Archive 2012 · Straps - What do you use?
StreetShotz
p.1 #1 · Straps - What do you use?
I'm needing to get a new neck strap for my Canon's and I want to get something better than the standard Canon strap that comes with the bodys.
What is everyone using?
I was thinking of the BlackRapid RS-sport strap with the RC2 button for the Manfrotto quick release plate. This way I can use the mounting stud and still get it onto the tripod with no trouble.
Sep 23, 2012 at 06:05 PM
mco_970
p.1 #2 · Straps - What do you use?
Neck strap: Op Tech, whatever model the deluxe ones are
Sling strap: BR RS-Sport
Sep 23, 2012 at 06:56 PM
vsg28
p.1 #3 · Straps - What do you use?
http://www.carryspeed.com/products/fs-pro-camera-sling-strap-with-f-1-foldable-mounting-plate
Sep 23, 2012 at 08:05 PM
rchb
p.1 #4 · Straps - What do you use?
http://photipherals.com/listing/pho-reel%e2%84%a2-camera-shoulder-strap-system/
Sep 23, 2012 at 08:25 PM
irish-george
p.1 #5 · Straps - What do you use?
I like Tamrac N-25 (similar to OpTech).
Sep 23, 2012 at 08:41 PM
M635_Guy
p.1 #6 · Straps - What do you use?
I love my BlackRapid RS-7, though I had to create a "rig" to make it happy with my Arca-Swiss setup. I don't know why they don't come up with something similar (and less expensive) - they said at CES in January they were working on something for release "this summer" (which obviously is over)...
Sep 23, 2012 at 08:47 PM
sjms
p.1 #7 · Straps - What do you use?
mine is a combination of a Luma Labs Cinch and a Custom SLR C Loop.
http://luma-labs.com/products/cinch
http://www.customslr.com/products/c-loop
just started out playing with the idea since Luma hasn't come out with a QR design for the Cinch strap (which i like) and threw them together. works better then i thought it would interchangeably with both my D4, D7000, and even my X10. screws right into my RRS L bracket bases and stays put due to the C Loop design. pretty much completely out of the way in use.
http://i.pbase.com/o3/89/44489/1/146248472.mfcOwHvu.DSCF1370.jpg
Sep 23, 2012 at 09:16 PM
wordfool
p.1 #8 · Straps - What do you use?
Optech... pro strap, wrist strap or sling strap.... once you buy the correct connectors (in my case pro loop) you can switch between the three options in seconds
Sep 23, 2012 at 11:26 PM
15Bit
p.1 #9 · Straps - What do you use?
Handstrap only, from camdapter.
Sep 24, 2012 at 12:08 AM
DLP
p.1 #10 · Straps - What do you use?
Op-Tech.
Sep 24, 2012 at 07:00 AM
EB-1
p.1 #11 · Straps - What do you use?
Tamac or Optek, but mostly the Tamrac.
Sep 24, 2012 at 05:12 PM
helimat
p.1 #12 · Straps - What do you use?
The Wapiti Strap is where it's at
http://farm5.staticflickr.com/4145/5005395720_5b68eecd1b_z.jpg
Sep 24, 2012 at 06:21 PM
EB-1
p.1 #13 · Straps - What do you use?
Maybe that works for a small camera/lens, but it would be painful for a 1 series and 300/2.8.
Sep 24, 2012 at 06:51 PM
helimat
p.1 #14 · Straps - What do you use?
I had the larger Wapiti Strap on my 1D Mark III, and it is also great. I should say though it would not be the best idea to carry the weight of a 1 series + 300/2.8 by the camera strap.
http://farm8.staticflickr.com/7163/6625679991_88737fff2f_z.jpg
Sep 24, 2012 at 09:26 PM
RDKirk
p.1 #15 · Straps - What do you use?
I use a couple of DIY "Frankenstraps" made from Domke swivels and leads with Tamrac padded suede pads.
Sep 24, 2012 at 09:59 PM
p.1 #16 · Straps - What do you use?
Domke Gripper, modified.
https://www.fredmiranda.com/forum/topic/1067381/1#10163047
https://www.fredmiranda.com/forum/topic/1103127/0#10530515
Sep 25, 2012 at 09:50 AM
goldjim
p.1 #17 · Straps - What do you use?
+1 for the Wapiti strap. Love mine.
Sep 25, 2012 at 12:02 PM
Carson Wilcox
p.1 #18 · Straps - What do you use?
I've been using the op-tech classic for years:
http://www.adorama.com/OTCLSBK.html
Sep 25, 2012 at 01:21 PM
swoop
p.1 #19 · Straps - What do you use?
UpStrap
Sep 25, 2012 at 03:15 PM
dalite
p.1 #20 · Straps - What do you use?
I don't see how the Tamrac or Optek is an improvement over the OEM camera strap, unless you feel a little more padding is worth the extra $$. Personally, I think the BlackRapid RS-4 is a good alternative.
Oct 01, 2012 at 12:46 AM
