What are the criteria?
Bryce Canyon
RustyBug
p.1 #1 · Bryce Canyon
An impromptu drive up from Zion, arriving with only an hour to take in the waning light ... yet another too much to see, too little time.
Oct 05, 2012 at 02:32 AM
ben egbert
p.1 #2 · Bryce Canyon
I would either clone out the shadows or crop just below the larger monoliths. The sky could be darkened as well.
Heading out for some fall color or I would give it a play.
Oct 05, 2012 at 02:33 PM
newhaven
p.1 #3 · Bryce Canyon
Your image has blown channels. Try the recovery slider in ACR , or use the Apply Image command to to blend in a parts of the good channels. Duplicate the background layer, and change the blend mode to luminosity - color in background, luminosity in duplicate layer. Rebuild channels in the duplicate layer.
Oct 05, 2012 at 08:00 PM
RustyBug
p.1 #4 · Bryce Canyon
I got a lot of blown red channels from my trip out West ... this one is not exception.
However ... I'm not following your instructions ... can you clarify?
Oct 05, 2012 at 08:21 PM
newhaven
p.1 #5 · Bryce Canyon
Replace the blown out areas in the red channel with highlights from the green or blue channel using a copy of the original layer set to the luminosity blend mode. I believe channel blending is covered in a Dan Margulis book somewhere - I may have seen this in his video series on Kelby.
Another possibility is to add a channel mixer adjustment layer in luminosity mode and add more green to the red channel.
Edited on Oct 06, 2012 at 03:31 PM · View previous versions
Oct 05, 2012 at 11:11 PM
ben egbert
p.1 #6 · Bryce Canyon
Here is my take.
I cropped, added some shadow highlight to the forest, gradient mask to the top new curve.
Oct 06, 2012 at 12:24 AM
RustyBug
p.1 #7 · Bryce Canyon
I've got a couple of Dan's books ... I'll check there, thanks.
Oct 06, 2012 at 01:02 AM
pinball_pw
p.1 #8 · Bryce Canyon
Plus 1 to newhaven's post. I don't know which camera you shoot, but my Canon's always blow the red channel first. I tend to review the red histogram and adjust accordingly in these scenarios. - Paul
Oct 06, 2012 at 12:34 PM
