 2012 at 10:14 PM
philip_pj
p.1 #16 · Leica R 19/2.8 VS Zeiss 21/2.8
'Native mounts, auto-aperture, new coatings.'
'The newer 21 is better.'
Unfortunately - since few have the chance or the inclination to buy the Contax version - no.
The glass selection is doubtless very different:
"Lens cross-section of the Distagon 2.8/21 for the Contax SLR, a relatively complex lens with 15 elements in 13 groups. However, it had no aspherical surfaces. Its performance, particularly the perfect correction of lateral chromatic aberration, was achieved solely by the combination of very special (and expensive) high-index glass types with glass types displaying extremely high anomalous partial dispersion."
You can view the astounding MTF chart on page 6 of this document:
http://blogs.zeiss.com/photo/en/wp-content/uploads/2011/12/en_CLB41_Nasse_LensNames_Distagon.pdf
There are very good reasons why the market retains such incredible value in the Contax version.
Oct 09, 2012 at 01:47 AM
sebboh
p.1 #17 · Leica R 19/2.8 VS Zeiss 21/2.8
that doesn't sound like it has anything to do with photography.
Oct 09, 2012 at 01:55 AM
timballic
p.1 #18 · Leica R 19/2.8 VS Zeiss 21/2.8
The ZE 21 weighs 720g (Hard to find info as every spec sheet only gives the ZF.2 weight which is less)
The C/Y 21 is 550g + adapter. Over 100g difference.
Oct 09, 2012 at 11:58 AM
Edgars Kalnins
p.1 #19 · Leica R 19/2.8 VS Zeiss 21/2.8
I remember people being worried about the performance of the new 21mm Distagon before it was released. Even though Zeiss have changed the glass it seems to have no negative impact. The MTF shows improvement with the new design.
Your link does not open on my PC. here are links from Zeiss database:
ZF: http://lenses.zeiss.com/content/dam/Photography/new/pdf/en/downloadcenter/datasheets_slr/distagont2821.pdf
Contax:
http://lenses.zeiss.com/content/dam/Photography/new/pdf/en/downloadcenter/contax_yashica/distagon2-8_21mm_e.pdf
Oct 09, 2012 at 04:19 PM
sebboh
p.1 #20 · Leica R 19/2.8 VS Zeiss 21/2.8
Contax:
new one looks better to me on those mtfs. i thought i remembered seeing that one was better wide open and the other better stopped down last i looked. hmmm...
Oct 09, 2012 at 05:56 PM
