p.1 #1 · 5DIII LCD appearing Magenta? 5d Mark III 5d3 5dMk3
Is it me or do images on the 5D Mark III LCD appear overly magenta (compared to their actual color)? I notice this especially when shooting JPG mode, and in RAW to a lesser extent.
p.1 #5 · 5DIII LCD appearing Magenta? 5d Mark III 5d3 5dMk3
gfiksel wrote:
Do you have your jpegs set at a certain profile?
Whatever the factory default is. "Standard" I presume. They come out on the computer OK (calibrated monitors). Skin tones in particular are sometimes nuclear magenta / red on the LCD, especially when in Tungsten light corrected via Tungsten WB.
When I see them I think the WB is off, when it really isn't. First wedding I experimented w/the 5D3 had me manually adding +3 green to the WB.
p.1 #6 · 5DIII LCD appearing Magenta? 5d Mark III 5d3 5dMk3
What firmware version do you have?
This was one of the items listed in the Firmware 1.1.2 update (they're up to 1.1.3 now):
"Fixes a phenomenon where a pink cast may develop over the image when the shutter is completely pressed with the camera’s power turned off (by the auto power off setting)."
p.1 #7 · 5DIII LCD appearing Magenta? 5d Mark III 5d3 5dMk3
scalesusa wrote:
Not mine. I suspect that Canon can adjust the tint as part of the calibration setup, so if yours is off, ask them.
The Oly 4/3 allows user LCD calibration so the image display looks natural in any light. Pretty sure Canon could implement this feature in FW if they felt there was a demand.
p.1 #8 · 5DIII LCD appearing Magenta? 5d Mark III 5d3 5dMk3
Did you manage to get that fixed Andrew?
I just bought mine 2 days ago, and am having the same issue
